Problem s cdrw
Problem s cdrw
Jany ::
Imam probleme s snemanjem cdjev na cdrw teac. Včasih mi vrže ven nas sredini snemanja, včasih na koncu. Imam sveže naložene xpje, snemal sem pa tako da sem najprej posnel sliko na disk in potem na cd, vse to z nerotom 6.0.0.23. Snemal sem z samo 16x. Imam pa 40x12x48x. Probal sem z dvema medijema lg in princo in se mi zdi da pri lgjih vrže prej ven. Napiše "zapisavanje neuspešno". Že vnaprej hvala za pomoč!
Ven mi vrže ta log:
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 17.6.2003 15:25:04
Verzija Nera 6.0.0.23
Zapisovalnik: CD-W540E Verzija: 1.0K - HA 1 TA 0 - 6.0.0.23
Gonilnik vmesnika: atapi HA 1
Drive buffer : 8192kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
CD-ROM: TEAC CD-W540E Verzija: 1.0K - HA 1 TA 0 - 6.0.0.23
=== Scsi-Device-Map ===
DiskPeripheral : WDC WD800JB-00ETA0 atapi Port 0 ID 0 DMA: On
CdRomPeripheral : TEAC CD-W540E atapi Port 1 ID 0 DMA: On
CdRomPeripheral : LITEON DVD-ROM LTD122 atapi Port 1 ID 1 DMA: On
=== CDRom-Device-Map ===
TEAC CD-W540E D: CDRom0
LITEON DVD-ROM LTD122 E: CDRom1
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 40894464 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 255MB (261616kB)
Free physical memory: 164MB (168048kB)
Memory in use : 35 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
12.11.2003
===== Disc-Copy over image - 1st step : Copy to image ...
13:52:06 #1 Text 0 File Reader.cpp, Line 118
Reader running
13:52:06 #2 Phase 48 File dlgbrnst.cpp, Line 1803
Analiziram disk
13:52:06 #3 Text 0 File Writer.cpp, Line 124
Writer Image Recorder running
13:52:06 #4 CDCOPY -1 File CDCopy.cpp, Line 1873
CD je avtorsko zaščiten.
13:52:11 #5 Text 0 File CDCopy.cpp, Line 2089
_Index0_ _______Index1_______ PostPause ___LastBlockOfTrack_
Track 1: 0 0 ( 0:02.00) 344057 344056 ( 76:29.31)
13:52:11 #6 Text 0 File CDCopy.cpp, Line 840
Copy options: copy on-the-fly: ON
read ISRC/MCN: OFF
use jitter correction: OFF
data options
ignore read error: OFF write defekt blocks OFF
read raw data: OFF read r-w subchannel data: OFF
audio options
ignore read error: ON
read indexes: OFF read r-w subchannel data: OFF
source disc does not look like CD Extra
01. 0 - 344057 = 344057, data (TRM_DATA_MODE1, block size 2048)
13:52:11 #7 Text 0 File Burncd.cpp, Line 3218
Turn on Disk-naenkrat, using CD-R/RW media
13:52:11 #8 Text 0 File DlgWaitCD.cpp, Line 233
Last possible write address on media: 2147483646 (477218:37.21)
Last address to be written: 344056 (76:29.31)
13:52:11 #9 Text 0 File DlgWaitCD.cpp, Line 238
Write in overburning mode: FALSE
13:52:11 #10 Text 0 File DlgWaitCD.cpp, Line 1997
Recorder: Image Recorder;
CD type reading failed
ATIP Data: ?
13:52:11 #11 Text 0 File DlgWaitCD.cpp, Line 398
Protocol of DlgWaitCD activities:
13:52:11 #12 Text 0 File ThreadedTransferInterface.cpp, Line 773
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (1 Podatki (mode 1))
2 indices, index0 (150) not provided
original disc pos #0 + 344057 (344057) = #344057/76:27.32
relocatable, disc pos for caching/writing not required/not required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 344057 blocks [ Image Recorder ]
13:52:11 #13 Text 0 File ThreadedTransferInterface.cpp, Line 942
Prepare recorder [ Image Recorder ] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 704935936, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
-150 | lead-in | 0 | 0x00 | 0x41
-150 | 1 | 0 | 0x00 | 0x41
0 | 1 | 1 | 0x00 | 0x41
344057 | lead-out | 1 | 0x00 | 0x41
13:52:11 #14 Phase 120 File dlgbrnst.cpp, Line 1803
Ustvarjanje slike za zapisovanje
13:52:11 #15 Text 0 File ThreadedTransferInterface.cpp, Line 2146
Verifying disc position of item 0 (relocatable, no disc pos, no patch infos, orig at #0): write at #0
14:01:47 #16 Text 0 File WriterStatus.cpp, Line 113
< Image Recorder > start writing Lead-Out at LBA 344057 (53FF9h), lenght 0 blocks
14:01:47 #17 Text 0 File ThreadedTransfer.cpp, Line 229
all writers idle, stopping conversion
14:01:47 #18 Phase 121 File dlgbrnst.cpp, Line 1803
Ustvarjanje pod. slike uspešno zaključeno
===== Disc-Copy over image - 2nd step : Burn the image ...
14:01:56 #1 Phase 72 File dlgbrnst.cpp, Line 1803
BURN-Proof aktiviran
14:01:57 #2 Text 0 File Reader.cpp, Line 118
Reader running
14:01:57 #3 Text 0 File Writer.cpp, Line 124
Writer TEAC CD-W540E running
14:01:57 #4 IMAGEGEN -10 File ImageGen.cpp, Line 363
Image was written as DAO.
DAOI:
MediaCatalogNumber = ''
TocType = 0x00
Finalized = 1
First/Last Track = 1 / 1
1: ISRC = ''
Blocksize = 2048
TrackMode = 'TRM_DATA_MODE1'
TrackConfig = 0x00
First/Last Index = 0 / 1
Index0FilePos = 0, Index1FilePos = 307200, NextTrackFilePos = 704935936
CUES:
0: Ctrl=0x41 Trk= 0 (0x00) Index=00 RecDep=0x00 Start=954437:08.46 ( -150)
1: Ctrl=0x41 Trk= 1 (0x01) Index=00 RecDep=0x00 Start=954437:08.46 ( -150)
2: Ctrl=0x41 Trk= 1 (0x01) Index=01 RecDep=0x00 Start=00:00.00 ( 0)
3: Ctrl=0x41 Trk=110 (0xAA) Index=01 RecDep=0x00 Start=76:27.32 ( 344057)
MTYP: Mediumtype = CD (old format) (0x1)
14:01:58 #5 Text 0 File Burncd.cpp, Line 3218
14:02:18 #6 Text 0 File DlgWaitCD.cpp, Line 233
Last possible write address on media: 359848 (79:59.73)
14:02:18 #7 Text 0 File DlgWaitCD.cpp, Line 238
14:02:18 #8 Text 0 File DlgWaitCD.cpp, Line 1997
Recorder: TEAC CD-W540E;
CDR code: 00 97 27 18; OSJ entry from: Plasmon Data systems Ltd.
ATIP Data:
Special Info [hex] 1: D0 00 A0, 2: 61 1B 12 (LI 97:27.18), 3: 4F 3B 4A (LO 79:59.74)
Additional Info [hex] 1: 00 00 80 (invalid), 2: 00 80 00 (invalid), 3: 00 00 00 (invalid)
14:02:18 #9 Text 0 File DlgWaitCD.cpp, Line 398
Insert empty disc to write to.
(Medium in drive: Neznano. Medium required by compilation: CD-R/RW.)
14:02:18 #10 Text 0 File ThreadedTransferInterface.cpp, Line 773
0: TRM_DATA_MODE1 (CD-ROM Mode 1, Joliet)
2 indices, index0 (150) provided
not relocatable, disc pos for caching/writing not required/not required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 344057 blocks [TEAC CD-W540E ]
14:02:18 #11 Text 0 File ThreadedTransferInterface.cpp, Line 942
Prepare recorder [TEAC CD-W540E ] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
Tracks 1 to 1:
DAO layout:
14:02:18 #12 Phase 36 File dlgbrnst.cpp, Line 1803
Začetek zapisovanja na 16x (2.400 KB/s)
14:02:18 #13 Text 0 File ThreadedTransferInterface.cpp, Line 2146
Verifying disc position of item 0 (not relocatable, no disc pos, no patch infos, orig at #0): write at #0
14:02:18 #14 Text 0 File Mmc.cpp, Line 14897
StartDAO : CD-Text - Off
14:02:18 #15 Text 0 File Mmc.cpp, Line 19359
Set BUFE: BURN-Proof -> ON
14:02:18 #16 Text 0 File Mmc.cpp, Line 15217
CueData, Len=32
41 00 00 14 00 00 00 00
41 01 00 10 00 00 00 00
41 01 01 10 00 00 02 00
41 aa 01 14 00 4c 1d 20
14:05:20 #17 SCSI -1135 File Cdrdrv.cpp, Line 1427
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x03830000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x02 0xFB 0x00 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x0C 0x00
14:05:20 #18 CDR -1135 File Writer.cpp, Line 301
Napaka pri zapisovanju.
14:05:20 #19 Text 0 File ThreadedTransfer.cpp, Line 229
14:05:21 #20 Text 0 File ThreadedTransfer.cpp, Line 223
conversion idle, stopping reader
14:05:22 #21 Text 0 File dlgbrnst.cpp, Line 1661
Set remaining time: 0:00,000 (0ms) -> OK
14:05:22 #22 Phase 38 File dlgbrnst.cpp, Line 1803
Zapisovanje neuspešno na 16x (2.400 KB/s)
Existing drivers:
File 'Drivers\atapi.sys': Ver=5.1.2600.1106 (xpsp1.020828-1920), size=86912 bytes, created 29.8.2002 2:27:50 (Adapter driver for rec)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Epox 8RDA+ rev 2.2 + Athlon XP 1700+, 256 PC3200, 80GB WD 7200 RPM, Gf3 TI200
ERGY ::
Tvoja resitev je v Clonecdju, skini kr tazadno verzijo pa probi eno kopijo nredt, verjetno ti uspe.:))
Packač ::
Pršu sm to tukaj pol se mi ni delo več brat, ker sumim da je to vzrok:
Probi z cloneCD kot je ERGY reku ali pa teci po originalen CD ;)
Druge CDje ti pa vrjetno brez težav peče???
_juMek ::
Probi firmware upgradat_dobijo se na kakšni strani od proizvajalca!!ker men je včasih isto delal!LP.
Jumek_rola
NEC ND-3540A problem...
282786 (2077) dean444
LG GSA-4120B dela probleme pri pečenju DL DVD+Rjev
442197 (2006) mtosev
Plextor writer 24/48/48 problem! (strani: 1 2 )
646238 (5747) Hux
Težave s pekačem
122376 (2316) boštjan
PLEXTOR BurfProof unicuje cdje - prosim pomagajte!
92164 (1918) krho
