Forum » Problemi človeštva » Podnebni ekstremizem
cvalsr hoče povedati, da moramo pri tem početju ene stvari zanemariti, druge pa poudariti.
Katere stvari točno moramo zanemariti in katere poudariti, bodo on in njegovi določili.
Da bomo dobili jasno sliko, kako bo leta 2100.
Članek iz leta 2011:
The researchers found that the uncorrected temperature data correlated strongly with data on movements of Earth's core and Earth's length of day until about 1930. They then began to diverge substantially: that is, global surface air temperatures continued to increase, but without corresponding changes in Earth's length of day or movements of Earth's core. This divergence corresponds with a well-documented, robust global warming trend that has been widely attributed to increased levels of human-produced greenhouse gases.
But an examination of the corrected temperature record yielded a different result: the corrected temperature record remained strongly correlated with both Earth's length of day and movements of Earth's core throughout the entire temperature data series. The researchers performed robust tests to confirm the statistical significance of their results.
"Our research demonstrates that, for the past 160 years, decadal and longer-period changes in atmospheric temperature correspond to changes in Earth's length of day if we remove the very significant effect of atmospheric warming attributed to the buildup of greenhouse gases due to mankind's enterprise," said Dickey. "Our study implies that human influences on climate during the past 80 years mask the natural balance that exists among Earth's rotation, the core angular momentum and the temperature at Earth's surface."
Since scientists know air temperature can't affect movements of Earth's core or Earth's length of day to the extent observed, one possibility is the movements of Earth's core might disturb Earth's magnetic shielding of charged-particle (i.e., cosmic ray) fluxes that have been hypothesized to affect the formation of clouds. This could affect how much of the sun's energy is reflected back to space and how much is absorbed by our planet. Other possibilities are that some other core process could be having a more indirect effect on climate, or that an external (e.g. solar) process affects the core and climate simultaneously.
https://www.jpl.nasa.gov/news/nasa-stud...
Pa tudi tole je zanimivo:
https://www.sciencedirect.com/science/a...
Zdaj pa se manj ne razumem. EU uporablja "zamazane" panele -> grejo se zeleni prehod. Kitajska uporablja "zamazane" panele -> ne grejo se zeleni prehod.
Se nekaj ne razumem. Katero elektriko iz premoga uvaza Nemcija? To mislis na jedrsko iz Francije? Ali na hidro skandinavsko? Nic vec ne razumem.
Morda mislis Poljsko? Koliko pa so jo uvozili? Znas povedati? Oziroma pozabi. Vse je jasno. Manjkajo ti kolesca, sem se zdaj spomnil.
Si res bolj počasne sorte, a nič hudega, we got you.
Eni se grejo zeleni prehod, drugi pa ne. V katerem primeru si torej hinavec?
Če zapreš svoje JE, da boš bolj zelen in nato uvažaš to manjkajočo energijo iz JE, TE ali drugih fosilnih virov, kaj točno si naredil, razen da serješ drugje kot spiš?
Sparkxl ::
Dajmo se malo o resnih stvareh pogovarjat. EU klima naciji harajo naprej s polno paro
https://www.euronews.com/my-europe/2023...
"Nature restoration" pomeni konkretno zmanjšanje kmetijskih površin in zelo omejeno uporabo pesticidov in gnojil. Lahko pogledate na šri lanko kako se je to izšlo. Pod črto to pomeni konkretno manj pridelane hrane pri nas. To pomeni več uvoza, torej višje cene.
Zdaj pa nagradno vprašanje: kako bomo s tem rešili svet? Opcije so samo 2. Drugi več proizvedejo, da pokrijejo naše potrebe. S tem smo "problem" samo prestavili na drugo lokacijo. Druga opcija pa je, da futer odvzememo drugim. Isto kot smo letos počeli s plinom. Kdor plača več, dobi. Verjetno je jasno da s tem povzročimo lakoto nekje drugje
Saj, kot z zelenim prehodom svinjanje prestavljamo v druge države, sami pa se tolčemo po prsih, češ, kako smo zdaj eko in zeleni, česar kow nikakor ne razume. Vse skupaj je le hinavska farsa.
A lačnega ljudstva se je treba najbolj bat, ker to ne vodi nikamor drugam, kot v konkretno prehransko krizo.
GenZNPC ::
Labeliranje zadev je irrelevantno. Dejstvo je, da se segreva. Pomoje je boljs, da se v tej temi ne oglasas vec. Odpri novo temo.
V tej temi je OP rekel, da se po njegovo pretirava s posledicami. Ni pa zanikal segrevanja.
Seveda se, ampak ne izkljucno zaradi nas, si pozabil dodat.
Tudi brez nas, bi se segrevalo, jebiga. Tudi z vso zeleno E-agendo bodo "podnebni extremi" dan vsakdanjosti.
Prej, ko se boste prilagodili boljse bo. Pravim, ne kupujte parcel tik ob morju za vase pravnuke.
skibidi
feryz recimo ne verjame v statistiko. Predlagam mu, da odpre novo temo z naslovom: "ne verjamem v statistiko - ne vem sicer zakaj".Seveda verjamem v statistiko. Absolutno verjamem.
Še bolj pa verjamem v to, da je statistika zeloooooo prilagodljiva.
Vedno je točno taka, kakršno potrebuješ.
Osnovne statistike: "vsak, ki jo ne razume", trdi da je statistika "zeloooo prilagodljiva".
Aja? Zakaj pa bi se segrevalo in ne ohlajalo? Nestrpno pricakujem odgovor.
Ce te prav razumem, ti serjes tam kjer spis. Genijalno!
- spremenil: kow ()
Predlagam ti obisk Nizozemske. Bolano kako so povsem unicili svojo krajino, da futrajo Slovence ipd. Pocasi bi lahko tudi nehal s svojim rasizmom.
- spremenil: kow ()
Povzetek teme:
- Mato sovrazi clovestvo in pravi, da nam more biti vseeno za nas obstoj
- feryz ne verjame v statistiko
- c3p0 ima tezave z logiko (enako obnasanje eu in kitajske -> razlicni zakljucki)
- molnar se razume v zemljine klimatske razmere in "ve", da se bi se tudi brez clovestva segrevalo
- sparxl ne verjame v termometre
- cool bits informacije dobiva iz daily maila, kar pomeni da je verjetno blizu debilu (v medicinskem smislu)
- pacific blue lima znanstvene linke ne da bi jih prebral
- spremenil: kow ()
GenZNPC ::
To znam tudi jaz, glej:
Zakaj bi se ohlajalo? Se bolj nestrpno pricakujem odg.
Povzetek teme:
Kowa si izpustil, ko ve vse to in se vec !
skibidi
- spremenil: GenZNPC ()
fulk ::
Zmeden sem, da si vsi tako zelo nasprotujete v svojih izjavah. Fulk recimo omenja neko narascajoco podvodno vulkansko aktivnost, nato pa lepi znanstvene clanke, ki govorijo o necem tretjem (napacnem merjenju ipd.)
Vemo v kaj ne verjamete (vsi po vrsti), ampak v kaj verjamete - to bi bilo zanimivo, da napisete!
Sparkxl ne verjame v segrevanje. Rad bi izvedel ali potem verjame v ohlajanje? Morda v staticne temperature? Kdo bi vedel
To ti smo pove, da zadeva še zdaleč ni dorečena, kot trdi vaša stran.
Glede vulkanov in meritev pa je burden of proof na tebi. Ti si tisi, ki želi ljudem prepovedat peči na drva/plin, ne jaz. Jaz zgolj posredujem info, da obstajajo naravni izvori in ponori CO2, ki niso preučeni do tega nivoja, da lahko upravičimo zmrzovanje riti tistega nemca. Jaz ne rabim dokazovat nič, ker zadeve so self evident. Da so "nepomembne", ali "že upoštevane" pa je tvoje delo.
Povzetek teme:
Prav užaljen sem, ker me nisi omenil! To ti zamerim.
- spremenil: fulk ()
Pa sem te res pozabil! Se opravicujem.
Burden of proof je seveda na tebi. Ti trdis, da imamo povecano podvodno vulkansko aktivnost. Jaz trdim, da se segreva zaradi "dodatne izolacije" v atmosferi.
Proof? Lahko si preberes znanstvene clanke, ki jih povzema IPCC porocilo. Hvala!
Jaz nisem rekel, da bi se ohlajalo. Ne rabim zagovarjati neizrecenih trditev.
- spremenil: kow ()
fulk ::
Ok hvala, za popravek.
Sicer pa jaz ne trdim, da imamo povečano vulkansko aktivnost. Trdim, da imamo vulkansko aktivnost, ki je nismo preučili, meritve CO2 pa ne dosegajo znanstvene konsistence, kot bi se pričakovalo za tako dramatično družbeno spremembo.
Ne vem, če se kow zaveda, ker v trenutni geoloski eri (quaternary) je povpprečna koncentraxcija CO2 na zelo nizki ravni. Pod 180 ppm je prakticno ogroženo vsakakrsno življenje na Zemlji. V kambriju je bilo recimo 4000ppm.
fulk ::
https://nakedemperor.substack.com/p/202...
Pohvalno, ampak me sploh ne preseneča.
Moj nateg-o-meter je imel že toliko kalibriranja zadnja leta, da hitro prepoznam, kdaj gre za nateg.
Ko vidiš, da tebi sovražen establišment se na vse kriplje trudi te prepričati/prisiliti v nekaj, veš, da je nateg. Kdo profitira se vedno vprašajte.
In preden rečete recimo generični "američani", "rusi" itd. raje se vprašajte kateri američani in kateri rusi. Joe Average iz Kentuckyja ali Schlomo Finkelstein iz Washingtona DC?
PacificBlue je izjavil:
Steje zadnjih 10k let. Prej smo s sulicami skakali okoli. Me ne zanima. Poleg tega ne gre samo za povprecno koncentracijo, ampak za veliko hitrost povecanja. Ni vseeno ali se bova na 2 stopinji vec prilagajala midva, ali pa postopoma 100 generacij. Verjetno vsaj to zastopis...
- spremenil: kow ()
fulk ::
Predvsem zastopim, da nimate nobenih kredibilnih podlag za take trditve. Najprej se naučite korektno merit CO2 na planetu, pol se lahko pogovarjamo.
cvalsr ::
Uuuu, res? Prav.
Najprej-najprej nas pouči, kako se objektivno korektno (ne po tvoji 'strokovnosti') meri CO2. Torej:
Stotisoči znanstvenikov po svetu tega očitno ne znajo. Proooosim pouči jih, pametnjakovič.
fulk ::
V bistvu se stotisoč znanstvenikov sploh ne ukvarja s tem. Od kje ti ta pravljica?
Kot drugo, tedenske satelitske meritve celotnega planeta bi bile dobrodošle. Jih imamo?
cvalsr ::
Oprosti za pomoto: Globalno segrevanje opažajo čistilke in picopeki ter pišejo pravljice.
Imamo tedenske. Tudi dnevne, urne, večdesetletne...
Čakmau, zakaj se pogovarjam s tako vrhunsko razgledanim osebkom?
Zakaj pa se ne bi
Hoces rect da preden so nastali ljudje da je na zemlji bila konstantno enaka temperatura brez spremembe?????
Uuuu, res? Prav.
Najprej razlozite kako je v najbolj plodnem in zelenem casu jure bilo v zraku vec co2 kot danes in kateri clovek je bil za tisto kriv in razlozi kako ni takrat nic uspevalo
Rastline rabijo co2
- spremenilo: Mato989 ()
Rastline rabijo co2
Jup, CO2, vodo, substrat (nekaj kjer lahko fizicno pritrdijo korenine) ter makro- in mikrohranila. Vecini rastlin je omejujoc faktor rasti nizka koncentracija CO2 ter manjko dusika.
Kdor se ukvarja z akvaristiko, ve, da lahko s pravilnim doziranjem CO2 pospesis rast rastlin za faktor 10 in vec. To je nekaj, kar lahko doma testira vsak. Rast rastlin se umiri, ko koncentracija CO2 pade oziroma ko zmanjka hranil.
Generalno se o tem ponoru CO2 premalo razpravlja. Me zanima, kako racunski modeli upostevajo to. Ker ce ne upostevajo tega, niso vredni racunske moci.
Hitrost rasti je irrelevantna (razen v smislu, da se neobdelano prej zaraste). Steje kolicina biomase, ki nase veze ogljik. Pravo vprasanje je koliko so drevesa (oz. rastlinje) vecja/debelejsa zaradi visje koncentracije CO2.
Gre pa za kompleksno vprasanje, ker je veliko faktorjev.
Naslednje leto:
Biomass (satellite) @ Wikipedia
Ko se pizdite ves cas na IPCC - mislim, da podcenjujete tezavnost njihovega dela. To je jebeni UN komite - birokracija, ki skupaj zlaga vse kompleksno znanje in pac napise neko porocilo. Z vsemi slabostmi in napakami.
Naslednje leto:
- spremenil: kow ()
A je kdo kaj bral pooptv? A bo danes ponovno najbolj vroč dan tega vročinskega vala?
Pozabili smo klimo ugasniti v pisarni in zdaj nas zebe.
Sem šel ven, da bi se malo ogrel, pa je zunaj še bolj mraz.
ARSO:
V državnem povprečju je bil januar 2,5 C toplejši od normale
V državnem povprečju je bil februar 2023 za 0,8 °C toplejši od povprečja obdobja 1991-2020
Marec 2023 je bil v državnem povprečju 1,4 °C toplejši kot normalno,
April je bil 1,4 °C hladnejši kot v povprečju obdobja 1991-2020
Prvi 4 meseci so bili zelo topli. To so pac uradne stevilke, ki jih imamo za letosnje leto. Noro topla prva tretjina leta.
Pomenljivo je tudi, da pricakujete vsak dan cez 30 stopinj, lol. Vidim, da ste se ze cisto privadili na mnogo toplejso klimo.
Zanimivo. Letos se mi je zdel maj precej hladen, potem pa vidim statistiko:
ARSO:
Maj je bil 0.1°C hladnejsi kot v povprečju obdobja 1991-2020.
Pred leti je še oče šel na eko kmetovanje. S sejanjem koruze, rži,... smo končali, ker je pridelek bil slab (samo zaradi trave v posevku), ostali smo samo na krompirju (koloradski hrošči se ročno pobirajo tudi 2x/dan), pa še to bolj za lastno uporabo in zelenjava,... tudi za lastno uporabo. Rastlinsko hrano težje pridelaš brez škropiv, predvsem je je pa manj in slabše izgleda. Ko bo trg za eko hrano, ki je slabšega videza in bodo ljudje pripravljeni za to plačati več, bom pa mogoče prodal kaj na trgu. Sedaj se grem govedorejo, ampak ob takšnem ekofašizmu bodo zagotovo "naglumili" še kakšne omejitve. Bomo pa še to omejili in bo kmetija iz tržne prešla v ljubiteljsko za samooskrbo.
A ne verjameš statistiki?
Verjamem. Ravno to je bila moja poanta. Percepcija vara. Ceprav je bilo veliko dezevja, jutra niso bila hladna.
20 stopinj je mraz? Wow, ti pa si pussy. Vecina ljudi, ki sem jih zjutraj videl so bili v kratkih rokavih.
- spremenil: kow ()
Seveda, ker zaupajo Arsu. Ker je bil včeraj najhujši dan v vročinskem valu. Do 27 stopinj smo prilezli.
Btw, to da se Arso norca iz vremenskih napovedi dela, ni vedno samo smešno. Lahko je tudi z velikimi posledicami.
V Postojni sodelujem pri obnovi bloka. Skupaj z ostalimi izvajalci.
Vsi smo preverjali napoved in računali, da je vsaj malo pravilna. Se pravi, da nas bo prvič napralo v sredo popoldan. Še v torek popoldan je veljalo tako!!!
Zato smo si delo organizirali tako, da smo ponedeljek in torek razkopavali, v sredo pa sestavili skupaj, da bo blok zaščiten.
Kako se je izteklo, pa sami veste. Ok, jaz nimam dosti škode zaradi tega, malo pucanja vode so imeli fantje.
Ampak streharje je pa konkretno najebalo. In zdaj imajo v bloku polno podstreho vode in stanovanja v zgornjih dveh štukih konkretno namočena.
Tako da žreti Arsov drek ni ravno prijetno. Lahko bi vsaj namignili, da lahko pride do neviht.
12 ur prej mater, valjda vejo kaj se bo zgodilo čez noč!? Če že točno vejo, kaj bo leta 2100.
Še dobro da obstajajo zavarovanja. Ker drugače lahko, v takem primeru, mirno bankrotiraš.
So pac nesposobni, kaj naj recem. Nesposobni placajo na trgu dela.
Itak pa ne govorimo o napovedih, si samo zamenjal temo, ko se je izkazalo, da nimas pojma.
- spremenil: kow ()
Če ti taka zadeva ni dovolj zgovoren prikaz verodostojnosti strokovnjakov, potem ne vem, kaj bi ti lahko bilo.
Vernik pač.
Sicer pa hvala k... za podnebne spremembe. Že dolgo ni bilo tako hladno, kot je letos. Glih tapravo je.
Vernik pač.
fulk ::
Naslednje leto:
Bogi UN birokrati. Težek njihov lajf.
Ti si sploh pogledal IPCC poročilo?
Je kot nekakšen slab filemski scenarij.
Drugače pa glede rastlin. Zanimivo, da vsi tej vaši CO2 modeli ne uopštevajo enega glavnih CO2 ponorov.
Rastline tudi če eventuelno nazaj spustijo CO2, še vedno zamaknejo efekt za par 100 let, ker je shranjen v biomasi in ta v divjini razpada počasneje.
Zapomni si, ko establišment tako propagira nekaj...vrjetno te želi nategnit.
https://twitter.com/tansuyegen/status/1...
To pa je retardiranost.
Za to izklesat vn bo rabilo nekaj časa in truda.
Glede na dolg seznam, imaš kar splošne probleme, se je za zamislit. Samorefleksija ponoči, ko ne moreš spat (kar je given), priporočam.
Enako obnašanje, ampak EU se gre nek "zeleni prehod", Kitajska se vsaj ne pretvarja. To je point, ki ga ne razumeš. Če bi EU bila na drugem planetu, bi še šlo.
Amputated ravno ne, koža se olušči, če ne druga. Bosta pa besties en čas. Vsekakor pa izdat račun za obnovo ceste, oviranje prometa.
fulk ::
Nekdo se je spraševal, zakaj pol kitajska inštalira panele:
Kitajski je pomembno, da ohrani nek mednarodni ugled. Zato je podpisnica številnih internacionalnih predpisev o vsem možnem, ampak ko pa gre zares, naredijo po svoje.
Inštalacija toliko panelov je primarno, da lahko kitajska reče pred vsemi, da oni najbolje izvajajo zeleni prehod. V resnici pa potiho gradijo še več premoga.
CCP je velikokrat nekaj obljubil pol pa se izneveril.
Kitajci imajo velike probleme z zelo onesnaženim zrakom, zato inštalacija panelov, gradnja HE, JE,... In ja, tudi TE gradijo, ker imajo veliko potrebo po elektriki.
fulk ::
Smog in TE je problem, če gre za staro generacijo, brez filtrov. Moderne TE skoraj ne izpuščajo trdnih delcev v ozračje.
Je pa res, da kitaji pograbijo vse kar generira energijo.
Spravit dobro miljardo ljudi na nek zadovoljiv standard rabi še in še energije.
V bistvu mi je nasploh nepredstavljivo, kako bo izgledal svet, ko se bodo Indijci, Kitajci in Afrika potegovali za evropski standard. To bo izžgalo luknjo sredi planeta.
Ta stare tudi (postopoma) zapirajo. Gradijo tudi nuklearke. Trenutno jim proizvodnja energije se vedno raste. Vprasanje kdaj se bo sunkovita rast porabe ustavila. Imajo 4x vec prebivalcev kot ZDA in 2x vecjo proizvodnjo. Ker imajo vecjo gostoto prebivalstva pomeni, da v resnici ne rabijo 4x vec elektricne energije kot ZDA za visok standard. Japonska proizvodnja elektrike je 9x manjsa kot Kitajska. Pa se mi dozdeva, da imajo japonci kar dober standard. Pa tudi industrije nimajo malo.
So pa pravkar kitajci imeli rekorden dan. Le zakaj? Ker imajo vrocinski val.
Partija bo na koncu naredila zakljucek, da imajo toliko sus in vrocinskih valov... zaradi emisij. Ironija.
- spremenil: kow ()
fulk ::
Kaj pomeni ne rabijo?
Bo partija določila kje se bo standard ustalil?
Kaj pa afrika. Kako se ti zdi, da vi tisti divji deželi bodo domačini imeli občutek za planet med razvijanjem? A sploh vrjameš, da bodo prišli na naš nivo?
Poraba elektrike je odvisna od industrije. Na prebivalca Kitajci verjetno porabijo precej manj energije za gospodinjstva (vzrok blaginja) kot npr. Usa, veliko pa porabijo v industriji. Japonci imajo verjetno manj industrije pridobivanja primarnih surovin kot Kitajska, zato so lahko "varčni".
In še več vzrokov bi se dalo najti zakaj Kitajci porabijo toliko elektrike.
Ce bi bila toliko odvisna od industrije, bi jim poraba stagnirala, pa jim ne.
Razen, ce pod industrijo jemljes tudi soping center ipd.
- spremenil: kow ()
Kaže, da ti nekaj manjka....
Kitajci imajo v svetovnem merilu veliko "črne" industrije pridelava/predelave osnovnih surovin. EU je mnogo tega izvozila tudi na Kitajsko, ker doma ni več eko sprejemljivo in je energetsko potratno.
GenZNPC ::
Kdo pa je privlekel ohlajanje sem not, ce ne ti?
To so uni japonci, ki zivijo v tiny apartmentsih na 30kvadratih, ker si vec ne morejo privosciti?
Samo sprasujem iz radovednosti.
skibidi
Jaz ga nisem. Ti si trdil, da se segreva ("tudi brez nas, bi se segrevalo, jebiga") v vsakem primeru. Jaz sem samo spraseval kako ves, da bi segrevalo napram ohlajalo.
Kakorkoli, vsi imate enako prepricanje:
"ne zaupam kar mi pravi trenutna ideologija" -> "torej lazejo in velja ravno nasprotno" -> "iscem razloge, novice, raziskave, ki bodo potrdili mojo intuicijo"
Skratka, popolnoma neznanstven pristop. Kar je po svoje razumljivo, saj ste ocitno vsi precej neizobrazeni.
Vam moram res razloziti pravilen pristop?
- spremenil: kow ()
Uporabnik ::
Najprej je bil global cooling, pol je bil global warming, pol pa ko se ni nič izšlo, je pa nastal climate change, ki pa pomeni pol kurca, če imaš možgane.
If You Don\'t Stand for Something, You\'ll Fall for Anything
| » | Izpusti ogljikovega dioksida še vedno rekordni (strani: 1 2 3 4 )Oddelek: Novice / Znanost in tehnologija | 25310 (20179) | kow |
| » | Lani peto ali šesto najtoplejše leto (strani: 1 2 )Oddelek: Novice / Znanost in tehnologija | 13258 (10713) | FoxKnox |
| » | Udarec za podnebne alarmiste? (strani: 1 2 3 4 )Oddelek: Znanost in tehnologija | 42935 (26810) | zmaugy |
| » | Univerza Brown: Podnebni zanikovalci še vedno nesorazmerno visoko zastopani v medijih (strani: 1 2 3 )Oddelek: Novice / Znanost in tehnologija | 30946 (27145) | gruntfürmich |
| » | IPCC: Hitrost globalnega segrevanja manjša, a le po naključju (strani: 1 2 3 )Oddelek: Novice / Znanost in tehnologija | 43383 (33345) | NSA Agent |
