Problemi z google računom na Android napravi
mrTwelveTrees ::
Na noname tablici, Android 13
Imam pri logiranju gmail računa problem, sprejme email + geslo, tudi na svojem telefonu potrdim napravo
potem se pa ustavi izpiše Your security code
code 1 10 mestna št.
code 2 10.mestna št.
ni nobene druge opcije preko SMS, mail ali kaj
nimam pojma kam te kode morm te kode vnesit.
na https://myaccount.google.com/
imam naprave in tam najdem "Android" napravo to je to
- ura in datum sta prava
- posodobljena Play trgovina sicer delno sprejme gmail account da lahko nalagam
- posodobljen Youtube - se ne morem logirat
- Maps - se ne morem logirat
1. On your phone, go to Settings and then Google.
2. Tap Manage your Google Account. Then, scroll right and tap Security and then Security code
3. If needed, enter your phone password and pick the account.
4. A 10-digit code generates on your phone.
5. Enter the code on the device you want to sign in on and tap Continue.
Zgleda, da boš moral to zgenerirat na svojem telefonu.
mrTwelveTrees ::
Pa to vem, samo meni telefon generira to 10 mestno št.
pravtako tablica 10 mestno št.
Kaj mi to nuca, če me tablica ne vpraša za vnesti št. ali telefon.
To sem še našel, se opravičujem:
https://www.reddit.com/r/GMail/comments...
I don't believe those 10-digit codes are used any more.
Is there a working recovery e-mail and recovery phone configured on the account? If not, it will probably be impossible to prove ownership of the account.
- The only account recovery option Google provides starts at https://accounts.google.com/signin/reco...
- Google does not provide live support for account recovery, you must use the above link.
mrTwelveTrees ::
To ni obnova računa. Ne rabim obnovo računa.
driftwood ::
poskusi tole:
-odjavi napravo iz google računa
-namesti 2fa avtentikacijo za dostop do google računa
vir:
https://www.reddit.com/r/chrome/comment...
mrTwelveTrees ::
Sem rešil.
Ker uporabljam svojo domeno na googlu, sem moral v Admin nadzorni plošči izklopiti, da ne zahteva zaklenjenega zaslona Android napravi.
Glupa fora.
Kreiranje google accounta: This phone number cannot be used for verification.
211944 (1007) rado7rado
Android - napaka pri dodajanju Google računa
Oddelek: Mobilne tehnologije
72154 (1253) TheBlueOne
kako odkleniti LG G5?
303462 (2850) louser
TeamViewer nedosegljiv, vdor kljub pričevanjem uporabnikov zanikajo (strani: 1 2 )
Oddelek: Novice / Varnost
5319430 (13658) Saul Goodman
Kje je fora takih mailov, ki jih dobivam?
123418 (3031) Sandi79
