Forum » Operacijski sistemi » [Windows 11] Debate, vprašanja in težave
KTr1sk ::
MBEC virtualization provides an extra layer of protection from malware attacks in a virtualized environment.
MBEC provides finer-grain control on execute permissions to help protect the integrity of system code from malicious changes.
To so razna mnenja ljudi iz forumov, da bi bil bolj varen operacijski sistem, glede virusov in malware..., če te tako moti, kupi si najnovejše komponente, jaz pa bom še nekaj let ostal na svojih starih kištah ;)
It doesn't stop malware, or viruses or ransomware and as secure as a motorbike protected by a keychain.
And ask any Linux user how much security secure boot offers, hello on Linux now with secure boot, bite me Microsoft.
The only reason Microsoft is doing this is to sell people new computers, they are desperate for money and think doing this will lure people to new machines in fear of their current machines being obsolete, it's a scam and I will not stand for it and nether should you.
Sn Intelu postavil še eno vprašanje pa me zanima kaj bodo odgovorili.
_Denny_ ::
@KTr1sk: Največji problem pri nepodpori in emulaciji tega čuda je performance impact, zato sem v mojem prejšnjem postu napisal, da pri forsiranju tega moj PC ne bo videl Win11. Se še spomnim kako se mi je 5820k prelevil v Core 2 Duo, ko sem v Win10 enkrat "v imenu varnosti" vklopil Memory Integrity...dejansko občutiš kako dela čisto vse počasneje.
@mtosev: Jebat ga, x299 je 2017 tech. Si na istem kot mi vsi ostali.
- spremenil: _Denny_ ()
Nisem na istem, ker je cpu na supported listi. Edino mi ni jasno kaj pomeni, da nek feature MBEC ni podprt. Na mi Microsoftovem website piše Kaby Lake or newer. Ugotavljam kaj je točno in če mene prizadele ali ne.
Hi thanks for your answer.
I found this on Microsoft's website:
Because it makes use of Mode Based Execution Control, HVCI works better with Intel Kaby Lake or AMD Zen 2 CPUs and newer. Processors without MBEC will rely on an emulation of this feature, called Restricted User Mode, which has a bigger impact on performance.
Can someone explain this because I find it confusing especially the part that says Kaby Lake and newer?
- spremenil: mtosev ()
Assass1n ::
Ali je kdo kje videl kako odpravit, ko v taskbaru pri uri nekaj trzne kot da bi hotel pokazat kak notification pa si premisli. Na kake pol minute do par minut je skrajno moteče ko ti tja pozornost usmeri.
KTr1sk ::
Dokler se ne bo nekaj samodejno vklopilo in začelo počasi delovati se ne sekiram, tako pa dela vse tekoče oz ne opazim razlike napram Windwos 10, zenkrat posodobitve delujejo in se nameščajo samodejno tako kot na podprtem sistemu ;)
Eno hitro vprašanje: a rabi biti win 10 na najnovejšem buildu 21H1, da se lahko upgrada na win 11 kr iz settings / updates? Trenutno sem na 20H2 zato sprašujem.
Ja in ne. Namestiti se bo dalo, ampak ne bo posodobitev, ker cpu ni na listi podprtih procesorjev.
KTr1sk ::
Ali bo windows 11 "deloval" na MSI B150A in procesorjem i7-6700?
Poglej malo višje ..tam ti piše kako se inštalira na ne-podprtih sistemih, verjetno ti bo napisalo da ne ustreza in te ne bo spustilo naprej.
Ko ti bo uspelo inštalirat, no zaenkrat DELAJO vse posodobitve ne glede na to da ni podprto, ker imam še vedno na treh različnih pcjih in deluje vse posodobitve, tako da ne govorim na pamet! Kako bo pa vnaprej pa se res ne ve, ampak verjeno bo enako ostalo oz. bomo videli ;)
_Denny_ ::
https://www.pcgamer.com/windows-11-pcs-...
Taka je situacija s CPU-jem, ki bi naj imel MBEC/HVCI podporo. Kako lepo še mora biti, če stvar laufa prek emulacije...bo kar veselo, ko bo MS ob releasu oz. pozneje prek kakega žnj updata vsem vklopil te varnostne zadeve po standardih US ministrstva za obrambo.
Isto je baje Memory integrity na večini podprtih Win10 sistemov vključen že od 2018 dalje, samo mi tega ne vemo, ker ne delamo clean installov. Reddit je poln pritožb glede upočasnitev zaradi tega.
Pezdicek ::
So pa pravi kekci tile na MS.
Moj pc ne dosega min. req. ampak reklamo na zaklenjem zaslonu pa šopajo na polno.
And if you're upgrading from Windows 10 to Windows 11 then you don't have to worry about VBS being enabled, unless you were already running an enterprise version of the older OS, that is. The issue comes if you're receiving a machine which has had an OEM build of Windows 11 installed on it.
Zame očitno ni relevantno.
Čisto btw jaz čakam, da mi ponudijo upgrade na Windows 11, ker ko bo možno grem gor takoj.
strom_15 ::
Z enostavnim programom nad zaščito operacijskega sistema Windows 11
vir: https://racunalniske-novice.com/z-enost...
Jutri uradno izzide Windows 11. Se je komu v Windows update prikazalo sporočilo za upgrade?
KTr1sk ::
Ponavadi računalnik dela veliko boljše, če se na novo naloži kakor da se updejta ;).
KTr1sk ::
Mantra za čas Viste, morda 7/8.
Problem je samo vse nastavitve in program nazaj spravit, drugače pa včasih enostavno je boljši občutek imeti na novo inštaliran "svež" Windows.
Gospod ::
KTr1sk ::
For home use as long as it works I don't care if it's labeled unsupported ;).
bluefish ::
Hja, odvisno. Microsoft grozi z nedostopnostjo popravkov, tudi varnostnih, na nepodprtih sistemih. Ne ravno nekaj, kar bi tudi domač uporabnik ignoriral.
KTr1sk ::
Ta forum spremljam že leta
https://forums.mydigitallife.net
Tukaj je že nekdo naredil "patch" VBS off
Microsoft 'will be enabling VBS on most new PCs over this next year' and that can tank performance
https://forums.mydigitallife.net/thread...
Tukaj naprimer lahko najdeš tudi marsikaj zanimivega:
https://www.elevenforum.com/tutorials/
Prav zanimiva "bitka" bo, kar bo Microsoft zahteval, kako bodo drugi delali razne bypasse ;)
Han ::
US stran za ISO
https://www.microsoft.com/en-us/softwar...
SI
https://www.microsoft.com/sl-si/softwar...
SI
- spremenil: Han ()
filip007 ::
Samo piše, da ga pripravljajo za nas, kdaj bo to?
Zero games, zero talk.
filip007 ::
Kako, kako, to je družinski prenosnik, ne bom dajal na silo gor nekaj na prvi dan.
Buggy ::
Ce ob strani pustimo on/off VBS, ali je pri DX12 gamingu v W11 vs W10 res (opazna) razlika v prid W11?
Nekje sem namrec naletel na nek video, ki pa ne vem koliko je pristen, ne najdem pa nikjer nic kaj konkretnega na to temo. DX11 gaming naj bi ostal enak, Vulkan na W11 celo malce slabsi...DX12 pa na W11 obcutno boljsi.
Je kdo naletel na kaksem kredibilen clanek, ki ugotavlja kaj podobnega in ga lahko prilima?
bluefish ::
Ravno gledam tale hiter vpogled v novosti.
Vidim da so odstranili kar nekaj dobrih funkcionalnosti, ki jih je imel W10, in njih odsotnost zamaskirali s kičem.
Moj "star" procesor vstran, tole (še?) ni zrelo za nadgradnjo Desetke.
- spremenil: bluefish ()
orreel ::
Bom kar tukaj vprašal.
Ko sem z programama preveril ali je moj računalnik pripravljen za 11ko,mi pokaže sledeče,povezava do posnetka.
https://ibb.co/gd5KG2c
Ker je Windows 10 pro naložen-kloniran v načinu Legacy,ni možno v biosu vključit varnega zagona,ter disk je v načinu MBR namesto GBT.
Mi očitno ne preostane drigega kot najlažje je formatiranje sistemskega diska in pretvorbo v GBT,in me zanima ali se ga da pretvoriti z upraviteljem diskov ?
Računalnik bom zagnal z prejšnega SSD sistemskega diska na katerem je še vedno windows 10.
Potem formatiram nov sistemski disk in ga pretvorim v GBT,tukaj rabim vašo pomoč kako to storiti.
Potem na novo naložim nanj 10ko z usb ključa,in počakam še nekaj časa z nadgradnjo na 11ko.
Ali mora biti iso 10 kasneje 11 ke v enakem jeziku kot je bila prvič naložena 10ka v ang. jeziku ali je lahko tudi v Slo.jeziku ?
Kateri koli jezik lahko uporabiš, je čisto vseeno. BTW na Googlu najdeš navodila kako pretvoriš disk. Obstaja orodje za to.
orreel ::
Google je našel tole,ali je v redu ?
le kaj bi mi brez strica googla.
https://www.windowsnoticias.com/sl/como...
Bolf3nk ::
MS je reko, da v končni verziji bo TPM obvezen in takšne stvari blokirane.
Ravno obratno pravi, da ne bo blokiral ;)
https://www.windowscentral.com/windows-...
In kako sedaj ročno namestiš w11 na star PC brez raznih hackov?
Meni "uradno" ne gre. naredil sem booteble usb - bootam in preden bi izbral disk, mi javi da ni ok PC.
orreel ::
Kaj menite o tem načinu ?
https://www.websetnet.net/sl/windows-10...
https://ik4.es/sl/convertir-mbr-a-gpt-u...
KTr1sk ::
Uradno ne gre, (ko je naložen pa zaenrat še delajo posodobitve) ne rabiš pa ISO datoteke nič spreminjat, ampak samo slediš tem navodilom
Drugače pa še vedno imaš Windows 10, jaz testirtam Windows 11 na nepodprtem sistemu, ...zaenrkraš še niso ničesar blokirali
Bolf3nk ::
Sem gledal tole...
vendar nikakor ne znam dl tiste reg. datatoteke...
https://github.com/St1ckys/Win11
KTr1sk ::
Sem gledal tole...
https://www.filemail.com/d/hrydkxxpnqzd...
_Sajmon_ ::
A je komu uspelo namestit 11-ko v VirtualBox ali Vmware Player? Meni v obeh napiše, da ne more namestit, ker niso vsi pogoji zadovoljeni.
KTr1sk ::
Prelistaj malo ta forum
Master_Yoda ::
Jaz sem jo v VMWare workstation. Moras ko kreiras nov VM ga enkriptirati, izbrati UEFI+Secure boot. Potem ti dovoli dodati TPM device v VM, in potem dela.
Ampak ne vem v cem je finta tega TPM requirementa, ce lahko softwarsko se to resi ze v VMjih
Dovie'andi se tovya sagain.
Moj star procesor vstran, tole (še?) ni zrelo za nadgradnjo Desetke.
Imaš prav, med drugim ne deluje način povleci in spusti (drag and drop) v taskbaru, kar je še delovalo na starejših sistemih. Enostavno ne moreš povleči neko datoteko na ikon programa, pa naj bo ta zaprt ali odprt spodaj v taskbaru. Pa še cel kup malenkosti je, katere so odstranili ali pa samo izklopili. Kakorkoli, funkcijsko izgleda vse bolj okrnjen, v smislu, da lahko uporabnik sam nima več takšnega dostopa "pod havbo". No, morda se bo to dalo rešiti z raznimi 3rd party orodji, dodatki, tweakerji.
Jaz bom počakal vsaj kakšno leto, če ne več ...
- spremenil: opeter ()
Matooo1 ::
Mene isto jebe procesor, ni kompatibilen, računalnik pa je star 4 leta.. lol.. ne vem no hvala Microsoft.. res ste karlji.. in kako nj zdj nadgradim računalnik?
Saj imaš razne postopke ...
Tu pa je še postopek nadgradnje na nepodprtih napravah in sicer tako, da preliščiš Windows 11 na način, da uporabiš Window 10 USB Media Creator orodje, za ISO pa izbereš Windows 11 sliko.
Preštudiraj spodnji posnetek:
Evo.
Postopek končan na dveh mašinah.
AMD 3500U in 4650G
za enkrat vse dela.
Sistem deluje "odzivnejši" (možnost placeba)
Izgled.........Apple.
WHY!!!
AMD 3500U in 4650G
za enkrat vse dela.
WHY!!!
- spremenil: D3m ()
djabi ::
WHY!!!
V grafičnem smislu je neka mešanica elementov iz mac OS, ChromeOS in raznih vmesnikov/rešitev, ki jih najdemo v različnih operacijskih sistemih na pametnih napravah ...
Zakaj? Ker je to trenutno trend.
Že kakšno desetletje, oz. več se zadeve pomikajo proti ploski obliki:
Flat design @ Wikipedia
Designers may prefer flat design because it allows interface designs to be more streamlined and efficient. It is easier to quickly convey information while still looking visually appealing and approachable.
prevod: Oblikovalci imajo raje plosko oblikovanje, ker omogoča bolj poenostavljeno in učinkovito oblikovanje vmesnikov. Tako je lažje in hitrejše posredovati informacije, hkrati pa je še vedno videti vizualno privlačno in dostopno.
Sama zasnova je (baje) bolj primerna tudi za moderne čase, ko večina visi na društvenih omrežjih itn.
Si bral to novico?
https://slo-tech.com/novice/t791076/0
| » | Microsoft bo brezplačno omogočil še leto dni popravkov za Windows 10 (strani: 1 2 )Oddelek: Novice / Operacijski sistemi | 15848 (6271) | bm1973 |
| » | Procesor upgrade za WIN 11 prenosnik AkoyaOddelek: Kaj kupiti | 2979 (2054) | joez7 |
| » | Windows 11 je tu (strani: 1 2 3 4 5 6 )Oddelek: Novice / Operacijski sistemi | 75964 (26356) | joez7 |
| » | Windowse 11 bo mogoče ročno namestiti tudi na starejše napraveOddelek: Novice / Operacijski sistemi | 20451 (6255) | bm1973 |
| » | Windows 11 24H2 na voljo za vse (strani: 1 2 )Oddelek: Novice / Operacijski sistemi | 21129 (12876) | _Denny_ |
