P: Thermalright Burst Assassin 120 ARGB NOV Zapakiran
nejko8 ::
Prodam nov zapakiran CPU hladilnik.
Za podnožja:
Intel:115X/1200/1700/1851
AMD:AM4/AM5
Povezava do strani proizvajalca: https://www.thermalright.com/product/bu...
Technical Spec :
Heatsink Specifications:
Dimension:L124 mm x W52 mm x H154 mm
Weight:510g
Heat pipes:6mm heatpipe x 6 units
Copper Base:C1100 Pure copper nickel plated
TL-C12CG-S FAN Spec:
Dimension:L120 mm x W120 mm x H25 mm
Weight:120g
Rated Speed:1550 RPM±10% (MAX)
Noise Level:25.6 dBA
Air Flow:66.17 CFM (MAX)
Air Pressure:1.53 mm H2O (MAX)
Ampere:0.20 A
ARGB Port:5V/3Pin
Connector:4 Pin (PWM Fan connector)
Bearing Type : S-FDB Bearing
Priložim še 1 dodatni nov Thermalright ARGB ventilator, tako da lahko na hladilnik namestite dva za boljše hlajenje in airflow v ohišju!
Cena: 25€
Kontakt na ZS.
Možna menjava za brezhibno delujoč napajalnik 550W+ z 8 pin pci-e.
P: Corsair HX750 750 W 80+ Platinum, popolnoma modularen napajalnik
55 €
Oddelek: Mali oglasi
0212 (212) nejko8
P: Crucial 16GB DDR4 2666MHz RAM CT16G4DFD8266
60 €
0206 (206) nejko8
P: 2 x 8GB DDR4 SODIMM RAM Samsung M471A1K43DB1-CWE 3200mhz
60 €
0258 (258) nejko8
P: Thermalright Phantom Spirit 120 EVO CPU Hladilnik
40 €
0179 (179) nejko8
P: prenosnik HP EliteBook 840 G7 i5 10. gen/ 16GB RAM /256GB SSD
250 €
0202 (202) nejko8
60 €
0333 (333) nejko8
P: SSD 256GB NVMe M.2 SK Hynix PCIe
20 €
0387 (387) nejko8
260 €
0347 (347) nejko8
