Forum » Problemi človeštva » Imigrantski val 2.0
Imigrantski val 2.0
Kayzon ::
>The European Parliament just voted in support of the EU’s new Migration Pact.
>It will take away national sovereignty from member states & allow the European Commission to allocate any size of “mandatory migrant relocation quotas” for all states
>420 MEPs voted for the Migration Pact while 130 MPs were against.
>The Parliament only added some changes to the text that will make it even easier for asylum seekers to enter and stay in the European Union.
>Voting will also have to take place in the Council of the EU and the European Council before the Migration Pact becomes law.
>As the EU pushed through qualified majority voting in 2015 on migrant relocation quotas, the same system will be used now.
>The European Commission’s plan is to push through the Migration Pact by February, before the European Parliament elections.
>QMV means that a large coalition of states would have to oppose it for it not to pass.
>A veto by one or a few states (Poland & Hungary) won’t be enough.
Veselim se prihajajocih zdravnikov in inzenirjev
- zaklenil: bluefish ()
Avenger ::
Brez skrbi, vsak od nas ima še nekaj prostora v hiši/stanovanju, ali pa celo ekstra hišo/stanovanje, v prvem primeru boste lahko z odprtimi rokami sprejeli tistega inženirja, v drugem pa kar celo družino!
Eni smo to že naredili. Pred več kot desetletjem.
Tile inženirji iz 2015 so bolj malo pomagali, Fachkräftemangel ostaja in se veča !
Tudi wir schaffen das se več ne sliši.
- spremenilo: sbawe64 ()
FrRoSt ::
Glejte.
Lahko se hecate, kakor hočete, vendar ljudi primanjkuje! Ne samo dohtarjev in inžinurjev, tudi natakarjev, kuharjev, vojakov, strežnikov v domovih za ostarele in vse ostalo! Smo trenutno v BALONU!
Morda se prišleki ne bodo izučili, njihovi otroci pač lahko postanejo zdravniki in vse ostalo.
komu zvoni; zvoni tebi.
Pa bomo sploh še rabili toliko doktorjev in inžinirjev zdaj, ko imamo AI?
- spremenil: Miki N ()
Vanich ::
Saj imate sedaj potrjeno še vizno liberalizacijo za Kosovo*. Samo iz tega naslov lahko pričakujete najkasneje do 01.01.2024 kakšnih 500.000 migrantov. Kaj več jih pa itak ni tam dol.
PrihajaNodi ::
Samo ženske muslimanke oz tudi moške samo je fino da se čimbolj zmeša. Islam je religija Miru!
#OstaniDoma
#StaiAcasa
#SpikajmoSEvsi
#StaiAcasa
#SpikajmoSEvsi
- spremenilo: PrihajaNodi ()
-puhek- ::
PrihajaNodi je izjavil:
To je pribljižno kot bi rekel, da je katolicizem religija miru. Oksimoron pravzaprav.
PrihajaNodi ::
Jaz bi raje sicer pakistince, filipinke, tudi turki so ok.
Vaška dekleta hočejo še denar, tega pa pri njih ne bo veliko. Prej bi bilo fino če bi kakšen vaški janez dobil kakšno pridno delovno dekle ki mu pomaga pri kmečkih in gospodinjskih opravilih.
#OstaniDoma
#StaiAcasa
#SpikajmoSEvsi
#StaiAcasa
#SpikajmoSEvsi
Socrates ::
Eno čisto realno vprašanje. Če so migranti tako fajn, zakaj so njihove domovine tako v pizdi?
Narod funkcionira tako dobro, kot ima dobre ljudi. Če so ljudje koruptivni, leni in se niso pripravljeni učit, je tudi država takšna. Velja seveda tudi za Slovence. Ko gledam karakter Slovencev in kako funkcionira slovenska država, mi je čisto jasno, da gre samo za odraz naše mentalitete, delavnosti in (manjka) inteligence.
Ko vidim mentaliteto Švicarja ali Nizozemca, mi je jasno, zakaj imajo oni produktivnost x2 napram nam. Ko vidi mentaliteto Šveda mi je jasno, zakaj zdravstvo tam funkcionira. In ko sem videl mentaliteto Afričanov mi je postalo jasno, zakaj živijo brez kanalizacije.
Mac Mini, 4x3.2 GHz + 4x2.064 GHz, 8 GB LPDDR4X, 256 SSD. Ventura.
Seveda drzava nima nic pri tem, da je koruptivna in zelo neposlušna, da bi imel delavec kaj več od socialca.
enemon ::
Mogoče (upam) bo to pospešilo njihovo pot iz Slovenije v bolj razvite države EU, saj se bodo lahko prosto šetali znotraj schengena.
Socrates ::
IL_DIAVOLO je izjavil:
Država so ljudje, ne moreš okrog tega dejstva. Ni država koruptivna, ampak ljudje. Država je abstrakten pojem.
Recimo Slovenci smo mamini sinkoti, ki pričakujemo od države, da nam bo nadomestna mati. Zato se država vtika v vse pore našega življenja. Celo v to katere medije bomo poslušali in katere filme se bo snemalo (financiranje).
Američani so recimo settlerji, ki so se morali nekaj stoletij zanašati samo nase in na svoj pogum. Originalni settlerji so celo bežali pred vplivom države, ki jih je preganjala. Zato hočejo čim manj države in čim več svobode.
Afričani so klanski ljudje, ki načrtujejo 5 minut vnaprej. Zato tam politiki pokradejo denar, ga razdelijo svojemu plemenu in sorodnikom, potem pa iščejo 1001 način kako zaslužiti še več. Ko se drugo pleme temu upre, se začnejo streljati.
Je zanimivo gledat kako bo Evropa uničila samo sebe. Pa niti svetovne vojne ni potrebne. No kakorkoli, bosta pač Amerika in Kitajska še bolj properirali na naš račun.
PovemVfaco ::
Ej, mamin sinko, največji in pravi settlerji so zdaj Afričani (v prihodnosti pa še bolj), bežijo ne samo pred svojimi skorumpiranimi državami, ampak še pred čim hujšim - in so še večji ljubitelji svobode od zavaljenih krvosesov čez lužo, ki so se sposobni selit samo pred lokalni fast food s klovnom gor, vidim da ti je v resnici afriška mentalitieta kar blizu, ko za trenutek nehaš jamrat in začneš filozofirat. Je že čas za malo zaspinat, da so mamini sinkoti boljši od settlerjev, ali še ne?
cias ::
Temu ne bi rekel samomor ker v demokraciji nimamo pravice voliti ali smo za ali proti. Pa tudi če bi imeli referendum, Slovenci dobro vemo kako se to upošteva ko se gre za "človeške pravice". Spij en Bud light in malo razmisli.
fulk ::
Jaz obtožujem tiste, ki so ultra pro migracije, da izvajajo genocid nad evropejci. Nakar mi odgovorijo, da "kakšen genocid, hur hur, ženske so se same odločile ne imeti otrok, hur hur, to ne more biti genocid, hur hur".
Moja replika:
Stockholm syndrome @ Wikipedia
Če ugrabljena žrtev eventuelno ponotranji posiljevalčevo racionalo in "svobodno" razširi noge ob naslednjem posilstvu, to ne pomeni, da posiljevalec ni več posiljevalec. To zgolj pomeni, da jo je še psihično zlorabil.
Identično situacijo imamo mi. Posiljevalci (pleme ki si lasti netflixe, novičarske portale, glasbeno industrijo itd.) nam (našim ženskam) dnevno vceplja v glavo, kako naj se avto-kastriramo.
To JE mehki genocid. Psihično zlorabit nekoga v samomor. V tem primeru celotne nacije.
Ko se posiljeni začne spraševati, kaj se mu dogaja
https://www.bbc.com/news/world-europe-6...
Posiljevalec ga hitro nazaj popravi.
"Ni zamenjave", "to je le teorija zarote", "to je dobro za družbo", "naša prihodnost".
Moja replika:
Tipicen rasistek:).
Taksne bi z veseljm, ze ob spocetju, steral v skorumpirane drzave v razvoju, da vidimo kak bi se obnesli.
Kar se tice migracij, stepajte otroke, ce jih ne, bodo drugi naselili ozemlje. Kar se mene tice, nobene skode.
- spremenilo: tikitoki ()
fulk ::
Kaj točno neresničnega je povedal?
Država so ljudje. Takšni kot so ljudje takšni bodo politiki in takšna bo država.
Razlika je samo v tem, da meni je kar všeč v sloveniji. Nismo kot albanci, kjer vlada divjačina, ampak tudi nismo zategnjeni skandinavci, ki proslavljamo, ko nam musliman posili ženo (khm, partnerico, da bom moderen).
Socrates ::
PovemVfaco je izjavil:
Afričani, ki kolonizirajo Evropo, niso settlerji. Settlerji so ljudje, ki naselijo neko območje na novo. Američani so prišli v Severno Ameriko leta 1620, ki je bila praktično prazna, saj so bolezni, ki jih je prinesel Kolumb dobro stoletje prej, pobile cca. 90 % prebivalstva. Mimogrede, Ameriški Indijanci so bili večinoma kamenodobna kultura. Praktično vse kar je trenutno v ZDA so ustvarili Evropski priseljenci.
Afričani pa prihajajo v Evropo ravno zato, ker smo razviti. Oni so diametralno nasprotni od settlerjev. Oni bi lahko razvili Afriko, pa pridejo raje v že razvito in bogato Evropo. Kjer računajo na lagodno življenje z čim manj dela. Skratka, delujejo v skladu z svojo mentaliteto, ki jim v matičnih državah tako škoduje.
In prav si povedal, bežijo iz totalno skorumpiranih držav. Ampak sebi ne morejo ubežati in to korupcijo prinašajo s sabo. Če naseliš Afričane v Evropo, bo Evropa pač postala bolj Afriška. Kdor si želi tega za sebe in svoje potomce, je po mojem mnenju malo trčen.
Ampak hej, dandanes je normalno biti trčen. Ljudje ne ločijo več med žensko in moškim, tako da me ne čudi.
Tebi ocitno niso osnove janse. Americani so izvedli nacrtn genocid. Tko, k ga trenutno izvjajo izraelski "settlerji". To, da se delas, da domorodcev ni, jih pobijas in izzenes na nerodovitna obmocja, ne pomeni ,da ni bilo ozemlje ze poseljeno. Pol pa se pravljice, da si s tem naredil dobro delo.
Socrates ::
Čakaj malo. Živim v Sloveniji, ki je v 20. stoletju doživela dve krvavi in brutalni svetovni vojni, fašistično zasedbo primorske, komunistično diktaturo in potem še vojno za osamosvojitev ter tranzicijo. A ni to dovolj brutalno? Imel sem cel kup sorodnikov, ki so v vojni izgubili ude, ki so jih postrelili, ki so bili ranjeni, ki so bili taboriščniki, ki so stradali, ki so šli še mladoletni v hosto, ki jih je zasliševala tajna policija. Slovenca je v prejšnjem stoletju tepel, vsak, ki je imel 5 minut časa. Od vseh sosedov, fašistov, nacistov pa do domačih revolucionarjev.
Malo pozabljate lastno zgodovino. Sodobna zgodovina Slovenije je bila jebeno jebena. Pa smo kljub temu uspeli ujeti priključek z najbolj razvitimi državami.
Vzhodnoevropejce je pojebal Hitler, pa še Stalin. Vojne, lakote, genocid, gulagi, na desetine milijonov mrtvih. Ni bilo vzhodnega Slovana, ki ne bi trpel večino 20-tega stoletja. Pa so kljub temu poslali v vesolje najprej satelit, potem pa še človeka.
Številne evropski narodi so imeli precej bolj jebeno zgodnovino kot številni Afriški, pa so prvi še vedno nekaj dali svetu, drugi pa ne.
Socrates ::
Neumnost. Ko so se Pilgrimi zasidrali v zalivu Massachusettsa, so bile obale popolnoma prazne. Razlog je bil v tem, da so domorodce pobile bolezni:
https://www.ncbi.nlm.nih.gov/pmc/articl...
Severna Amerika je bila izjemno redko naseljena in večino teh ljudstev so pobile bolezni, proti katerim Indijanci niso bili odporni. Nekateri viri navajajo, da so bolezni pobile kar 90 % prebivalcev obeh Amerik:
https://www.pbs.org/gunsgermssteel/vari...
Moderni zgodovinarji pozabijo povedati, da so veliko večino Indijancev pobile bolezni. Le zelo majhen del pa jih je umrlo v boju z settlerji. Velik delež Indijancev pa se je integriral v novo Ameriko.
Kakorkoli obrneš, so Američani zaradi demografske in tehnološke premoči popolnoma prevladali nad Indijanci. To je zelo pomembna lekcija za Evropo. Če bomo dopuščali migracije iz Afrike, se nam zna zgoditi podobno, kot Ameriškim Indijancem.
Ampak eni itak pravite, da vas to ne moti. Dvomim, da se zavedate, kaj govorite. Indijance je zelo prokleto zmotilo, da so izgubili svoj kontinent.
- spremenilo: Socrates ()
tomlin ::
Odlično si tem tumplekom razložil, samo ne verjamem, da bodo razumeli, oziroma nočejo razumeti.
M. Friedman
M. Friedman
Kayzon ::
Se strinjam,lepo napisano. Ne razumem kako lahko sami sebe sovrazijo evropejci,ko ce pogledas realno sliko,smo glih mi gonilo civilizacije in napredka.
Kaj ti res najbolj osnovne stvari niso jasne? Ce ne bi bilo indijancev, ne bi bile mozne vojne z njimi.
American Indian Wars @ Wikipedia
Pravljice o integraciji indijacnev pa zivijo zgoljv v glavi cepcev, ki verjamejo v karkoli.
https://www.fmprc.gov.cn/mfa_eng/wjdt_6...
Kayzon ::
Nedolzni indijanci am i right?
So intimidating was Comanche cruelty, almost all raids by Indians were blamed on them. Texans, Mexicans and other Indians living in the region all developed a particular dread of the full moon — still known as a ‘Comanche Moon’ in Texas — because that was when the Comanche came for cattle, horses and captives.
They were infamous for their inventive tortures, and women were usually in charge of the torture process.
The Comanche roasted captive American and Mexican soldiers to death over open fires. Others were castrated and scalped while alive. The most agonising Comanche tortures included burying captives up to the chin and cutting off their eyelids so their eyes were seared by the burning sun before they starved to death.
Contemporary accounts also describe them staking out male captives spread-eagled and naked over a red-ant bed. Sometimes this was done after excising the victim’s private parts, putting them in his mouth and then sewing his lips together.
One band sewed up captives in untanned leather and left them out in the sun. The green rawhide would slowly shrink and squeeze the prisoner to death.
T R Fehrenbach quotes a Spanish account that has Comanche torturing Tonkawa Indian captives by burning their hands and feet until the nerves in them were destroyed, then amputating these extremities and starting the fire treatment again on the fresh wounds. Scalped alive, the Tonkawas had their tongues torn out to stop the screaming.
A so to pravljce, k jih napisejo zavojevalci po uspesni izvedbi genocida? Nekako tko, k zionisti, kjer dokazano izvajajo etnicno ciscenje in naseljevanje zavojevanega ozemlja, in njihove pravljcie o groznih palestniskih otrocih s fracami, ki jih morajo postreliti ostrostrelci?
Sicer pa smo sedaj sli od pravljic o izmurtih indijancih, ki so jih pobile neznane bolezni, do groznih indijancev, ki jih je bilo treba iztrebiti zaradi grozodejstev:). Rasistki res hitro spremenite vižo.
Socrates ::
Ne razumem, odkod takšno sovraštvo nekaterih Evropejcev do samih sebe? Ste zaužili preveč mikroplastike in imate zdaj mikropenise in porušeno hormonsko ravnovesje? Ker to ni normalno razmišljanje. Nisem srečal ne Azijca, ne Afričana, ki bi razmišljal tako abotno. To je nek bug Evropejcev.
Točno veste, kaj se je zgodilo Indijancem. A vendar želite odpreti vrata migracij v Evropo. Da se bo Evropejcem zgodilo enako kot Indijancem. Kje je tu logika?
Leta 2100 bo 4 milijarde Afričanov in 400 milijonov Evropejcev. Indijance je v Severni Ameriki uničil totalen demografski pritisk priseljencev. Ti so rabili zemljo zato so na koncu Indijance pregnali v rezervate. Demografski imperativ. In ker settlerji preprosto niso hoteli imeti za sosede raznih bojevitih plemen, ki so ropala in mučila po njihovih naselbinah. Oboje je bil razlog, varnost in zemlja.
Afriška populacija bo v prihodnjih desetletjih eksplodirala. In če bomo pustili, da migrirajo k nam, bomo šli po poti Indijancev. Samo način bo malo drugačen.
Ampak ko bodo demografsko prevladali, bo tako kot v Južni Afriki. Od cvetoče države, ki je prva na svetu presadila srce in razvila jedrsko orožje, do tega kar je danes. Nasilna, korumpirana država, z dnevnimi večurnimi izpadi elektrike. Kjer se ljudje sploh ne ustavljajo pri rdeči luči, ker je prenevarno. Južna Afrika ima 100x več umorov na 100.000 prebivalcev kot Slovenija.
Tega si kavč socialisti sploh ne znate predstavljati. Kaj pomeni živeti v 100x bolj nasilni družbi, kot je naša. Takrat bodo čakalne vrste za operacijo nožnega palca vaša zadnja briga.
Jaz mislim, da ste kavč socialisti razvajene riti ki se ne zavedate, kaj imate. In nimate pojma, da gre civilizacija zelo hitro v franže. Blebetate neumnosti, ker hočete izpasti woke, ampak se ne zavedate posledic. Niste se sposobni zavedati posledic, ker se vam v življenju še ni zgodilo nič slabega.
Nihče vas še ni oropal tako, da bi vam prislonil pištolo na glavo medtem ko se sprehajate po Tivoliju. V trgovini vam ni treba delati za neprebojnim steklom, ker vam nihče še ni nič hudega storil. Nikoli vas niso zavrnili na razgovoru za službo, ker morajo zaradi raznolikosti vzeti manj kvalificiranega kandidata druge rase. Nobena od vaših sorodnic ali prijateljic ni bila skupinsko posiljena, ker se je ponoči vračala domov čez napačno sosesko. Itd. itd. itd.
Vi živite v eni pravljici, ki se ji reče Slovenija. Ampak ta pravljica se lahko zelo hitro konča. Samo kritično maso bedakov rabimo, potem pa bo čas naredil svoje.
PovemVfaco ::
Spet ti možgani napol trokirajo. Povampirjena kapitalistična Evropa prazni samo sebe, zato seveda Afričani tudi po tem kriteriju so settlerji, naseljujejo ta prazen prostor, ki nastaja, svobodoljubni pa so seveda tudi, še bolj od zavaljenih gospodarjev, ki so te sprogramirali v trokiranje.
PovemVfaco ::
Proti vsakemu kavčarskemu zahodnjaku, ki se komaj premakne iz domačega sela do bližnje pisarne, pa še to samo lastni v dvotonski konzervi, je ilegalno prečkanje EU meje višek settlerstva in tudi iniciative.
- spremenil: PovemVfaco ()
PovemVfaco ::
Ej, rit razvajena, ki misliš, da se pa tebi v neki prazni slovenski vasi to vsak dan dogaja, ker videoigrice preveč špilaš: veš komu se to res dogaja? Afričanom npr. Da kot ameriški sprogramiranec nisi sposoben individualističnega pogleda na stvari, ampak sam kolektivističnega, pač veliko pove o tvoji omejenosti.
Tebi pa okol glave granate letijo vsak dan, ker se boriš v Sudanu, pravljičar.
PovemVfaco ::
ZDA pa 10x več umorov od Slovenije. Zgleda, da tako južnoafriškim kot ameriškim settlerjem marsikaj ni jasno. Glede varnosti se lahko zgledujejo po Sloveniji ali pa Gvineji Bissau in Burkini Faso v Afriki.
Zigerion ::
To da hoče EU vsilit neko skupno politiko migracij je nonsense. Migrantsko politiko vodijo interesi po poceni delovni sili, ki je v Nemčiji, Italiji, Franciji primanjkuje. Jebe se njim ali so to ekonomski ali vojni migranti, samo da za malo cekinov opravljajo dela, ki jih drugi več nočejo. In potem te države pod pretvezo solidarnosti vsiljujejo takšne in drugačne akte..
Na primer Danska velja za eno najbolj progresivnih EU držav ima pa mogoče celo najbolj restriktivno politiko do migrantov. Kako gre to skupaj?
Maxlos ::
Vprašaj palestince, ti bodo povedali da rjavosrjačniki ravno niso religija miru.
Sej nočeš pucati WC-ja. No razumeš v kotekstu delovnega mesta, kot smo imeli "čefurji Raus" pa nihče ni hotel opravljati njihovega dela.
Barking up the wrong tree
- spremenilo: Maxlos ()
Aha, prvo ga bomo nekaj let futrali, potem pa izgnali.
Socrates ::
@ povemVFaco,
iskreno, ne vem če se splača odgovarjati na tvoje nebuloze. Večina tega kar izjaviš je ravno obratno od resnice. In če sovražiš samega sebe, tudi ne verjamem, da te bodo neki argumenti prepričali. Gre za globlji psihološki problem.
Ampak na hitro, za vse ostale, da ne bodo nasedali najbolj banalnim neumnostim:
- Evropa je eno najgosteje poseljenih območij na planetu. Afrika eno najmanj poseljenih območij na svetu. Migranti torej ne silijo v izpraznjeno Evropo, ampak v eno izmed najgosteje poseljenih območij na svetu. Moraš biti velik bedak, če trdiš da je Evropa prazen prostor.
List of countries and dependencies by population density @ Wikipedia
- produktivnost v Evropi je več kot 10x višja, kot produktivnost v Afriki. Moraš biti velik bedak, da poimenuješ Evropejce za kavčarje.
- Afričani pridejo v Evropo tako, da se v Libiji vkrcajo na star čoln, zaplujejo en kilometer od obale potem pa kličejo evropsko obalno stražo. Z ogrožanjem lastnega življenja izsiljujejo ilegalni prihod v Evropo. Moraš biti velik bedak, da to poimenuješ settlerstvo.
- ZDA imajo več kot 10x več umorov kot v Sloveniji. Ampak črnci v ZDA zagrešijo 10x več umorov na prebivalca kot belci. ZDA bi bila brez črnskega prebivalstva in mehiških tolp približno tako varna kot povprečna Evropska država. Poglej si umore po rasah in računaj. Ravno o tem govorim - uvozi Afričane in adijo varnost in mir.
anketar ::
Morajo bit davčne olajšave za podjetja, da vlagajo v proizvodne kapacitete ali storitve v severu Afriških držav, da se tm ustarja ekonomska sila na pa da vsi rinejo v EU.
PovemVfaco ::
Evropa se prazni, stalno je jok, kako evropske vukojebine propadajo, populacija prestara in kako je premala rodnost, sploh določen wannabe grški filozof o tem rad jamra, celo v tej temi že. To bo pač za ponovno posettlat od takih, ki se bolj plodijo, pa če se na napihnjeni rački pripeljejo.
Produktivnost v Evropi je na račun boljše opreme, avtomatizacije in seveda še najbolj nategantskih bluzatorskih panog. Zaradi tega je tudi povprečen Evropejec vedno bolj razvajen, nesposoben in len fachidiot, to vsi vemo, pa če se še tako dereš, da line goes up
In kdo je ameriškim iber pametnim settlerjem kriv, da so si sužnje navozili iz Afrike in da so sami preleni, da bi si sadje obirali, pa jim hodijo Mehičani to delat (in potem še sproti droge prodajat, ker se jih to bolj splača)? Ilegalci so celo najboljši za biznis, ker lahko šefe fajn z deportacijo zagrozi, če kaj ni čist po njegovem. Ali pa Angležem in Nizozemcem ali kaj so, da so rinili v današnjo JAR in se šli neke šefe, dans pa dobivajo po buči? Burkina Faso in Gvineja-Bissau (pa verjetno še kakšna država) v Afriki imata dosti manj umorov na 100k od ZDA, primerljivo z evropskimi državami. Mogoče so bili pri njih manj usekani beli settlerji, ne vem.
| » | Kanadsko prebivalstvo se je prvič povečalo za več kot 1 milijon (Letna rast 2,7%) (strani: 1 2 3 4 )Oddelek: Loža | 38763 (18371) | Mr.B |
| ⊘ | Kako dvigniti populacijo starjoče Evrope? (strani: 1 2 3 4 … 22 23 24 25 )Oddelek: Problemi človeštva | 180408 (154090) | vostok_1 |
