Facebook, Instagram ne dela
2
vilonja ::
Mogoče veste kaj je vzrok za upad teh dveh storitev? Ali samo meni ne dela?
koyotee ::
Rear DVD collector!
JTD power!
McNato ::
WhatsApp tudi ne.
xseki ::
Je down po celem svetu.
Zimonem ::
Predvsem pa brez panike! Dowlodajo vam osebne podAtke.
https://news.ycombinator.com/item?id=28...
Kleemen ::
Zanimivo, nisem še doživel takega velikega "downa" sploh pa ne da vpliva na cel svet. Kdo stoji za tem? :)
Samael ::
Kleemen je izjavil:
Verjetno ga biksa kakšen CDN kot Akamai, Cloudflare ipd...
Samael != Samuel
b3D_950 ::
Konec je.
Se dobro, da imamo slo-tech. Drugace ne bi opazili.
teckow ::
Na češkem ni interneta preko stacionarnih povezav, prav tako ni interneta preko klasičnih mobilnih podatkov... internet je možen samo preko 5g trenutno na češkem.... (informacija ta trenutek iz češke)
zanimivo :)
Vuli ::
a ga DDOSajo zaradi unih svinjarij k so pršle ven?
Goran's Blog ::
Dejansko se dogaja DDOS attach na svetovni ravni in veliko spletnih strani je down.
Aktivirali so Mr. President Trump racun, sedaj grejo skozi backlog... Sej bo vsebine.
Voluharr ::
Zanimivo, pa prestavljam DNS na 1.1.1.1 in gledam kaj je narobe z routerjem, pa očitno ni tu težava.
Meni je tudi Youtube malo počepnil.
Bo zanimivo videti kak graf 8-)
Backup, VPS, kolokacija: https://reavisys.si
  • spremenil: Voluharr ()
jsmith ::
https://www.reddit.com/r/sysadmin/comme...
/u/ramenporn Update 1440 UTC:
As many of you know, DNS for FB services has been affected and this is likely a symptom of the actual issue, and that's that BGP peering with Facebook peering routers has gone down, very likely due to a configuration change that went into effect shortly before the outages happened (started roughly 1540 UTC).
There are people now trying to gain access to the peering routers to implement fixes, but the people with physical access is separate from the people with knowledge of how to actually authenticate to the systems and people who know what to actually do, so there is now a logistical challenge with getting all that knowledge unified.
Part of this is also due to lower staffing in data centers due to pandemic measures.
Update from /u/ramenporn
No discussion that I'm aware of yet that is considering a threat/attack vector.
I believe the original change was 'automatic' (as in configuration done via a web interface). However, now that connection to the outside world is down, remote access to those tools don't exist anymore, so the emergency procedure is to gain physical access to the peering routers and do all the configuration locally.
Zaenkrat izgleda, da so s spremembo konfiguracije ubili vse povezave z ostalimi omrežji.
Včeraj so sicer v ZDA predvajali oddajo 60 minutes, v kateri so razkrili mnoge nepravilnosti znotraj Facebooka.
Voluharr ::
No tudi https://bgp.he.net/ je postal neodziven ;((
Being updated
The private personal data of 1,5 billion Facebook users is reportedly being sold on hacking forum.
poweroff ::
Jaz sem takoj posumil na BGP problem... kot kaže, je točno to težava.
sudo poweroff
Uporabnik ::
IL_DIAVOLO je izjavil:
https://twitter.com/arlo_kaporaki/statu...
Something went wrong. Try reloading.
Kaj je pisalo, da so zbrisali?
If You Don\'t Stand for Something, You\'ll Fall for Anything
49106 ::
refresh. To se pri twitterju pogosto dogaja.
poweroff ::
V bistvu je po mojih informacija problem precej ... smešen. Updatali so routerje in se zaklenili ven. :))
sudo poweroff
Dri3r ::
Facebook je dobil korono in je trenutno v karanteni.
dri3r
widj3098dj32 ::
Ne delajo tudi kartice za vstop v firmo, mega lol. And nothing of value was lost. Influencerke na suicide watch.
poweroff ::
Kakšne kartice? V Facebook fizično ne morejo vstopit??
sudo poweroff
TheBlueOne ::
Sprosti um. :)
harvey ::
Se zgodi, da tudi veliki klecnejo, iz niti na twitterju naj bi bile posredi 'banalnosti'.
Goran's Blog ::
Somebody messed up. The protocol that routes ALL servers is wrongly configured. 2 DNS have disappeared from the routing table and the others are unreachable. My guess is a BGP issue and that someone really dropped the ball on this one.
But it gets better: To fix this, someone needs to get physical access to the actual machines that are running this. Actual humans need to fly to the location where the centralised computers are sitting and reboot some stuff from there.
Horas ::
vse kar je fejsbukovega ne dela :D
ni samo fb in ig, tudi https://www.isitdownrightnow.com/ ne dela :D.
Voluharr ::
poweroff je izjavil:
Zanimivo, imajo oni routerje lastne izdelave ali uporabljajo kaj bolj znanega? Cisco, Huawei, Extreme Networks, ... ?
d4vid ::
Skrajni čas. Kaj bi dal, da tak izpad traja vsaj 14 dni.
Kaj je tukaj spornega, da me bluefish brise?
d4vid je izjavil:
Tvoja barva koze.
d4vid ::
iloveboobz je izjavil:
d4vid je izjavil:
Tvoja barva koze.
Se mi je zdelo, ker nisem moder kot modra riba.
d4vid je izjavil:
Pisat moraš kok je KUL u redu in SD najboljša stranka. Da se boš včlanil v to stranko. In podobne kozlarije. :D:D:D
hmm, zgleda so flesnal najnovejso verzijo openwrtja gor in niso checnal changeloga:))
Janša je zaradi EU srečanja izklopil Facebook, v Kranju in okolici pa tudi internet..
deltron ::
Slabši ste kot crackhead-i...
V-i-p ::
Mogoče za koga butasto vprašanje, pa jbg. Zakaj na SIX-u ni videt nobenega upada prometa danes zvečer?
 null
null
FireSnack ::
Pravijo da nikoli več ne bo Facebooka. Teroristični napad ali nekaj takega. Konc je. Zdaj pa po štrik in na drevo.
  • predlagal izbris: Shkorc ()
Colt1911 ::
Kurzweil ::
Zabavno kakšno histerijo nekateri doživljajo... ne manjka niti kupa teorij zarot... sam sem FB user, pa sem to opazil šele na Slo-techu...
Že kot nek sociološki eksperiment bi bilo zanimivo videt, kako bi izgledale stvar v kolikor FBja recimo ne bi bilo kakšen mesec dni, za kar seveda "ni straha"...
Če pa je tu kdo, ki mešetari z delnicami in podobnim... me zanima kako bo vplivalo tole na vrednost delnic... indeks oz. kakorkoli se že naj izrazim...
FireSnack ::
Verjetno bo sprožilo novo rast ko pride nazaj. Eksponentno.
Kurzweil ::
ADD: zanimivo je tudi to, kako bi hipotetično padec socialnih omrežij boostal obisk forumov, kot je tudi ST... res škoda, da ne bi FB padel za kakšen mesec dni... pa tudi vsa ostala socialna omrežja ;((
vasquez ::
Na koncu bo verjetno krivo pomanjkanje polprevodnikov...
FireSnack ::
Kurzweil je izjavil:
Podpišem za 2 meseca, ampak nimamo kadra v bolnišnici za kaj takega.
Nekdo bo spoznal vrednost backdoorov v mngmt networke ...
Jerry000 ::
Tole bo še zanimivo. Za takšno veliko firmo da je sistem dol 5h+, to je katastrofa. Potem pa ko malo razmišljaš, ljudje se na spletne strani in celo v aplikacije prijavljajo preko FB. Potem društva, male trgovine, sportne skupine in ostale skupine, to vse poteka preko FB, tudi prodaja. Vse to ne dela. To bojo izgube takšne da glava boli, pa da ne govorimo še o kakšnih tožbah zaradi izgube. Luštn bo
Ponavadi se taki downtimei bolj poznajo na številu rojstev čez 9 mesecev ;)
2
SIX
Oddelek: Omrežja in internet
213299 (956) starfotr
Nerazumljivi in škodljivi posegi MJU v internet
Oddelek: Novice / NWO
198146 (5840) MrStein
Postati ISP ponudnik
405781 (4531) blabla80
Kam gre internet?
2910344 (9975) NoBody-
