Forum » Loža » Kuba in zdravstvo, tehnologija ter bolezni
SmeskoSnezak ::
International bodies like the Pan-American Health Organisation (PAHO) hope that Cuba will become the first Latin American country to produce its own vaccine.
https://www.bbc.com/news/world-latin-am...
Zgodovina: https://blogs.lse.ac.uk/latamcaribbean/...
From March 11 to June 17, 2,295 patients had been confirmed to be severe acute respiratory syndrome coronavirus 2 (SARS-CoV-2) positive in Cuba, 2,165 were treated with Heberon® Alpha R, and 130 received the approved protocol without IFN. The proportion of fully recovered patients was higher in the IFN-treated compared with the non-IFN-treated group. Prior IFN treatment decreases the likelihood of intensive care and increases the survival after severe or critical diseases. Benefits of IFN were significantly supported by time variables analyzed.
https://www.liebertpub.com/doi/abs/10.1...
Studies showed, he said, that after starting treatment with Interferon alfa 2b, 50% of those treated tested negative for the virus on the fifth day, and that when also applying Heberferon, 50% of patients took only three days to test negative. This led, he said, to accelerating the taking of PCR samples in June and July to testing on the first day. Subsequent PCR samples were then taken on the ninth and tenth day to confirm and discharge a patient if the result was negative.https://www.caribbean-council.org/scien...
Izgleda da imajo na Kubi svoja zdravila po imenu Interferon Alfa 2B , Heberon ....
In ocitno bodo tudi izvazali novo zdravilo po imenu Soberana 02:
https://www.cnbc.com/2021/02/23/soberan...
Izgleda so nekatere drzave res bolj tehnicno podkovane, kot nas slovenistan.
Kje so sedaj nasi znanstveniki, pa tehnolosko nadpovprecni , brihtni ljudje? Zakaj pri hudicu ni novic direkt iz teh nasih tehnolosko naprednih laboratorijev, ip.? Saj ne morejo bit vsi placani od drzave ali pa se bati, molcati...
Ah, verjetno so vsi pobegnili ze davno ven... takorekoc brain drain /soff /roff
LP,
Smeska
p.s.:/soff - sarkazem off /roff - rant off :)
@ Pusti soncu v srce... @
wajdouc ::
Banana republicc Slovenistan. Zakaj bi Slovenec pohvalil sposobnega sodržavljana, če pa ga lahko tlači dol in sta oba na slabšem?
Dokler se bo znanosti rezalo budget, novic ne bo, sprijazni se s tem.
| » | Umaknjeni dve pomembni študiji o terapijah za covid-19Oddelek: Novice / Znanost in tehnologija | 17445 (12598) | rusilec |
| » | EMA odobrila cepivo proti covidu-19 (strani: 1 2 )Oddelek: Novice / Znanost in tehnologija | 24069 (20655) | 7982884e |
| » | WHO ne bo več preizkušala hidroksiklorokina proti covidu-19Oddelek: Novice / Znanost in tehnologija | 12920 (10671) | hr_natakar |
