Forum » Strojna oprema » NVIDIA GeForce RTX 60 (Rubin 3nm)
FlyingBee ::
Verjetno ne bo geforce
NVIDIA GTC 2026: Jensen Huang promises a chip reveal meant to "surprise the world"
New Sphincter Kvartet:
FlyingBee ::
JUST IN: Nvidia $NVDA reports $68 billion in revenue for Q4 2025, higher than expectations.
FlyingBee ::
Baje ne bo raster napredka, predvsem RT in memory bandwidth.
https://hothardware.com/news/geforce-rt...
Vir je pa RedGamingTech, ki ima dokazano manj zanesljive "vire" od moje kristalne krogle.
Predlagam, da daš tega spammerja pod "Don't recommend channel".
RTX6080 z 20Gb VRAMA? Lol? Torej 10 čipov po 2Gb? Takšne RAMpocalypse pa vseeno ne bo čez ~10 mesecev. :///
- spremenil: DarwiN ()
FlyingBee ::
Če bo sploh še kaj izšlo
Kurzweil ::
NVIDIA je objavila na svojem uradnem FB profilu:
In nekako človek pride do ugotovitve, da so to geografske koordinate tajvanskega Taipeia, lokacije, kjer se odvija Computex. Tu običajno Nvidia objavlja največje dosežke, izide, napovedi na področju grafičnih kartic in AI. Jaz bi si drznil ugibati, da bodo to nove grafične serije 60, lahko pa se povsem motim... koliko bo to nova era za PC pustimo za druge debate...
Eden od zabavnih kometarjev pa je bil, da gre za MRSP range novih kartic
A new era of PC.
25.0528, 121.5990
FlyingBee ::
Verjetno v zvezi z N1 laptopi, žal so Geforci za namizni pc peto kolo.
FlyingBee ::
Koordinate sta tudi Microsoft in Arm na X objavila, tako da bo to očitno N1 čip, se pravi (novi ali ponovni) vzpon ARMa v PC sferi.
FlyingBee ::
AI runs locally on the device. and the smaller models got good enough that a laptop can run one by itself now
the computer stops waiting for you and starts working with you. coding, editing, research, all on your machine
that's what "a new era of PC" actually means
FlyingBee ::
AMD Fusion v zeleni preobleki z okusom ARMa:
Reports suggest Blackwell-based graphics that could give thin and light laptops much stronger gaming and AI performance than current Windows-on-ARM devices.
FlyingBee ::
Dvomim, da bo na nivoju 5070, mogoče prvih par minut.
The iGPU is based on the "Blackwell" graphics architecture, and features 48 streaming multiprocessors (SM) worth 6,144 CUDA cores, and up to 1 petaFLOP of FP4 AI performance. This features a similar specs-sheet to the desktop GeForce RTX 5070 graphics card.
GALAX shows GeForce RTX 6090 HOF concept with Swarovski crystals, as if current cards weren't expensive enough
https://videocardz.com/newz/galax-shows...
FlyingBee ::
AMD RDNA 5 and Nvidia Rubin GPUs could both slip to late 2027 or 2028, board partners suggest.
https://www.techspot.com/news/112682-am...
FlyingBee ::
Medtem pa...NVIDIA GeForce RTX 50 SUPER series now rumored early 2027.
Nvidia dolgo čaka z novimi grafičnami.
Bratranc in sestrična sta se tako odločila :D
Mtosev se tudi dobro odločil.. Plačal čez 3k, ampak danes bi ga 5090 koštala ~4k. Pa še leto dni jo lahk ima zapakirano, pa bo kartica še vedno latest&greatest. :P
Sej ima lahko 16GB, saj več ne rabi.
Je pa trg čist izkrivljen. 5080 za 1200€, 5090 pa 3800€, 3x več, vmes pa vakum. Boli Nvideo.
FlyingBee ::
Ja, ni dinar za gaming.
Linux 7.2 Begins Making Preparations For NVIDIA "Blackwell-Next"
https://www.phoronix.com/news/NVIDIA-Bl...
NVIDIA Rubin GPUs Bring 10x Increase in Agentic AI Performance Versus Blackwell as Its Architecture Gets Fully Unpacked, Featuring 336 billion Transistors
https://wccftech.com/nvidia-rubin-gpu-a...
FlyingBee ::
Geforce bo 2028?
PluribusUnum ::
FlyingBee ::
Dober Hommage bi bil.
Rumor: No NVIDIA "Rubin" and AMD RDNA 5 Gaming GPUs Until 2028
https://www.techpowerup.com/352761/rumo...
Škoda, da bodo grafe pozneje izšle.
FlyingBee ::
Za koliko prodaš 5090?
Sem v mimovrste BTC gledal RTX 5080.
Kok gromozanska grafa....igre pa ne iz gledajo nič boljše, kot pa med Crysis časom :D
What gives?
What gives?
Jaz pa sem po 10++ letih končno opazil konkreten napredek v grafiki. Pri peščici iger. Mogoče je to znak stvari, ki prihajajo. Denimo Forest Doesn't Care, predvsem pa streljačina Bodycam. Tole izgleda res noro. To je prva igra po PUBG, ki bi jo dejansko igral. Ampak bi potreboval Mtosevo grafično za moj 4k TV-monitor.. ://
Mtosev, posodiš, dokler ti leži v predalu?
FlyingBee ::
Unreal Engine 5 je velik napredek, pa pogon v Forza Horizont 6 tudi, vegetacija in nekatere scene v mestu so najboljše kar sem videl do zdaj. Seveda je bil Crysis večji boom takrat, pa vseeno ni več primerjave, osvetlitev je na najvišjem nivoju. Bodycam (UE5 pogon) je že zelo blizu realizma kar se prikazuje na 2D zaslonu.
Pusti mimovrste, zavij najprej k prvemu lokalnemi okulistu.
What gives?
- spremenil: FlyingBee ()
Ijus ::
jaz bi samo malo spotoma/vzporedno vprašal v tej temi, če dovolte prosim: kva so tam neke grafe, k je pisal v naslovih od videjev na YT, tko like 5000% hitrejše od GPU?
nisem pol gledal te videje. nisem mel časa pa interesa ker tud nisem bil in the mood.
lahk kdo sam na hit pove kva so to za ene stvari?
mislim da je pisal nekaj v smislu LPU al NPU.
pa da je nvidia to nekako hit ušutkala ker je preveč kompetentno.
kao za đabe tko like par sto € bi mel tko like 2000% boljšo grafo od nvidie.
neki tazga je pisal. al se motim?
strom_15 ::
Grafične kartice Nvidia RTX 60 že v začetku leta 2027?
Prvotni načrti so predvidevali izid nove družine grafičnih kartic Nvidia GeForce RTX serije 60 v letu 2026, vendar je prilagoditev proizvodnje za potrebe umetne inteligence časovnico premaknila. Kljub temu viri navajajo, da je projekt sedaj dobil zeleno luč, Nvidia pa ima postavljene jasne interne mejnike za začetek proizvodnje tovrstnih grafičnih kartic že leta 2027. Nova zgradba grafičnih kartic Nvidia Rubin naj bi pri vodilnih modelih uporabila prilagojen proizvodni proces TSMC 3NP, saj bodo zmogljivejši 2 nm proces verjetno hranili za poslovne AI izdelke. Viri prav tako namigujejo na nenavadno fizično zasnovo samega grafičnega procesorja, ki bi lahko prinesla prehode na tako imenovano čipletno zgradbo. Takšna časovnica postavlja Nvidio v neposreden spopad z AMD-jevo arhitekturo AMD RDNA 5, ki naj bi prinesla ogromen skok v zmogljivosti, medtem ko naj bi cenejši AMD modeli uporabljali pomnilnik LPDDR namesto GDDR. Ob tem ostaja odprto vprašanje glede zmogljivosti novih kartic serije RTX 60. Ker je pridobivanje surove moči brez prekomerne porabe energije čedalje težje, se bo Nvidia verjetno še bolj zanašala na tehnologijo Nvidia DLSS 5. Povečanje porabe bi namreč lahko poslabšalo težave z napajalnimi priključki, ki so pestile serijo Nvidia GeForce RTX serije 50 in nekatere starejše modele. Ker gre za nepotrjene govorice in precej oddaljene načrte, velja biti pri pričakovanjih zadržani. Skrivnost ostaja tudi usoda družine grafičnih kartric Nvidia GeForce RTX 50 Super, ki naj bi po poročilih nabirala prah v skladiščih zaradi neusklajenih cen med Nvidio in distributerji, zato nihče ne ve, ali bo sploh kdaj ugledala luč sveta.
Več na: https://racunalniske-novice.com/graficn... - racunalniske-novice.com
Nikonja ::
To je že par dni stara novica katero je plasirala ena oseba, ta zadnja je zgoraj linkana in po večini velikooooo bolj realna glede na probleme z memorijo:
strom_15 ::
Bomo pač čakali.
FlyingBee ::
Itak bo samo 20%.
Gregor459 ::
NVIDIA RTX 6060 May Slip to 2029, Leaker Claims https://shattered.io/nvidia-rtx-6060-20... dolga bo za čakat.
FlyingBee ::
6070 za 700 eur in basta!
6070 s 12GB za 700EUR. 5% hitrejša od 5070.
PS. 700EUR bo MSRP, realna cena pa je neznanka. Ali pa bo prej AI bust in ne bomo imel denarja.
- spremenil: Magic1 ()
| » | Nvidia Feynman - GPUOddelek: Strojna oprema | 2057 (1114) | oo7 |
| ⊘ | NVIDIA Blackwell (3nm GPU) (strani: 1 2 )Oddelek: Strojna oprema | 9692 (5162) | bluefish |
| » | Nvidia privzema strategijo tik-takOddelek: Novice / Procesorji | 4937 (1154) | Ghost7 |
