pascal copy event
pascal copy event
BRBR ::
procedure TForm1.MenuItem30Click(Sender: TObject);
var
begin
  Button1.OnClick:= self.OnClick;
end;
Zgleda dobro in compiler nič ne jamra, dela pa ne. Kako pripisat izvajanje kode enega elementa enemu drugemu elementu v run time ?
Jure14 ::
Torej ti v runtimu (dinamično) kreiraš gumb, ki bi mu rad določil OnClick dogodek?
Button1.OnClick := @proceduraKiSeIzvedeObKliku;
procedure TForm1.proceduraKiSeIzvedeObKliku(Sender: TObject);
begin
end;
BRBR ::
Da malo popravim opis. Recimo da imam 30 gumbov + enega.
Na tem zadnjem recimo piše: 'repeat last action'
Torej, vsak klik na kateregakoli od onih prvih 30 mora zadnjemu (31), runtime pripisat izvedbo lastne procedure.
var
begin
  //ne dela ker je self pač form1
  Button31.OnClick:= self.OnClick;
  //dela, samo je fixno, človek pa bi rabil nekaj univerzalnega (za vseh 30 gumbov), predvidevam da preko sender ....
  //sender nima onClick ...
  Button31.OnClick:= MenuItem30.OnClick;
end;
Gagatronix ::
Tole mi prej deluje kot Delphi, ki je, tehnicno gledano, Pascal ki se pretvarja da zna OOP. :))
kuall ::
The OnClick method that you have written provides all the information that you
need via the Sender parameter. This is the object which is calling the method
i.e. it is the actual menu item that was clicked. If you cast the Sender
parameter as a TMenuItem you can access all of it's properties e.g.
procedure TForm1.MyOnClick( Sender : TObject );
begin
 // Check that the Sender is of the required type.
  if Sender is TMenuItem then begin
    TMenuItem( Sender ).Caption := 'You just clicked me!';
   // Or if you prefer.
    with TMenuItem( Sender ) do begin
      Enabled := False;
    end;
   // Or even..
    with Sender as TMenuItem do begin
      Checked := True;
    end;
  end;
end;
http://www.delphigroups.info/2/4f/36076...
BRBR ::
kuall je izjavil:
begin
Enabled := False;
end;
// Or even..
Checked := True;
end;
end;
end;
To bo to. Hvala.
BRBR ::
BTW
  begin
     Button31.OnClick:= TMenuItem(Sender).OnClick;
  end;
Tale TMenuItem bi bil lahko nekaj višjega po hirearhiji ? Kaj ?
Tako bi if lahko odpadel ?
  • spremenil: BRBR ()
link_up ::
delphii...best memories ever. :)
In and Out
grimth ::
Spodnja koda dela univerzalno za vse komponente ki imajo OnClick event handle. Torej TButton, TMenuItem etc... . Ko klikneš gumb bRepeat bo ponovil event komponente ki je bila nazadnje pritisnjena. Ampak seveda mora imeti OnXClick event nameščen.
uses
  Winapi.Windows, Winapi.Messages, System.SysUtils, System.Variants, System.Classes, System.Rtti,
  Vcl.Graphics, Vcl.Controls, Vcl.Forms, Vcl.Dialogs, Vcl.Menus, Vcl.StdCtrls;
type
  TForm1 = class(TForm)
    bRepeat: TButton;
    MainMenu1: TMainMenu;
    est1: TMenuItem;
    Button1: TButton;
    Button2: TButton;
    procedure bRepeatClick(Sender: TObject);
    procedure FormCreate(Sender: TObject);
  private
    FContext: TRttiContext;
    FLastActive: TObject;
    procedure RepeatLast;
  published
    procedure onXClick(Sender : TObject);
  end;
var
  Form1: TForm1;
implementation
{$R *.dfm}
procedure TForm1.bRepeatClick(Sender: TObject);
begin
  RepeatLast;
end;
procedure TForm1.FormCreate(Sender: TObject);
begin
  FContext := TRttiContext.Create;
  FLastActive := nil;
  est1.OnClick := onXClick;
  Button1.OnClick := onXClick;
  Button2.OnClick := onXClick;
end;
procedure TForm1.onXClick(Sender: TObject);
begin
  ShowMessage((Sender as TComponent).Name);
  if FLastActive <> Sender then
    FLastActive := Sender;
end;
procedure TForm1.RepeatLast;
var
  LProp: TRttiInstanceProperty;
  V: TValue;
  E: TNotifyEvent;
begin
   if FLastActive <> nil then
  begin
    LProp := FContext.GetType(FLastActive.ClassType).GetProperty('OnClick');
    if LProp <> nil then
    begin
      V := (LProp as TRttiInstanceProperty).GetValue(FLastActive);
      if not V.IsEmpty and V.TryAsType<TNotifyEvent>(E) then
        E(FLastActive);
    end;
  end;
end;
Delphi - izdelava igre
Oddelek: Programiranje
81538 (1311) Nextor
[Delphi] Simpl vprašanja ko pasulj :)
91889 (1738) oldguy
Delphi - kako prepreči prečiti več zaporednih klikov gumba
51438 (1361) LoneWolf
Delphi problem- MessageDlg
61231 (1161) c3R4R
Delphi problem- zapiranje programa
71564 (1510) c3R4R
