Forum » Znanost in tehnologija » Neznani leteči predmet v Zagrebu morda Tu-141
harvey ::
Je ze razjasneno odkod vonj po amoniaku/plinu po strmoglavljenu drona?
Osjetili su miris koji je podsjećao na plin.
eventyrer ::
Huh, tega pa nisem videl.
Morda je povezano s temle.......
Russian Ministry of Defense Spokesperson Maj. Gen. Igor Konashenkov told Russian media on March 9 that “Ukrainian nationalists” delivered 80 tons of ammonia to Zolochiv, a village northwest of Kharkiv. Konashenkov claimed that the Ukrainians taught villagers how to act in case of a chemical attack. Konashenkov warned that “nationalists” were preparing to conduct a “provocation using toxic substances to accuse Russia of allegedly using chemical weapons.”[12]
- spremenil: eventyrer ()
harvey ::
Zanimivo, da bi to natovoril na dron
eventyrer ::
Then the people who were outside started to scream, then I panicked a bit and went outside to see what was going on. Then I smelled that horrible stench. People said that ammonia felt that way so we all closed the windows, we were afraid it wasn't something chemical, "says one of the students.
https://rs.n1info.com/region/kako-je-dr...
Pa res pisejo da je mocno smrdelo po amonijaku.
Najbrz je bilo v gorivu.
enemon ::
Zanimiva je teorija, da naj bi Rusija s padcem tega drona preverjala, kakšna bo reakcija Nata ...
Je pa zanimivo da ne BBC ne CNN o tem ne pišeta (sem pogledal samo naslovno stran).
Nepomembna regija.
Kumkvat_7725 ::
Kako verjetno je, da bi ob vsej tej površini letalnik naključno zadel ravno glavno mesto države, ki pošilja na veliko svoje borce tja in se hvali s tem ?
dronyx ::
Ves trud zaman, če v resnici ne veš, kako delujejo. Te letalnike lahko programiraš, da letijo po določeni poti, ki tudi slučajno ni kar ravna črta tja in nazaj.
To se po moje sigurno da, samo letalnik nima informacije kje točno se nahaja (GPS, radar terena ali kaj podobnega) tako da je dejanski let lahko precej drugačen od tistega, ki je bil programiran. Tudi Scud rakete niso namenjene temu, da boš natančno zadel neko tarčo, ampak prileti nekam približno kamor ciljajo.
mihagr ::
glede na to, da je letel tako nizko, bi se lahko že zdavnaj zaletel v kakšen hrib, ki jih je veliko na njegovi verjetni poti, če res ne bi imel kakšne bolj sodobne navigacije.
krucymucy ::
Ni hribov na poti tega "drona". Od Vojvodine do Rusije je ravnica, vmes je pa se nekaj drzav.
Ne vemo niti poti. Ravno cez najvisje vrhove karpatov ni sel, oz. se je spuscal.
Vemo da je bil bolj kot ne splet nakljucij.
- spremenilo: krucymucy ()
FilipF ::
Spoznal sem, da lahko povsem mirno spimo, smo povsem varni. Predlagam, da Ruse sankcioniramo tako, da jim pošljemo 6500 transponderjev, ki jih morajo nemudoma namestiti na svoje jedrske.
perci ::
Filip, nismo v vojnem stanju, zato je treba pazit, da ne sestrelis česa civilnega po pomoti.
Sicer pa, če bi Rusija iz podmornice v Jadranu v mirnem casu izstrelila par jedrskih konic, mislite, da bi nato pravočasno reagiral?
Verjetno enako velja tudi za podmornico, parkirano pred LAjem.
AtaŠtumf ::
Čakaj malo, tole je pa malce čudno.
Ves čas poslušamo od preverjenih virov, da so Rusi več kot 1000 km oddaljeni od Slovenije, Hrvaške, ..., sedaj pa delajo neko preverbo odziva Nata z ukrajinskim dronom?!
Pa kdo je tu nor.
Pa kdo je tu nor.
Ta dron so poslali Ukrajinci po navodilu NATO, zato da se bo po evropskih državah povečal budžet za vojsko.
Idioti tukaj pa še vedno sanjajo, da je to ruski dron.
Nihče pa ne ve, da je praktično vse bolj napredno orožje v ukrajinski vojski, rusko...
FilipF ::
Imam občutek, da se trudimo biti v vojni, sankcije, dobava orožja...
V 24 urah smo uspeli izvedeti, da je nekaj strmoglavilo v Zagrebu, da je letelo skozi zračni prostor treh članic NATA več kot eno uro. Na tem forumu se razlaga, da NATO radarji zaznajo vzlet komarja do 1000km v Ukrajino. Izstrelek ni prišel iz podmornice v Jadranu, odgovorni navajajo, da verjetno iz Ukrajine. Mislim, da je NATO pravočasno reagiral, saj bomo dali sankcije, da mora izstrelek potovati najmanj 24 ur nad članicami NATA preden pristane. Sem pomirjen in počutim se varno.
AtaŠtumf ::
K**** pa taki F-16, F-35 in vsi ostali NATO polizdelki, če tega niso pripravljeni sestreliti!
V bistvu nihče z gotovostjo ne ve ali je ruski ali ukrajinski je pa čisto iz lastnosti letala in poti ZELO verjetno, da je ukrajinski - in zelo verjetno so ga tudi poslali pač iz nekih taktičnih namenov, kot so jih že prej - malo verjetno da je bil polet nad Zagreb predviden.
No odsotnost neke posebne pozornosti novici v evropskih MSM je mogoče tudi določen znak, ampak to so spet špekulacije. Je pa znak.
- spremenil: Miki N ()
FilipF ::
So strokovnjaki že uradno ugotovili po 36 urah, kaj je strmoglavilo na Zagreb?
So morda že prišli predstavniki proizvajalca, da pomagajo pojasniti nesrečo?
Ne provociram rad, zato ne bom vprašal, kdo je to poslal.
TezkoDihanje ::
Vsi so ga imeli na radarjih, nihče ni naredil ničesar. Lahko bi bilo privatno letalo, pa ljudje gor. Ne moreš kar tako streljat nekaj kar ne veš, kaj je. Madžari bi morali poslat lovsko letalo, da bi ta artefakt prestreglo. Zakaj ga niso, mi ni jasno.
FilipF ::
TezkoDihanje je izjavil:
No saj Ruske manevrirne rakete tudi letijo skoraj tako, pa imajo lahko tudi jedrsko bojno glavo. Sicer bomo v par dnevih videli, če se po Zagrebu širi kovid 22. Važno je, da smo zavarovani in varni.
To je še najbolj sporno.
Niso preverili ali poizkusili vzpostaviti zvezo z letalnikom.
FilipF ::
To ni logično.
Če se ne odziva gredo preveriti vizualno. Vedno.
To je ja rutina.
In od vseh rutin prav sedaj niso imeli časa preveriti.
Smrdi enako, kot pri Epsteinu.....slučajno lih takrat niso delale kamere in varnostniki niso patrurirali tako, kot je rutina.
To je ja rutina.
Truga ::
No ja, mogoče so Ukrajinci sporočili, da so izgubili nadzor na letalnikom, pa ni bilo treba nič sestreljevati.
Ja, in lepo čakamo, da se zagoni v tvojo hišo & blok - i nikome ništa.
Aja, ker če jo sestreliš, pa ne more, ane.![]()
Ja; dileme, dileme. Ampak, če bo v vsakem primeru padlo na kurčev bivši eastern block & EX YU, NATO očitno itak boli kurac kam pade.
Mogoče bi se drugače odzvali, (ali pa sploh samo odzvali) če bi letelo kam drugam - na Nemčijo, mogoče. Mogoče.
1989 Belgium MiG-23 crash @ Wikipedia
Truga ::
FilipF ::
To ni logično.
To je ja rutina.
Počasi začenjam verjet v nemogoče, da so F35 nevidni za NATO radarje, Kitajski in Ruski, pa jih vidijo.
Pa kdo je tu nor.
rusija ni tako dalec kot se zdi :D
To so panslovanske barve:
Pan-Slavic colors @ Wikipedia
Nič tako radikalnega. Že Jugoslavija, kot tudi SFR Slovenija sta imeli panslovanske barve, skupaj z pač zvezdo. Da imamo še naprej panslovanske barve, je kar se mene tiče, nek legacy.
cvalsr ::
"""letalnik nima informacije kje točno se nahaja (GPS, radar terena ali kaj podobnega)"""
Hvala, mi je prav pasalo malo smeha. Točneje - veliko.
- spremenil: cvalsr ()
Banožić: Letjelica je imala aviobombu koja je eksplodirala
https://www.index.hr/vijesti/clanak/vid...
- spremenilo: sbawe64 ()
FilipF ::
Zaenkrat so ugotovili, da je bila izstreljena 1943 nekje iz vzhoda. Sicer ne vejo še katera vojska poseduje tako moderno orožje. Manjša težava je tudi, ker se ne ve še natančno, kako je potovala skozi prostor in čas. Važno je da smo varni.
Kvatebrigic ::
Hrvatje zdaj nekaj bluzijo da je bil na njem 120 kg bomba, ki je eksplodirala pod zemljo...
Bolj verjetna razlaga:
""Da kažem kulturno, priča mi je jako, jako čudna. Da je ta količina eksploziva eksplodirala, ne samo da ne bi ostao ni jedan komadić letjelice za istraživanje nego bi nestao i dio studentskog paviljona.
Pitanje je može li se 120 kg bombe staviti u dio za elektroniku. Kako bi letjela? U teoriji je sve moguće, ali sam jako skeptičan. Trebao bi MORH dati bolje dokaze za te tvrdnje.
Smatram da je došlo do aktiviranja samouništenja dvije kamere i elektronskih uređaja za snimanje signala. Cilj je da protivnik ne dođe do tih podataka. Tu su i patrone za izbacivanje kamera”, kaže."
Nacional: Dron je ukrajinski, bomba je bila namijenjena Rusima
https://www.index.hr/vijesti/clanak/nac...
Da Ukrajinci streljajo na Ruse? Mislim, da nasi o tem kar porocajo. Ce me spomin ne vara, so porocali o napadu na civilni del mesta Doneck.
Naši so ok.
V tujini so prikazali, da je ta raketa del tistih, ki so priletele na plačance na zahodu Ukrajiine.
| » | 780 miljonov za opremo vojske. (strani: 1 2 3 )Oddelek: Problemi človeštva | 27650 (22690) | redtech |
| » | Poletel prvi brezpilotni soborecOddelek: Novice / Znanost in tehnologija | 16291 (14189) | gus5 |
