.se domena
.se domena
jernejk90 ::
Zanima me ali bi bila domena .se v Sloveniji enako dobro prikazana v iskalniku kot .si z enako SEO optimizacijo?
Hvala
xseki ::
According to website.com, Your domain extension has no effect on your search results ranking. The only exception is country-code top-level domains, such as .us, .ca and .uk. These domain extensions will significantly affect your website’s ranking on a geographical search level. For example, if you have a .ca domain extension and your users are searching for your website from a Canadian city, then your website will be given a higher placement.
https://www.globalreach.com/global-reac...
Misliš na google.si? Verjetno bo .si pred .se z enako optimizacijo.
Odpiranje PDF z QR
Oddelek: Programiranje
92320 (1756) Ahim
Kontaknti obrazec - potrebujem pomoč
181527 (1249) cobrica
nova domena
Oddelek: Izdelava spletišč
92191 (1966) Groove
IP od subdomene
Oddelek: Omrežja in internet
61859 (1744) OmegaBlue
Filmska industrija gre po poteh glasbene
224060 (4060) Bistri007
