Forum » Strojna oprema » EP-8HDA3+, moja nova plata?
kuglvinkl ::
Em, ziher ne. Treba še malo hroščev polovit, pa razjasnt oz. odkrit kolk časa, naj bi bil s. 754 sploh v obtoku.
Vseeno pa:
Specifications of mainboard
• 5x PCI slots
• 1 x AGP 8 x Slot colour coded purple
• 2 x DDR400 DIMM slots
• 4 SATA ports by Sil3114 including RAID 0, 1, 10 & 5
• 1 Floppy drive controller - 2 serial ports - 1 parallel port
• 2 standard IDE ports for ATA-133, backwards compatible with ATA-33/66/100
• 8 USB 2.0 ports (4 by rear panel, 4 by front panel option)
• Onboard sound, 6 channel Jack Sensing ALC655 Audio with environmental effects
• Onboard SATA with
• Standard ATX format 305 x 245mm
• Onboard Dual LAN by 3COM 3C 940 (GBe) and VIA PHY (10/100)
• Onboard native Serial ATA support for 2 drives (including RAID) through VT8237
• Onboard P80P diagnostics LED
• 12v adapted power scheme for CPU voltage
• Onboard Coaxial and Optical SPDIF outputs
• Ability to run both 32bit and 64bit operating systems natively
Power BIOS features
• Fully adjustable Voltage scheme with VDimm and VccCore
• Fully adjustable Frequency scheme and fine memory hone.
• Magic Flash for web BIOS update
• Magic Screen for custom boot display
• Magic Health for quick reading of vital measurements at POST
Vseeno pa:
• 5x PCI slots
• Onboard SATA with
Power BIOS features
nodes ::
Kolikor sem spremljal sceno mal nazaj, naj bi bila to najbolj sprejemljiva plošča za S754 (na mojo žalost spet VIA).
Ta S754 malo omejuje nadgradnjo, zna zarezat nove smernice, tako, da ga jaz ne bi kar takoj odpisal.
trenutno ma VIA najbolsi in najcenejsi chipset za a64 platformo. upam da tuki ne bo tok razlike med chipseti, zaradi odsotnosti pomnilniskega kontrolerja.
s754 bo verjetno v obtoko precej casa...logicno...zaradi cene procesorjev.
Clemento ::
Ne zamenjam plat(nf7-s, 8rda+) dokler ne bo gor pci-express....
*Epox 8rda+, XP2600+@stock speed, TT Silent Boost, AS5, Ati AH3650
*Abit NF7-S, XP2500+@2425Mhz, 1.85V(220x11), TT Volcano 12, AS5, Rage128PRO
kuglvinkl ::
Pred naslednjim Comdexom takih plat verjetno ne bo. Tam ene H1 2005 IMHO. Pa še je*eni BTX utegne priti mimo...
kuglvinkl ::
Kaj je z njim narobi?
ATX je čist ena štala.
Najprej pragmatično. Treba bo zamenjat kišto in trafo (45k SIT).
+ vidiš kje genialnost rešitve v primerjavi z ATXom?
kuglvinkl ::
Sicer pa, plate so začele deževat. Glejte na PCStats.com.
nodes ::
Menjati bo potrebno samo Kišto, ki bo imela prezračevalni kanal v katerega bodo speljani fluidni hladilniki. Ne bo potrebno več sedem ventov za odvod toplote
kuglvinkl ::
Tudi sedaj jih ni potrebno. Ne pravim, da je ATX bog in batina in da so vsakršne spremembe brezveze, predvidevam pa da bo prišlo še do sprememb in bi bila vsaj z modom BTX plata sprejemljiva za ATX kišto. No ja, upam.
In, IIRC bo treba menjat trafo v določenih primerih (Anand).
Sicer pa, sva zašla... Če češ, odpreva novo temo?
nodes ::
Sva zašla, sam jaz za tabo, tako še tole;
V moji škatli je bilo 12 ventilatorjev in še vedno je bila temperatura 50 stopinj. sama čreva.
Prvo bi jaz menjal tole skuprcalo
| » | Sempron 2,8 Ghz?Oddelek: Pomoč in nasveti | 1941 (1551) | Blinder |
| » | ASUS ploščaOddelek: Pomoč in nasveti | 2185 (1917) | AngelOfDeath |
| » | Je ta konfig OK? Hitra pomoč potrebnaOddelek: Kaj kupiti | 2324 (2129) | Area_51 |
| » | Mnenje o plati EPOX 8KRA2+Oddelek: Kaj kupiti | 1472 (1409) | Zako |
| » | Epox prenehal s proizvodnjo 8RDA+ :(Oddelek: Strojna oprema | 2638 (2216) | OwcA |
