Forum » Programiranje » [c++] Dve niti noceta komunicirati
goranv ::
Namen je ustvariti dve niti, katerima posljem njen id in od druge niti. Nato vsaka nit sama sebi poslje dva msg. Problem je nobena nit mi nic ne izpise, razen ce dodam Sleep( 10 ) v funkciji Start() dobim samo dve sporocili
[id: 0] ldwOtherId: 8844
[id: 0] ldwOtherId: 9164
#define THRD_MESSAGE_START WM_USER + 1
#define THRD_MESSAGE_SET WM_USER + 2
#define THRD_MESSAGE_GET WM_USER + 3
#define THRD_MESSAGE_END WM_USER + 4
#define THRD_WPARAM_SET_OTHER_ID 1
#define THRD_WPARAM_SET_OWN_ID 2
HANDLE ghMutex;
LPCTSTR lpszMutex = L"enassa";
DWORD ThreadFunc( _In_opt_ PVOID lp )
MSG lmsg;
DWORD ldwOwnId = 0,
ldwOtherId = 0;
bool lInitFinish = false,
ldone = false;
HANDLE hMutex = OpenMutex( MUTEX_ALL_ACCESS, FALSE, lpszMutex );
while( !ldone )
while( GetMessage( &lmsg, 0, THRD_MESSAGE_START, THRD_MESSAGE_END ) > 0 )
switch( lmsg.message )
case THRD_MESSAGE_START:
if( lInitFinish )
WaitForSingleObject( hMutex, INFINITE );
printf( "[id: %d] [%d]\n", ldwOwnId, GetTickCount() );
ReleaseMutex( hMutex );
ldone = true;
break;
case THRD_MESSAGE_SET:
switch( lmsg.wParam )
case THRD_WPARAM_SET_OTHER_ID:
ldwOtherId = (DWORD)lmsg.lParam;
printf( "[id: %d] ldwOtherId: %u\n", ldwOwnId, ldwOtherId );
if( ldwOwnId != 0 )
PTMSG( ldwOtherId, THRD_MESSAGE_GET, TRUE, 0 );
break;
case THRD_WPARAM_SET_OWN_ID:
ldwOwnId = (DWORD)lmsg.lParam;
printf( "[id: %d] ldwOwnId: %u\n", ldwOwnId, ldwOwnId );
if( ldwOtherId != 0 )
break;
break;
case THRD_MESSAGE_GET:
// osnovne vrednosti nastavljene
if( lmsg.wParam == TRUE )
lInitFinish = true;
printf( "[id: %d] lInitFinish: %d\n", ldwOwnId, lInitFinish );
PTMSG( ldwOwnId, THRD_MESSAGE_START, 0, 0 );
break;
case THRD_MESSAGE_END:
break;
Sleep( 1 );
printf( "[id: %d] ExitThread\n", ldwOwnId );
CloseHandle( hMutex );
ExitThread( 0 );
Test1 :: Test1()
pHandles[0] = pHandles[1] = NULL;
void Test1 :: Start()
// private:
// Thread thr[2];
// HANDLE pHandles[2];
ghMutex = CreateMutex( NULL, FALSE, lpszMutex );
if( ghMutex == NULL )
printf( "ghMutex\n" );
thr[0].Create( ThreadFunc );
thr[1].Create( ThreadFunc );
thr[0].Send( THRD_MESSAGE_SET, THRD_WPARAM_SET_OWN_ID, thr[0].GetId() );
thr[1].Send( THRD_MESSAGE_SET, THRD_WPARAM_SET_OWN_ID, thr[1].GetId() );
Sleep( 10 );
thr[0].Send( THRD_MESSAGE_SET, THRD_WPARAM_SET_OTHER_ID, thr[1].GetId() );
thr[1].Send( THRD_MESSAGE_SET, THRD_WPARAM_SET_OTHER_ID, thr[0].GetId() );
Sleep( 10 );
pHandles[0] = thr[0].GetHandle();
pHandles[1] = thr[1].GetHandle();
WaitForMultipleObjects( 2, pHandles, TRUE, -1 );
CloseHandle( ghMutex );
// Thread.h
typedef struct ThreadInfo
HANDLE h; // handle
DWORD id; // id thread
PVOID lp; // lparam thread
} THREADINFO, *PTHREADINFO;
class Thread
ThreadInfo ti;
public:
Thread();
~Thread();
@param nFlags, 0 - run, CREATE_SUSPENDED - paused
_Success_( return == true )
bool Create(
_In_ LPTHREAD_START_ROUTINE pFunc,
_In_opt_ PVOID nParam = nullptr,
_In_opt_ DWORD nFlags = 0 );
void Send(
_In_ DWORD ndwMsg,
_In_ WPARAM nwParam,
_In_ LPARAM nlParam ) const;
_Success_( return > 0 ) DWORD GetId() const;
_Success_( return > 0 ) HANDLE GetHandle() const;
// Thread.cpp
Thread :: Thread()
ti.h = NULL;
ti.id = 0;
ti.lp = 0;
Thread :: ~Thread()
if( ti.h != NULL )
CloseHandle( ti.h );
ti.h = NULL;
ti.id = 0;
if( ti.lp != nullptr )
HeapFree( GetProcessHeap(), 0, ti.lp );
ti.lp = 0;
bool Thread :: Create(
_In_opt_ PVOID nParam,
_In_opt_ DWORD nFlags )
ti.h = CreateThread( nullptr, 0, pFunc, nParam, nFlags, &ti.id );
if( ti.h != NULL )
return true;
return false;
void Thread :: Send(
_In_ DWORD ndwMsg,
PTMSG( ti.id, ndwMsg, nwParam, nlParam );
DWORD Thread :: GetId() const
return ti.id;
HANDLE Thread :: GetHandle() const
return ti.h;
| » | [Java] Objekt poslan k metodi v kakšnem stanju?Oddelek: Programiranje | 1924 (1371) | shadeX |
| » | slovenski prevodi programerskih izrazovOddelek: Programiranje | 4578 (3513) | sverde21 |
| » | Komunikacija med thread-iOddelek: Programiranje | 4381 (4187) | zlatko |
| » | OpenGL orr v ansi cOddelek: Programiranje | 2168 (1956) | igor12 |
| » | Odpiranje dat.exe v VBOddelek: Programiranje | 3851 (3644) | webblod |
