Forum » Operacijski sistemi » Hibernation faild 0xc000007f.
k4vz0024 ::
Tole dobim
C:\Windows\system32>powercfg /hibernate on
Hibernation failed with the following error: The request is not supported.
The following items are preventing hibernation on this system.
The system could not create the hibernation file.
The specific error code is 0xc000007f.
V čem je problem?
V čem je problem?
- poskusil klonirati: k4vz0024 ()
Premalo prostora na disku za hibernacijsko datoteko.
k4vz0024 ::
Fizičnega pomnilnika je 16 GB.
Na C: je 8 GB rezerviranih za swap file. Na razpolago je še 4 GB prostora na C.
Dobim odgovor:
C:\Windows\system32>powercfg -h 30
Hibernation state must be "on" or "off"
To se je zgodilo, ko sem z Revouninstaller odstranil MS Edge, da bi pridobil več prostega prostora.
Kako ročno keriram hiberfile?
Dobim odgovor:
- spremenil: k4vz0024 ()
k4vz0024 ::
Ukaza C:\Windows\system32>touch c:\hiberfil.sys ne prepozna.
'touch' is not recognized as an internal or external command,
operable program or batch file.
Gre za Windows 10 enterprise.
k4vz0024 ::
Poskusil sem s tem:
C:\Windows\system32>powercfg /hibernate /size 30
A device attached to the system is not functioning.
Kaj je narobe?
Kaj je narobe?
k4vz0024 ::
Tole tudi ne prikaže gumba za mirovanje:
C:\Windows\system32>powercfg /setactive ac093644-6503-4314-b3b6-0b601924e3e9
Invalid Parameters -- try "/?" for help
C:\Windows\system32>powercfg /setactive 3703a64d-1b48-4668-ae1c-e8c1cca1481a
C:\Windows\system32>powercfg /setdcvalueindex SCHEME_CURRENT 4f971e89-eebd-4455-a8de-9e59040e7347 7648efa3-dd9c-4e3e-b566-50f929386280 0
C:\Windows\system32>powercfg -setactive SCHEME_CURRENT
C:\Windows\system32>powercfg /availablesleepstates
The following sleep states are available on this system:
Standby (S3)
The following sleep states are not available on this system:
Standby (S1)
The system firmware does not support this standby state.
Standby (S2)
Hibernate
The system could not create the hibernation file. The specific error code is 0xc000007f.
Standby (S0 Low Power Idle)
Hybrid Sleep
Hibernation is not available.
Fast Startup
Kako kreirati hibernacijski file ročno?
Standby (S3)
Standby (S1)
Standby (S2)
Hibernate
Hybrid Sleep
Fast Startup
k4vz0024 ::
Sem sprostil prostor na disku. Še vedno ne morem kreirati hibernacijsko datoteko. Iščem po spletu, vendar nobena od rešitev ne vklopi hibernacijo. Ima kdo kakšen predlog? Obupno ga potrebujem, ker mi hibernacija skrajša čas za začetek z delom z računalnikom.
k4vz0024 ::
Na poziv sem dobil tale odgovor:
C:\Windows\system32>powercfg -h /size 75%
V čem je problem?
V čem je problem?
k4vz0024 ::
Glede na to, da se zaenkrat ne najde rešitve za vklop hibernacije, me zanima ali obstaja program, ki bi ob zagonu sistema naložil programe bodisi z zamikom ali ob določenim časom? Na internetu je kar nekaj programov, ki omogočajo nalaganje programov ob zagonu Windowsow, vendar brez določitve zakasnitve nalaganja ali nalaganja ob določenem času.
Poskusi v cmd z ukazom " powercfg - H size 50"
Skompresira odtis oz velikost hiberfil.sys za 50%.
Hibernacijo lahko vklopis/izklopis tudi preko cmd z ukazom " powercfg.exe /hibernate on" oz " powercfg.exe /hibernate off"
We are fine without wings.
- spremenil: PacificBlue ()
k4vz0024 ::
Dobim odgovor
C:\Windows\system32>powercfg -h /size 50%
Kaj javi ?
powercfg /a
https://rawinfopages.co.uk/windows-wont...
powercfg /h /type reduced
Kaj javi ?
The status code 0xC000007F means STATUS_DISK_FULL
Bios na default nastavitve ?
Katera matična plošča ? Bios posodobi.
powercfg /a
Another option is to configure hibernate to use less disk space. There are two size settings for hibernate, full and reduced and if disk space is limited, use the reduced size. Return to the command prompt and enter:
Kaj javi ?
Hibernate
- spremenilo: sbawe64 ()
k4vz0024 ::
Objavi HW, predvsem seznam vseh diskov, vseh particij in njihove zasedenosti.
Compute: Medion Akoya E6424 MD99850
Sistemski disk C: SSD PHISON 128GB PS3109-S9, prosto 4.7 GB pagefile nastavljen na 4000-6000 MB
Second disk: TOSHIBA MQ01ABD100 1TB, Particija D: prosto 80 GB/870 GB, E: 2.8 GB/60 GB.
Pred deinstalacijo MS z RevoUnistalerjem je hibernacija delovala, kljub 3 GB prostora na sistemski particiji.
k4vz0024 ::
Kaj javi ?
powercfg /a
Kaj javi ?
Hibernate
Standby (S3)
Standby (S1)
Standby (S2)
Hibernate
Hybrid Sleep
Fast Startup
Standby (S3)
Standby (S1)
Standby (S2)
Hibernate
Hybrid Sleep
Fast Startup
C:\Windows\system32>powercfg /h /type reduced
Unable to perform operation. An unexpected error (0x65b) has occurred: Function failed during execution.
Computer Medion Akoya E6424 MD99850
Pred deintalacijo MS Edge z RevoUnistallerjem, je hibernacija deloval zgolj s 3 GB prostora na sistemski particiji. Očitno je Revo pobrisl nekaj kar je pomebno za hibernacijo. Morda v registru ali kako sistemsko komponento.
Ales ::
Kar je očitno je, da OS pride do zaključka, da nimaš dovolj prostora na particiji. Lahko iščeš vse možne "rešitve", ali pa poskusiš dejansko rešitev, ki je v tem primeru očitna.
V vsakem primeru delaš z nekje 4% prostega prostora, kar ni priporočljivo. Ali sprosti konkretno več prostora ali pa imej v mislih, da so SSD-ji, nekajkrat večji od 128GB, že na pol zastonj.
k4vz0024 ::
Aleš, sem imel v mislih, da nabavim večji SSD. Nabavil bom USB zunanje ohišje, v katerega bom vstavil M.2 2880 SSD in migriral celoten sitem. Potem pa odstranil starega in upal, da bo migracija sistema uspela.
Bojim se le, da sem z RevoUninstalarjem z odstranitvijo MS Edge odstranil tudi vse vnose, ki so povezani s hibernacijo.
Skrb je povezana s:
A device attached to the system is not functioning. Zakaj trdi, da priklopjen disk ne deluje, ko pa je chkdsk pokazal, da je disk brez napak. Prav tako integriteta sistema.
Glede migracije sem mislil na dupliciranje starega SSD na novega.
Skrb je povezana s:
Ales ::
Skrb je povezana s:
Te napake so dostikrat generično napisane. Pokrivajo lahko celo vrsto vzrokov, zato jih ne dobesedno jemat. Komot lahko izvira iz tega, da ni dovolj placa, lahko je pa tudi kaj tretjega...
Svetoval bi ti, da na novo namestiš sistem, ko boš menjal SSD. Tako boš siguren, da ne vlečeš kako sistemsko težavo za sabo.
k4vz0024 ::
Ironija je, da je vsa ta leta računalnik deloval brezhibno.
Šele s popolno odstranitvijo MS Edger se je pojavila ta resna napaka. Vse ostalo dela BP in kar jaz potrebujem, je informacije da preverim kaj manjka v registru ali Windows komponente.
Da odpravim napako, ki javlja:
inštaliraj ms edge nazaj
mihagr ::
kako si pa odstranil ms edge? menda nisi brisal map in ostalih datotek? če si že to delal si ga krepko polomil, moral bi iti v nadzorno ploščo, dodaj/odtrani programe, dodaj/odstrani windows komponente in poiskati explorer/edge in klikniti na kvdratek, da je prazen, potem pa ok.
moja napaka. nadzorna plošča, programi in funkcije, vklop ali izklop funkcij sistema windows.
- spremenilo: mihagr ()
mihagr ::
videl se tudi, da imaš sam 4gb prostora na disku c:. pravilo je takšno, da je lepo imeti dvakrat toliko prostega prostora na disku kot imaš fizičnega pomnilnika. torej 16gb pomnilnika, 32 gb prostora. nič čudnega, da se windowsi upirajo karkoli narediti.
ne glede na pomnilnik, je dobro imeti toliko prostora tudi zaradi posodobitev in še nekaj drugih stvari.
k4vz0024 ::
Revounstaller je odstranil vse kar si navedel!
Revounstaller je odstranil vse kar je povezano z Edge. Od vnosov v registru do datotek!
Ja je polom. Ampak se mora na nek način popraviti. Saj test sistema kaže da integriteta ni prizadeta. Vi progami delajo normalno. Sploh pa kaj ima MS Edge s nastavitvami hibernacije?
k4vz0024 ::
Pred odstranitvijo sem napravili system restore point, ki pa se ni uspešno izvedel.
Pa kaj huđiča ima Edge za posegati z nastavitve za hibernacijo?
Iz registra se je odstranilo 2500 vnosov! Ker sem potreboval prostor sem ukazal naj izbriše vse datoteke povezane z Edge! Zakaj bi morale delati šaro na particiji.
očitno ti je uninstaler pobrisal še mnogo več kot samo edge.
če hočeš okrnjeno verzijo, potem si vzami windows tiny edition.
k4vz0024 ::
WizzardOfOZ je izjavil:
Ja saj v tem je najbrž problem. Kako ugotoviti in nadomestiti manjkajpče?
windows dvd in update sistema
še boljše pa nov disk in nov install windows 10. serijske ne rabiš, ker je že registriran.
- predlagal izbris: k4vz0024 ()
Naredi 'Repair Install' (podatki& nastavitve bodo ostali)
https://www.tenforums.com/tutorials/163...
S tem bo tudi Edge nazaj.
Postopek je uporaben tudi v primeru, ko sfc/dism ne more popraviti napak.
Revo Uninstaller ni naredil varnostne kopije vsega, kar je pobrisal (da lahko restoraš če je pobrisal preveč) ?
k4vz0024 ::
Kako updajtat sistem, ki je ena od začetnih verzij Win 10? Sedaj sistem javlja, da update ni mogoč. Sistema nisem posodabljal, ker je bil SSD enostavno premajhen. Kljub temu je prišlo do sedanje situacije, da je zgolj 6 GB prostora na disku.
Sem pa nabavil 1 GB m.2 SSD, ki ga bom dal v zunanje ohišje in priklopil na USB.
Kateri program je najprimernejši za cold duplikacijo sistema oz. Celotnega SSD na večjega?
Je to podobno kot so poznali XP-ji, kjer so se obnovile sistemske datoteke, na instalirane programe pa ni vplivalo?
zakaj kompliciraš? imaš 1gb disk in ga daš v računalnik, pa windows na novo inštaliraš.
k4vz0024
Da.
Podatki& nastavitve ter nameščeni programi bodo ostali, preverjeno letos na w10 22H2.
Catch je samo v tem, da potrebuješ isti Windows build/verzijo iso kot imaš nameščenega, drugače repair install ne dela.
Da.
k4vz0024 ::
Zato, ker imam instaliranih 500+ programom. Da ne omenjam kopico perifernih naprav.
darkolord ::
Macrium Reflect Free uporabi za kloniranje. Link direkt na Free verzijo 7.
Mimogrede, si nabavil pravi SSD? Pomoje tvoj laptop podpira samo SATA M.2 in ne NVMe ...
jih boš pa še enkrat inštaliral.
Bezukhoff ::
Lesson learned za vnaprej, kakršenkoli poseg v sistemske datoteke, in ja, brskalnik je integriran v OS, ima določene posledice.
k4vz0024 ::
Ali Macrium Reflect Free omogoča cold kloniranje?
Sem nabavil SATA M.2, ki ni NVMe, ampak še ta star B+E oz. pazil, da je starejša verzija. Upam, da bo delal, ker uradno je preizkušen 512 GB. Ker pa je drugi klasični disk HD v velikosti 1 TB, sklepam, da bo tudi M.2 1 TB delal oz. ga bios podpira.
Pa se ti zavedaš koliko ur dela je to? Jaz sem to počel počasi 6 let. Razen hibernacije sistem začuda presenetljivo dobro dela. Je pa spucan vsake MS telemetrije. Tako, da že odstranjevanje MS spyware traja! Rajši ostanem brez hibernacije!
darkolord ::
S temle updejtaš na zadnjo verzijo: https://www.microsoft.com/sl-si/softwar...
Z Macrium Reflect pa narediš hot clone, zakaj bi delal cold?
k4vz0024 ::
Cold clone je veliko bolj zanesljiv, saj se napravi klon, ne da bi na to Windows imeli vpliv. Je zanesljivejši, ker gre pri hot kloniranju lahko kaj narobe zaradi vpliva Windows. Pri cold ima na razpolago več pomnilnika in je s tem hitrejši.
Včasih sem uporabljal Ghostery z cold načinom za image sistema in vedno mi je uspelo restavrirati delujoč sistem tudi na drug disk, ne da bi ga priključil neposredno.
Sem poskusil s Acronisom pa je restavrirani sistem javljal neznano napako pri zagonu.
Sem že kloniral sistem, vendar restavrirani sistem javlja v pojavnem oknu, da sistem ni originalen, čeprav je OEM. Sicer ni opozorila v statusni vrstici, ampak vsakih nekaj ur se pojavi okno, da sistem ni originalen. Gre za Win 7 64x Home. Problema do danes nisem uspel odpraviti.
Ali imajo Win 10 tudi težavo s prisotnostjo, ko se zamenja HD?
debloat windows 10 - skripte, ki ti vse počistijo:
https://github.com/W4RH4WK/Debloat-Wind...
Daš nov disk notri, inštaliraš na novo, očistiš z debloaterjem in na novo vse inštaliraš.
darkolord ::
Cold clone je veliko bolj zanesljiv, saj se napravi klon, ne da bi na to Windows imeli vpliv. Je zanesljivejši, ker gre pri hot kloniranju lahko kaj narobe zaradi vpliva Windows. Pri cold ima na razpolago več pomnilnika in je s tem hitrejši.Macrium naredi VSS Snapshot, tako da spremeba datotek med kopiranjem ne vpliva na kopijo.
Hot clone je ponavadi hitrejši, ker kopira samo zaseden prostor in ne celega diska, poleg tega lahko preskoči nepotrebne datoteke/mape. Cold pa odvisno od produkta.
Pomnilnik s hitrostjo kopiranja nima veze, razen če ga imaš res premalo.
ziggy42 ::
Pri meni je gumb na ohisju racunalnika ze nekoliko nezanesljiv in pride prav moznost bujenja preko tipkovnice ali miske, zakar pa je potreben ali nacin spanja ali hibernacija.
k4vz0024 ::
Ali updejti Win 10 kaj bolj obremenijo procesor in odzivnost sistema?
Gagatronix je izjavil:
Zakaj se sploh jebes s hibernacijo ? To je navadno govno.
Kaj predlagaš namesto hibernacije, da mi ne bo potrebno znova in znova odpirati 30+ pdf dokumentov in iskati v besedilu, kje sem naslednji dan ostal?
Word se vsaj zapomni nazadnje mesto pisanja.
Da ne omenjam nalaganje več kot 100+ zavihkov v broserjih!
Predlagaj rešitev!
k4vz0024 ::
Ali ima Macrium Reflect Free kakšno omejitev pred plačljivo verzijo?
k4vz0024 ::
Ali s posodobitvijo starih Win 10 na najnovejšo verzijo kaj izgubim na hitrosti delovanja sistema in njegovo odzivnostjo? Glede na to, da procesor ni nek super duper hiter.
| » | Hibernate ali sleep modeOddelek: Pomoč in nasveti | 4092 (3787) | Lonsarg |
| » | Win 7 - rabim prostor na SSDOddelek: Pomoč in nasveti | 2411 (2196) | Cveto |
| » | Can t come out of hibernationOddelek: Pomoč in nasveti | 2131 (1883) | zvocnik |
| » | C-disk se mi sam polni ???Oddelek: Pomoč in nasveti | 12052 (11147) | cookyx |
| » | Računalnik noče zaspatiOddelek: Pomoč in nasveti | 7113 (6609) | opeter |
