Forum » Pomoč in nasveti » NA POMOC!!! Gigabyte ex58 ud5
djmeethra2 ::
mam plato gigabyte ex58ud5... updatov sm bios iz F9 NA F13. not sm dau tud grafo, ki je bla mjhn premocna gkede na moj napajalc, 450W. in od tedaj je plata v bootloopu.se zazene, pride do spmashscreena, poj se pa ugasne. i ovo na novo... prej sm biu na asus plate navajen, pa sm presaltou na gigabyte.. je LGA1366, ki je bla skos moja zelja jo met. . A MI LOH KDO POMAGA PROSIM???!
djmeethra2 ::
Zodiac- sm probal vse zadewe, od reset cmosa, odstranu bat., po en ram not..na lcdju napise C 1.a je mozn da je ves ram fuc? sm pa tud prklopu grafo gor, 7980 3gb vram... PSU je 450w, grafa pa nuca +450w..... a je mozn da sm updatov bad bios? iz F9 na F13..
HAN-- vem da je zastarela platforma, ampak nekak sm zalublen v 1366 ...
a se splaca kupit asus p7h55 +procesor+hladilnik????
nucam komp za produkcijo muske(ne lih pro),za duso... obcasn kksn horror game, nameravam pa kupit Oculusov VR...
vrz to v smeti oz. bolho in kupi nekaj drugega. ce si zaljubljen v stare workstation platforme, imas na aliexpressu komplete z x79, xeoni in ddr3 rami
vlagat kakrsn kol cent v to staro platformo je strel v glavo, koleno in mednozje
- spremenil: iloveboobz ()
JH84 ::
Vlagat ni smiselno, se pa 1366 še danes več kot solidno drži...Kak 920 D0 je kamot navit na 4 giga...in zadeva deluje čisto spodobno
Xserces ::
Method 1
Shut off your computer
Hold the power button until your computer starts and shuts down again
Press the power button again, your backup BIOS should kick in now and should re-flash the backup BIOS if there's anything wrong with the new one.
Method 2
Hold the power AND the reset button for about 10 sec, than release.
It should boot into the backup BIOS now.
Method 3
Only use this if nothing else works.
Short out pins 1 and 6 on the main BIOS chip by attaching a jumper to both the pins (pin #1 should be marked with a red dot or whatever)
Tell a friend to press the power on button while you do this because right now you are holding the jumper on the pins
Remove the jumper you're holding between pins 1 and 6 as soon as you hear a beep.
Backup BIOS should boot now.
TehDucky ::
Sem že na drugi Gigabyte X58 UD5 matični, v prvo je 2x strela usekala in je izdihnila. i7 920 D0 pa je ok procesor, samo mi je že cela platforma stara, nimam niti USB 3.0.
Probaj kar je kolega Xserces prilepil, (lahko daš še direkten link, kje si našel), potem pa menjat komponente po vrsti, da vidiš kaj je hin.
Han ::
Zdaj imaš vsaj tehten razlog za menjavo. Aktualne plate, procesorji, NVMe SSD (!), RTX grafika... so za nekaj razredov boljši. Močno dvomim, da bi Oculus deloval na 10+ let stari platformi.
mailer ::
Odstrani grafiko in rame, če prideš v bios izberi tovarniške nastavitve. Če se plata ne postavi je mogoče problem v napajalcu. Ko boš to preveril raziskuješ naprej če je problem v biosu, mogoče si izbral za kakšno drugo plato istega proizvaljalca in ne deluje, lahko naložiš nazaj F9 in preveriš če deluje. Grafično in rame preveri kje drugje. Mogoče je plata tudi izdihnila zaradi grafične. Če si kupil rabljeno grafiko je morda kje stik in je prav tako fuč.
Xserces ::
Dejansko nikjer ne najdem official gigabyte manuala za dual bios funkcijo(MSI ima fizično stikalo na sami plati). Je omenjena in baje "avtomatsko" boota iz drugega čipa če prvi ni ok. Je pa to nek forum ki sem spotoma najdu. Je bolj na splošno
Link
- spremenil: Xserces ()
Vuli ::
Here's what I think the codes mean:
C1 is a memory check, if it gets stuck here then your memory is at fault.
25= innitialise VGA
26 = POST complete
58 = BIOS
FF = booting/normal operation.
25= innitialise VGA
26 = POST complete
58 = BIOS
| » | Pokvarjene plošče zaradi "zmaličenih" BIOSovOddelek: Navijanje | 4384 (1700) | sbawe64 |
| » | Računalnik se Restarta v nedogledOddelek: Pomoč in nasveti | 2901 (2642) | nsa_ag3nt |
| » | Gigabyte dualbios in re-flashOddelek: Strojna oprema | 2017 (1984) | Sami |
| » | računalnik se ne bootaOddelek: Strojna oprema | 1628 (1527) | IvoJan |
| » | Kako flešat bios brez disketnika?Oddelek: Pomoč in nasveti | 1471 (1328) | m.i.h.a. |
