Forum » Pomoč in nasveti » Restore QuickBooks Backup File
Joewatson ::
For restoring the QuickBooks file backup, you need to follow the steps mentioned below by using USB flash drive, CD, network folder or hard drive.
• You have to click on the option of File > Restore Company > Restore a backup Copy > Next.
• Select the Local Backup and click on the Next button.
• You have to choose the location where you want to save your backup file from the drop-down menu.
• Then give a new name to the selected backup file from the folder.
• Click on Next and then clicking the restored file save it.
If you have trouble restoring the backup file in this accounting software, then you can reach out to Quickbooks customer support number for immediate help.
- predlagal izbris: kloko ()
| » | Ne predvaja novega audio CDOddelek: Pomoč in nasveti | 2618 (2574) | Tea Time |
| » | Izšel TrueCrypt 4.0Oddelek: Novice / Ostala programska oprema | 5843 (4984) | poweroff |
| » | Ikone v win XP izginile po uporabi programa Spybot Search & Destroy. Kako dobiti ikonOddelek: Pomoč in nasveti | 2702 (2658) | riba43 |
| » | Kako v Win2k premakniti mapo Documents and Settings?Oddelek: Operacijski sistemi | 2542 (2508) | Mercier |
| » | Logitech MouseWare bug (?)Oddelek: Pomoč in nasveti | 2611 (2207) | Swiwer |
