NVR snemalnik in Flash player
torentino ::
Pozdrav, kako leto uporabljam Floureon snemalnik K9604-w, 4 IP kamere HA-JA WF960P.
Problem se je pojavil po ukinitvi Flash playerja, ker drugega zadeva pač ne ponuja, torej na remote dostopu ni več slike, lahko gledaš le na VGA ali HDMI izhodu NVR-ja.Proizvajalec je itak mrknil(ja, vem, čipšit china). Obstaja kaka rešitev?
ppapi, npapi fp 32.0.465 sta še vedno gor
https://fpdownload.macromedia.com/pub/f...
Shit, vidim kje je problem.
Browserji.
  • spremenilo: sbawe64 ()
torentino ::
Aha. BigTech se je odločil in mi se lahko jebemo.
https://www.howtogeek.com/707830/how-to...
ruffle recimo da dela 30% pravilno . Tega se recimo ne da več igrati http://flashfabrica.com/f_learning/brai... .
Potrebuješ Flash player 32.0.0.371, ki nima kill stikala + browser, ki bo podpiral flash.
http://andkon.com/arcade/faq.php
Download the Pale Moon browser (portable, 64-bit). [IMAGE]
Open to extract to a USB stick. Browse/select [...] the USB drive. Name the folder "palemoon" so that the extracted contents are in one folder. So something like F:\palemoon or G:\palemoon depending on what letter your USB drive uses. [IMAGE]
Download the flash file NPSWF64_32_0_0_371.dll and move it into USB:/palemoon/Lib/Mozilla/Plugins. (Flash 32.0.0.371 is the last version to not include a timer that disables Flash.) [IMAGE]
Remove Adobe Flash Player NPAPI 32 if higher than 32.0.0.371. (Flash defaults to the highest version installed.) [IMAGE]
Open USB:/palemoon/Palemoon-Portable.exe [IMAGE]
torentino ::
čakaj, jaz sem glup uporabnik, ne neki ludi geek...
Nek stari flash sem že naložil, delal je, dokler se niso winsi zbudili in zbrisali celo inštalacijski file.Brez vprašat.
Winsi sigurno ne, moogoče win defender pri w10 ?
Pri "PaleMoon browser x32" morata biti v mapi Plugins sledeča adobe fp fajla, drugače fp ne dela
\Lib\Mozilla\Plugins\
FlashPlayerPlugin_32_0_0_371.exe
NPSWF32_32_0_0_371.dll
Pri "PaleMoon browser x64" je dovolj "NPSWF64_32_0_0_371.dll".
//Trial and error metoda.
https://www.reddit.com/r/pcgaming/comme...
https://github.com/darktohka/FlashPatch
Tale je kot kaže reversal dll, ki vsebuje time kill switch (12.1.2021).
Kaj se spremeni je v { } oklepajih :
https://github.com/darktohka/FlashPatch...
torentino ::
sbawe64 je izjavil:
V Win 7 se je zgodilo. Eset antivirus imam.
Zadovoljen bi bil že, če bi uspel prepričat VLC, da bi kazal kamere ampak noben program mi ne najde streama iz kamer. V nastavitvah NVR-ja, je samo IP kamer, username, port 80 za user interface, pa piše, da je H.264.Onvif ne najde nič, ip in port scanerji ne najdejo nič.
Vuli ::
čaki, sej lahko dostopaš preko ip:porta na nvr in gledaš preko internet exploreja(brskalnik)
torentino ::
Ja, samo namesto slike je tam napis:
Get Adobe Flash...
Firefox/Pale Moon browser (chrome bo itak ukinil podporo), namesti adobe fp 32.0.0.465 https://fpdownload.macromedia.com/pub/f..., nato poženi https://github.com/darktohka/FlashPatch... da patchas time kill switch v fp.
Preveri če ti igre iz http://flashfabrica.com/f_learning/brai... delajo, če da, potem mora delati tudi NVR snemalnik.
torentino ::
Hvala sbwave64, zadeva špila:):):))Preizkušeno na Firefoxu v.84.0.2
  • spremenilo: torentino ()
Samo za info , vsi msm browserji bodo prej ali slej podporo za adobe fp ukinili, patchan fp gor ali dol, zato ti priporočam, da si namestiš portable verzijo bodisi od Firefox/Pale Moon browser oz. https://chromium.woolyss.com (pepper flash oz ppapi), v nastavitvah izklopiš iskanje posodobitev za browser in ga uporabljaš samo za flash zadeve.
https://portableapps.com/apps/internet/...
za PM imaš na palemoon.org strani
za chromium.woolyss izbereš Portable in nastaviš v chrlauncher.ini
ChromiumCheckPeriod=0
torentino ::
Kaj pa na android fonu?
Tudi tam me vsi browserji pošljejo na EOL stran od Adobeja, pusti pa ištalirat standalone Flash player.
Vuli ::
bo, kako pa meni kar dela pa ne vem.
Najdi starejšo verzijo brez time_kill_switcha ali patchaj apk.
https://www.wikihow.tech/Play-Flash-Gam...
Na FlashFox browserju flashfabrica.com igre delajo.
torentino ::
Meni se Flashfox sesuje, ko pride na stran z flash vsebino.Potegnil sem dol flash player v11.xx, pa ga ne znam dodat v mozilo kot dodatek..
Kateri os ?
torentino ::
aNDROID 9, sAMSUNG galaxy 4+
torentino je izjavil:
Kontaktiraj avtorja Flashfox, mogoče se da vklopiti kakšen verbose debug log, da se potem vidi, kje/zakaj se je app sesul.
Sesuje se na flashfabrica.com ali kje drugje ? Jaz sem testiral samo tam.
Uh, jaz imam precej starejšo verzijo os :)).
alternative (in še katera verjetno):
Dolphin Browser, Photon Flash Player & Browser tudi podpirata adobe fp.
Če uporabljaš FlashFox ne potrebuješ dodatno ročno nameščati adobe fp (starih 11 verzij).
Removing the timebomb from Adobe Flash Player
https://gist.github.com/KuromeSan/56d8b...
torentino ::
Sem preizkusil vse tiste browserje. Na Flashfoxu mi flashfabrica.com deluje, sesuje ga, ko pridem na moj NVR, prijavna stran še deluje, ko pride na prikaz videa ga usuje.
V kitajskem mestu Dalian težave na železnici zaradi ukinitve Flasha
Oddelek: Novice / Brskalniki
168400 (6805) Glugy
flash na android tel?
Oddelek: Mobilne tehnologije
71602 (1201) johan05
Ne dela youtube
182874 (2232) BorutK-73
Firefox bo 64-biten
4921479 (18420) RuskiSnajper
Google Chrome shranitev Facebook gesla problem!
143561 (3361) Valentin
