P: Crucial Ballistix 3200 MHz DDR4 DRAM 32GB (16GBx2)
Nikonja ::
Prodam cca 4 leta staro memorijo iz naslova, od takrat stabilno dela na i7 12700k na 3600Mhz XMP profil
Podatki iz CPU-z
Memory Type DDR4
Memory Size 32 GBytes
Channels 2 x 64-bit
Memory Frequency 1800.0 MHz (1:27)
Memory Max Frequency 3200.0 MHz
CAS# latency (CL) 16.0
RAS# to CAS# delay (tRCD) 20
RAS# Precharge (tRP) 20
Cycle Time (tRAS) 40
Bank Cycle Time (tRC) 60
Row Refresh Cycle Time (tRFC) 993
Command Rate (CR) 1T
Uncore Frequency 800.0 MHz
Memory Controller Frequency 1800.0 MHz
Memory type DDR4
Module format UDIMM
Module Manufacturer(ID) Crucial Technology (7F7F7F7F7F9B00000000000000000000)
SDRAM Manufacturer (ID) Micron Technology (2C000000000000000000000000000000)
Size 16384 MBytes
Max bandwidth DDR4-3200 (1600 MHz)
Max JEDEC DDR4-2666 (1333 MHz)
Part number BL16G32C16U4W.M8FB1
Serial number E5E751BE
Manufacturing date Week 23/Year 21
Nominal Voltage 1.20 Volts
EPP no
XMP yes, rev. 2.0
Cena 40 eur!
Kontakt na zs ali na email nikonja at gmail pika com
  • spremenilo: Nikonja ()
