Forum » Programiranje » pascal copy event
pascal copy event
BRBR ::
procedure TForm1.MenuItem30Click(Sender: TObject); var begin Button1.OnClick:= self.OnClick; end;
Zgleda dobro in compiler nič ne jamra, dela pa ne. Kako pripisat izvajanje kode enega elementa enemu drugemu elementu v run time ?
Jure14 ::
Torej ti v runtimu (dinamično) kreiraš gumb, ki bi mu rad določil OnClick dogodek?
Button1.OnClick := @proceduraKiSeIzvedeObKliku;
procedure TForm1.proceduraKiSeIzvedeObKliku(Sender: TObject); begin ... end;
BRBR ::
Da malo popravim opis. Recimo da imam 30 gumbov + enega.
Na tem zadnjem recimo piše: 'repeat last action'
Torej, vsak klik na kateregakoli od onih prvih 30 mora zadnjemu (31), runtime pripisat izvedbo lastne procedure.
procedure TForm1.MenuItem30Click(Sender: TObject); var begin //ne dela ker je self pač form1 Button31.OnClick:= self.OnClick; //dela, samo je fixno, človek pa bi rabil nekaj univerzalnega (za vseh 30 gumbov), predvidevam da preko sender .... //sender nima onClick ... Button31.OnClick:= MenuItem30.OnClick; end;
Gagatronix ::
Tole mi prej deluje kot Delphi, ki je, tehnicno gledano, Pascal ki se pretvarja da zna OOP.
kuall ::
The OnClick method that you have written provides all the information that you
need via the Sender parameter. This is the object which is calling the method
i.e. it is the actual menu item that was clicked. If you cast the Sender
parameter as a TMenuItem you can access all of it's properties e.g.
procedure TForm1.MyOnClick( Sender : TObject );
begin
// Check that the Sender is of the required type.
if Sender is TMenuItem then begin
TMenuItem( Sender ).Caption := 'You just clicked me!';
// Or if you prefer.
with TMenuItem( Sender ) do begin
Enabled := False;
end;
// Or even..
with Sender as TMenuItem do begin
Checked := True;
end;
end;
end;
http://www.delphigroups.info/2/4f/36076...
BRBR ::
begin
Enabled := False;
end;
// Or even..
Checked := True;
end;
end;
end;
To bo to. Hvala.
BRBR ::
BTW
Tale TMenuItem bi bil lahko nekaj višjega po hirearhiji ? Kaj ?
Tako bi if lahko odpadel ?
begin
Button31.OnClick:= TMenuItem(Sender).OnClick;
end;
- spremenil: BRBR ()
grimth ::
Spodnja koda dela univerzalno za vse komponente ki imajo OnClick event handle. Torej TButton, TMenuItem etc... . Ko klikneš gumb bRepeat bo ponovil event komponente ki je bila nazadnje pritisnjena. Ampak seveda mora imeti OnXClick event nameščen.
uses
Winapi.Windows, Winapi.Messages, System.SysUtils, System.Variants, System.Classes, System.Rtti,
Vcl.Graphics, Vcl.Controls, Vcl.Forms, Vcl.Dialogs, Vcl.Menus, Vcl.StdCtrls;
type
TForm1 = class(TForm)
bRepeat: TButton;
MainMenu1: TMainMenu;
est1: TMenuItem;
Button1: TButton;
Button2: TButton;
procedure bRepeatClick(Sender: TObject);
procedure FormCreate(Sender: TObject);
private
FContext: TRttiContext;
FLastActive: TObject;
procedure RepeatLast;
published
procedure onXClick(Sender : TObject);
end;
var
Form1: TForm1;
implementation
{$R *.dfm}
procedure TForm1.bRepeatClick(Sender: TObject);
begin
RepeatLast;
end;
procedure TForm1.FormCreate(Sender: TObject);
begin
FContext := TRttiContext.Create;
FLastActive := nil;
est1.OnClick := onXClick;
Button1.OnClick := onXClick;
Button2.OnClick := onXClick;
end;
procedure TForm1.onXClick(Sender: TObject);
begin
ShowMessage((Sender as TComponent).Name);
if FLastActive <> Sender then
FLastActive := Sender;
end;
procedure TForm1.RepeatLast;
var
LProp: TRttiInstanceProperty;
V: TValue;
E: TNotifyEvent;
begin
if FLastActive <> nil then
begin
LProp := FContext.GetType(FLastActive.ClassType).GetProperty('OnClick');
if LProp <> nil then
begin
V := (LProp as TRttiInstanceProperty).GetValue(FLastActive);
if not V.IsEmpty and V.TryAsType<TNotifyEvent>(E) then
E(FLastActive);
end;
end;
end;
| » | Delphi - izdelava igreOddelek: Programiranje | 1538 (1311) | Nextor |
| » | [Delphi] Simpl vprašanja ko pasulj :)Oddelek: Programiranje | 1889 (1738) | oldguy |
| » | Delphi - kako prepreči prečiti več zaporednih klikov gumbaOddelek: Programiranje | 1438 (1361) | LoneWolf |
| » | Delphi problem- MessageDlgOddelek: Programiranje | 1231 (1161) | c3R4R |
| » | Delphi problem- zapiranje programaOddelek: Programiranje | 1564 (1510) | c3R4R |
