P: Thermalright Phantom Spirit 120 EVO CPU Hladilnik
nejko8 ::
Prodam vrhunski hladilnik. Brezhibno delujoč in malo rabljen. Priložen ves material za pritrditev.
Podnožja:
Intel:LGA115X/1200/1700/1851/2011/2066
AMD:AM4/AM5
Uradna stran proizvajalca: https://www.thermalright.com/product/ph...
Technical Spec :
Heatsink Specifications:
Dimension:L110 mm x W125 mm x H157 mm
Weight:810g(Without Fan)
Heat pipes:6mm heatpipe x 7 units
Copper Base:C1100 Pure copper nickel plated
TL-K12 FAN Spec:
Dimension:L120 mm x W120 mm x H25 mm
Weight:220g
Rated Speed:2150 RPM±10% (MAX)
Noise Level:27 dBA
Air Flow:69 CFM (MAX)
Air Pressure:2.87 mm H2O (MAX)
Ampere:0.16 A
Connector:4 Pin (PWM Fan connector)
ARGB Connector: 3 PIN 5V
Bearing Type : S-FDB V2 Bearing
Kontakt na ZS.
Cena: 40€
P: Corsair HX750 750 W 80+ Platinum, popolnoma modularen napajalnik
55 €
Oddelek: Mali oglasi
0212 (212) nejko8
P: Crucial 16GB DDR4 2666MHz RAM CT16G4DFD8266
60 €
0208 (208) nejko8
P: 2 x 8GB DDR4 SODIMM RAM Samsung M471A1K43DB1-CWE 3200mhz
60 €
0259 (259) nejko8
P: Thermalright Burst Assassin 120 ARGB NOV Zapakiran
25 €
0178 (178) nejko8
P: prenosnik HP EliteBook 840 G7 i5 10. gen/ 16GB RAM /256GB SSD
250 €
0202 (202) nejko8
60 €
0333 (333) nejko8
P: SSD 256GB NVMe M.2 SK Hynix PCIe
20 €
0391 (391) nejko8
260 €
0349 (349) nejko8
