RAM
RAM
Alkanoid_1 ::
Imam 2x Corsair 4GB 1600MHz DDR3 (povezava) na matični plošči Gigabyte GA-990XA-UD3 R5 (povezava), ko grem v nastavitve piše, da imam nameščenega 6GB RAM-a in uporabnega 3GB RAM-a. Zakaj nimam nameščenega 8GB RAM-a.
Hvala za odgovore
Han ::
Katere nastavitve? BIOS je zadnji? Sta modula v belih ali modrih režah?
Verjetno imaš 32-biten OS.
Alkanoid_1 ::
BIOS ni zadnji, modula sta v modrih režah, OS je 64 biten
Vuli ::
Poskusi tole:
I made this account just to thank the person above, this method was the only thing that worked out of everything I've tried... his configuration was similar to mine except with different motherboard and different ram brand and I had the exact same issue (as well as others such as XMP profile failing to work)
did as he suggested, removed all the RAM, started with empty, boot...
shutdown, installed one ram, boot, set BIOS to use proper XMP, went all the way to windows, checked that it wasn't reserving half of my RAM (and my XMP is working),
shutdown, installed 2nd ram, boot, set BIOS to use proper XMP, went all the way again to windows, checked that it still wasn't reserving half of my RAM (and my XMP is still working)
shutdown, installed 3rd ram, boot, set BIOS to use proper XMP, went all the way again to windows, checked that it still wasn't reserving half of my RAM (and my XMP is still working)
shutdown, installed 4th ram, boot, set BIOS to use proper XMP,
this time I ran into a problem as the system was unstable... and refused to enter windows properly...
I booted again, set BIOS to use a lower XMP (as it seems it has trouble using it's maximum XMP profile with all 4 sticks),
with the lower XMP profile it worked and went all the way again to windows, checked that it still wasn't reserving half of my RAM (and my lower XMP profile is still working)
As a note:
all 4 of my ram are Corsair LPX Vengeance 3200 8Gb each, they were 2 sets of a pair with the set bought separately so I have a pair of older version, and a pair of newer version (all 4 are the same DDR4 3200 but the 2nd set is newer)
I made sure that the pairs from the same set occupy the corresponding ram slot pair (so 1 pair from the older version occupy slotA2 and slotB2, another pair from the newer version occupy slotA1 and slotB1)
Now I got all 4 working.. albeit with a slightly slower XMP profile than the maximum (it can run at fastest XMP with the respective pair but not with both sets of pair together which is fair enough, XMP profile are not guaranteed to work with memory that didn't come in the pair after all)
and only 50Mb is hardware reserved.... so I have full 32GB of RAM available.
Alkanoid_1 ::
Torej, če vstavim v režo samo en RAM ga imam 4GB, če vstavim dva RAM-a imam 6GB(3 GB uporabnega).
3200MHz RAM skupaj z MOBO in CPU, ki podpirata 2933MHz
161993 (1690) Cveto
Dejanska frekvenca ramov
181415 (1128) Jst
Frekvenca RAM
111772 (1554) r3dkv1c4
hitro rabim en mocan racunalnik za 1500eurov ali vec
292906 (2180) JIM22
Windows Commander 5.1
53449 (3449) darh
