Forum » Mali oglasi » P: Cambridge Audio Azure 350A - integriran stereo ojačevalec
strumf666 ::
Prodam brezhiben ojačevalec z daljinskim upravljalnikom.
Specifikacije:
Power Output .................45 watts (into 8 ohms)
THD (unweighted)....................... 0.02%@1kHz, 80% of rated power / 0.15% 20Hz – 20kHz, 80% of rated power
Inputs.................................... 5 inputs, 1 Tape Input, ¼’’ headphone input, 3.5mm MP3 input
Outputs................................. Speaker A & B outputs, 1 Record Output
Frequency response (-1dB)..........................5Hz – 50kHz
S/N ratio (ref 1W) ................................>92dB (unweighted)
Input Impedances............................... 47k ohms
Max. Power Consumption .....................320W
Bass/Treble controls............................ Shelving, ultimate boost/cut +/-10dB @ 20Hz and +/-6dB @ 20kHz
Dimensions (H x W x D)....................... 86 x 430 x 340mm (3.4 x 16.9 x 13.4’’)
Weight............................................. 6.0kg (13.2lbs)
Cena 180€
Kontakt na peter(pika)stampfel(afna)gmail(pika)com ali ZS
LP,
Peter
Specifikacije:
Cena 180€
LP,
Peter
Member of OC-Lab Team
http://www.oc-lab.si/
| » | P: Črn moški usnjen plašč s snemljivo podlogo200 € Oddelek: Mali oglasi | 286 (286) | strumf666 |
| » | P: Fujitsu/FSC Lifebook port replikator/dock in polnilec30 € Oddelek: Mali oglasi | 184 (184) | strumf666 |
| » | P: Napajalni modul in napajalnik za raspberry Pi15 € Oddelek: Mali oglasi | 169 (169) | strumf666 |
| » | P: kable hdmi, dp-hdmi15 € Oddelek: Mali oglasi | 167 (167) | strumf666 |
| » | P: HP USB-C Travel Hub G3 - usb-c hub z hdmi portom60 € Oddelek: Mali oglasi | 251 (251) | strumf666 |
| » | P: Lenovo ThinkCentre M92p80 € Oddelek: Mali oglasi | 193 (193) | strumf666 |
| » | P: Samsung 2433BW 24" 16:10 monitor50 € Oddelek: Mali oglasi | 188 (188) | strumf666 |
| » | P: Zvocnike Logitech Z-5500, 5.1, 505W RMS190 € Oddelek: Mali oglasi | 418 (418) | babicdeni |
| » | P: Cambridge Audio Azure 350A - integriran stereo ojačevalec200 € Oddelek: Mali oglasi | 331 (331) | strumf666 |
| » | P: Cambridge Audio Azure 350A - integriran stereo ojačevalec200 € Oddelek: Mali oglasi | 258 (258) | strumf666 |
