JohnyQ_ ::
Russia’s War Machine is running OUT of GAS Literally. The petro-State is running on Fumes
Russia’s October oil and gas revenues crashed 27% YoY another brutal hit to the Kremlin’s budget as sanctions tighten and the ruble surges, The Moscow Times reports.
Moscow pulled in 888.6B RUB ($10.9B) — down 322B RUB from last year.
The core extraction tax plunged 26%. Total 2025 energy income is now 7.5T RUB, a massive 2T RUB below 2024 — and the drop is accelerating
That is thanks to the fact that Washington finally went for Russia’s crown jewels: Rosneft and Lukoil, which exported over half of all crude.
Add other sanctioned giants and and we have appr. 70% of Russia’s barrels are now tainted
Even a 5–10% export dip could blow a 120B RUB/month hole in Putin’s budget
Kremlin’s fantasy budget: 10.9T RUB
Reality check: 8.6T RUB
No rebound expected through 2028.
Meanwhile, the ruble’s rebound is its own poison — making every dollar of oil worth less at home.
BOTTOM of the BARREL: Sanctions biting Revenue sinking Fiscal pressure rising
If prices don’t rise or sanctions don’t break, Putin may be forced to
torch reserves (of which he does not have much anymore),
borrow heavily (printing the money which will shoot inflation up or borrow from China, which will come with a very high interest both economic and possibly political too)
or scale back the war he swore he’d never lose.
From an economic perspetive, the Kremlin is bleeding money and time.
bbbbbb2024 je izjavil:
V vsakem primeru je Pokrovsk trenutno izredno nevaren za obe strani. Obe strani sta tudi politicno investirani in ne striktno za vojaske odlocitve.
+1
Podpišem!
Pokrovsk je zdaj mesto nacionalnega ponosa.
Ukrajinci da ga obranijo, Rusi da ga zavzamejo.
Je pa Pokrovsk zadnje mesto, kjer je neka resna obrambna črta s trdnjavami, jarki. Ko to Rusi prebijejo, naj bi bilo vse lažje.
Čas bo pokazal svoje... Ampak trenutno Ukrajinci mečejo v Pokrovsk in Kupjansk večino vojske, Na drugih frontah pa Rusi počasi napredujejo. Stepnohirk, Vovčansk, pa še par lokacij....
o0o0o0o0o0 ::
+1
Podpišem!
Že tri leta si delaš sramoto s svojimi napovedmi. Pejta s talibancem brat ruske bote na twitter
Windlass ::
Ukrajincem bi sedaj še kako prav prišlo tistih 30 obkoljenih brigad.
Pa tisti roji radioaktivnih komarjev
Ko smo že ravno pri slovenskih putinistih danes.. A je kdo opazil (na X ali na bilokaterem novičarskem portalu), da ko se približuje zasedba nekega bolj odmevnega kraja v Ukrajini (kot npr. zdaj Pokrovsk) in se v ruski propagandi seveda pojavi rusko ime za to mesto (v tem primeru Krasnoaramejsk), začnejo te večni proruski komentatorji nemudoma uporabljat rusko ime in ne tisto, pod katerim se pogovarjamo že ves čas.
Isto je bilo recimo pri Bahmutu - takoj ko so slišali nek Putinov nagovor, kjer je uporabil ime Artemovsk je del MMC falange instant prešaltal na to ime, da najprej sploh moraš dešifrirat o čem lapajo..
Men to tko sluzasto in fanatično izpade glede na to da so slovenci... mislim, za kozlat. A še koga moti al mam samo jaz ta pet peeve?
JohnyQ_ ::
ModriMiha ::
Ni se konec bitke za Pokrovsk...
Ukrainian soldiers raise flag on Pokrovsk city council building
https://kyivindependent.com/ukraine-war...
Čas prve prijave04.10.2025 23:08:35
Bote ima večina EU&UA
Sedaj med padcem bodo podivjali, z najbolj znanimi frazami...3 dni do Kijeva itn.
Če bi temo spucali ne bi bilo 10 strani vsebine![]()
Dober si mi ti
Windlass ::
Goran10 ::
Hm, js pa ne opažam kaj posebnega na X te dni. Sledim vidnejšim akterjem obeh polov v Sloveniji, pa kakšnega posebnega pro-rusizma s slovenske strani ne vidim. Samo v komentarjih pišejo kakšne ProPutinske ogabnosti sem pa tja.
Se pa najdejo v zavihku ˝For you˝ razni Lord Beboti in podobni primerki ampak se mi ne zdi huje kot po navadi. MMCjevci so pa faking nadležni, ker kar vidiš pod vsako novico kako hlepijo, da bi ta nesrečni Pokrovsk vendarle okupirali.
Meni so feed rasfukal v prafaktorje ne spoznam novih pametnih ustvarjalcev. Recimo take zadeve fašem
This is China.🇨🇳
China is proof that socialism works.
As for Cuba, Venezuala and other examples, they may have worked if the US government hadn't spent TRILLIONS of dollars to prevent their success.
Seveda zraven dodan video kjer so stolpnice in lučke-kitajska klasika. Zadeva res izgleda slaboumno.
https://x.com/ShangguanJiewen/status/19...
Tako da ja moram striktno gledat zadeve ki jih sledim. For you feed je samo še slaboumna kitajsko ruska propaganda.
- spremenilo: Goran10 ()
A so tudi danes Rusi zasedli Pokrovsk ?
Ne še, danes ga bodo zasedli ob 20.30Jutri pa malo prej, verjetno popoldne.
Grem stavit, da ima Vasev že več kot eno leto spisan zmagoslavni članek o zasedbi in ga kar prsti srbijo da bi dal na svetlo ta svoj magnum opus od članka.![]()
Ukrajinski X kanal:
https://x.com/EuromaidanPress/status/19...
"Ukrainian elite forces deployed into Pokrovsk—not to counterattack, but to cover a retreat
425th Assault & 82nd Airborne hold 3km corridor open while decimated brigades flee on foot through Russian drone fire. Year-long battle for the city ends in days"
Goran10 ::
Men to tko sluzasto in fanatično izpade glede na to da so slovenci... mislim, za kozlat. A še koga moti al mam samo jaz ta pet peeve?![]()
Za bahmut sem jaz isto opazil. Ruski papagaji dobesedno vse skopirajo kar jim Putin pove. Zadeva res spominja na verski kult sploh ko začnejo da bo resnica prišla na plano in da jo mediji cenzurirajo. Ja fak model kako si pa ti potem prišel do nje?
Windlass ::
This is China.🇨🇳
Uf. Slaba. No, saj nazore Elona in njegovega fotra verjetno poznaš, tako da verjetno se za čudit ni. Če bi obveljalo po Muskovo bi se delala posla s Kitajci, nažiralo kaviarja in prostitutk v Moskvi... medtem se naj pa luzerska EU in Ukrajina j***jo. Po mojem je blazno nesrečen da ne sme ugasnit Starlinka za Ukrajino, ker bi ga preveč stalo v Teslinih delnicah.
Tako je, če podpiraš ruske morilce in posiljevalce. Tak pač si. Njihov.
Še video. Za nejeverne Tomaže.
Goran10 ::
Talibanc spet polira ruske škornje.
Musk je pač ruskih in kitajskih škornjev polirc. Žal.
This is China.🇨🇳
Pač. Će maš argumente postaviš video, ki prikazuje nasprotna dejstva. Pristen video, ne nareje z "Soro". Če argumentov ni, se začne z Telabancem, ki da je "peder", čistilec ruskih čevljev, in tko naprej v tem smislu.
Goran10 ::
Jebat ga resnica boli. Sploh ne vem kaj delaš na tem forumu. Spadaš med svoje na mmc forum tam se lahko pridružiš ostalim russian cock sakerjem.
Stane2 ::
https://x.com/nexta_tv/status/198644036...
Wait a second. Where's Lavrov?
-He was absent from yesterday's meeting where Putin was throwing around threats of nuclear tests. Kommersantpolitely wrote that the foreign minister was "absent by agreement."
-Almost simultaneously, Lavrov lost his status as head of the Russian delegation at the G20 summit.
-He's also vanished from the information field -- his last public statements were made in late October.
Earlier we reported that the Russian leadership is looking for those responsible for the failed Putin-Trump talks in Budapest. Lavrov has been named the main culprit.
koral45 ::
Goran10 ::
To je russian cock sucker luzaerstvo. To je čista russian boot polirec narativa poskus opravičevanja agresorja in poniževanja tistih, ki se branijo.
Polirci resnice preprosto ne prenesejo dejstva, da se Ukrajinci niso pokorili.
Namesto da bi v njihovem pogumu prepoznali herojstvo, jih zaničujejo in zmerjajo.
Ker resnica, ki se ne ukloni, zanje vedno pomeni madež, ki ga je treba zloščiti stran.
Enostavno se polirci resnice ne morejo sprijazniti da se Ukrajinci noćejo predati.
Windlass ::
Zakaj pa ni "bilo lažje" takrat ko je padel Bakhmut? In potem ko je padla Avdiika? Čisto vsakič je blo govora, da bo potem šlo lažje...
To je cope. Vedno se lahko skonstruira nove obrambne linije, na novo utrdi vasi, če le to naredijo dovolj zgodaj. Ukrajinci so bolj omejeni z živo silo, moralo in milostjo/nemilostjo zaveznic.
Veliko bolj kot cela ta obrambna linija v Donbasu bi bil Rusom vredna obrambna linija v Washingtonu. To je tisto kar bo neslo Ukrajince (če kaj).
dexterboy ::
To je russian cock sucker luzaerstvo. To je čista russian boot polirec narativa poskus opravičevanja agresorja in poniževanja tistih, ki se branijo.Imaš čisto prav! Vse, ki ne sovražijo Ruse, je treba označiti in poslati v geto! Pa še kasneje, ko se bodo prosto gibali, bodo morali obvezno nosti trak na levi roki. Le da bo to pot 2barvni, v barvah neupogljive domovine Ukrajine!
JohnyQ_ ::
Tudi za Bakhmut smo poslušali, ko bo padel se Rusi samo še zapeljejoyv Kijev.
Sedaj leto in pol kasneje pa so še kar zataknjeni.
Nihče ne sovraži rusov kar tako.
Ne bomo jim pa ploskali ko napadajo sosednjo državo.
Če misliš da je ruski napad na Ukrajino nekaj pozitivnega ti lahko samo rečem da si debil.
- spremenil: JohnyQ_ ()
https://arstechnica.com/space/2025/11/a... ... Yay rusko raketarstvo ... Globoko so zabredli ...
Mene čudi od kje ukrajincem tak upor proti rusom? Že ENO leto rusofili vse povsod trobijo, da je ukrajini zmanjkalo vojakov, da se borijo še samo starčki... Ne vem no... Zjasnite se že enkrat - je ruska vojska tako zanič, da jih ti ukrajinski starčki šolajo, ali pa kokodakate laži, ki vam jih servirajo ruski plačanci, da vam perejo tisto malo možgančkov, ki jih še imate? Zanimivo je tudi, ko ukrajinski in zahodni medij napiše kaj, kjer se kasneje izkaže, da morda pa le ni bilo vse tako, kot so prikazovali (recimo kaj vse so ukrajinci rusom uničili, a škoda je bila veliko manjša) in rusofili takoj govorijo o zahodnih lažeh, se norčujejo itd... Ko pa ruski mediji in sam kremelj lažejo na dnevmi ravni, pa se izkaže, da so imeli zahodni mediji prav, takrat pa rusofilići pozabijo na te ruske laži.
Goran10 ::
Nekateri se skrivajo za retoriko miru in nevtralnosti ko jih povprašaš kaj s tem mislijo se na koncu izkaže da so polirno pasto samo malo bolj skrivali. To je tipičen odziv mnogih v vzhodni evropi ker jim je bila suverenost podarjena s strani zahoda zdaj pa ne vedo kaj bi z njo počeli in raje polirajo ruske škornje z njo.
JohnyQ_ ::
Oh no, trouble is paradise. Elvira Nabiullina’s super high interest rates is causing banks to turn down 60% of mortgage requests from young families who can’t afford to pay for it with mutual wages.
Elvira, where are the Eastern Orthodox believers gonna have their traditional babies? In the cow pastures? They can’t live on the streets because as Russian trolls can’t stop telling you there are no hobos in Moscow.
Elvira, the governess of the Central Bank of Russia, recently expressed her displeasure that Russians are paid too much at work.
According to her, they then grab their wallets and go to the shops and Oh heavens! spend money on stuff! What are they gonna do next to destroy Russian economy? Do MORE shopping?
The shopping, Elvira claims, accelerates inflation, which she’s fighting tooth and nail. The shopping as well as construction business should all cease to exist to improve the health of economy.
I guess this is what communist professors had taught Elvira in Moscow State University, then part of the Soviet Union.
Ooooopsie
Kot zanimivost ...
... me prav zanima, kako bi bil obarvana naša karta; ironično zgleda nas je Tito rešil, da nismo čisto kot oni
Vzhod Nemčije je že zdavnaj spoznal, da ga je Zahod nategnil...
Pobral najboljši folk in jih preselil k sebi, uničil praktično vsa dobra vzhodnonemška podjetja in jih poceni razprodal ter pozabil na njih.
Zato pač ne bodo sledili tej LGBT, woke, DEI, proukro politiki.
bbbbbb2024 ::
No, to ni nekaj novega, niti nepričakovanega. V grobem, ko so Američani prisilno upokojili Space Shuttle, ki je še imel pred sabo 20 let delovne dobe (morda ne ti modeli, bi nove zgradili), so Američani čez noč ostali brez pogona njihovega raketnega programa.
Zakaj so to Američani storili, se ne ve, jasno je da je bila zadnja nesreča Space Shuttla (odlom kosa ledu, ki je zadel krilo) bila preprečljiva in tudi popravljiva. Če malo špekuliram, morda so Boeing in LM in kar je vesoljskih kekcev računali, da se bo vsula pod nujno gora denarja, za razvoj Space Shuttle 2.0.
No, to se ni zgodilo in Američani so pragmatično motorje za rakete kupili pri Rusih, natančneje pri Roskosmosu. Za mednarodne obveznosti (ISS) pa so kar plačali Rusom za vse polete. Ni pretirano, če rečemo, da je v enem obdobju 80% vsega vesoljskega dogajalo pri Roskosmosu, ki so na debelo kasirali.
To je trajalo nekih 20+ let, kar je sicer dosti.
Nakar so se Američani začeli zavedati, saj to so se zavedali že prej, da jim denar na debelo uhaja skozi to Roskosmos luknjo in potem so dali denar za R&D. Nekaj Boeing, nekaj SpaceX, ki je v bistvu skopiral (konceptualno) ruse:
SpaceX Raptor @ Wikipedia
In prihodki Roskosmosa v dolarjih so šli na 0. In od takrat (cca 5 let) gre vse k vragu. Sama rusija ne uspe financirati vesolje, Kitajci to delajo po svoje, Evropejci imajo Arianne, drugih pa ni. Japonci imajo nekaj svojega, nekaj v miksu z ZDA.
In sedaj vsi grandiozni plani Roskosmosa padajo v vodo. Tukaj, konkretno, pa je problem, da ima izvajalec premalo denarja, da bi zgradil vzletišče, ki ga je zgradil, a je dolžan 500.000 EUR za elektriko. In to je to.
- spremenilo: bbbbbb2024 ()
AvtoR ::
"... komunizem povzroči trajne posledice na mentalnem nivoju."
Imaš prav. Nekateri se ga spominjajo z nostalgijo, drugi ga sovražijo brez racionalnih razlogov, tretji ga jemljemo takšnega kot je bil in gledamo naprej.
Pri zgornji sliki je več razlogov, zakaj je takšna kot je, nekateri gledate preozko in po svojih predsodkih.
mikhaair ::
No daj, nastej vec teh razlogov, da vidimo kolk smo ozki.
cleanac ::
Potrebno je povedati, da volilna karta ne predstavlja večine, kar si oboževalci ruskih morilcev radi predstavljajo, temveč najvišji odstotek dobljenih glasov. Berlin seveda ignorirajo.
Gospodarstvo v NDR je bilo nekonkurenčno proti ZRN, številne firme propadale,... Zahod je pokupil, kar je bilo še kaj vredno, ljudi, ki so jih rabili, so jih "prestavili" na zahod, vlaganj na V je bilo bolj malo, ... vzvišenost zahoda nad vzhodom,.... tako da je še sedaj po 35+ letih V del ZRN v slabšem gospodarskem, ekonomskem stanju, kar so boljši pogoji za stranke tipa AfD.
asinhronc ::
Kot zanimivost ...
... me prav zanima, kako bi bil obarvana naša karta; ironično zgleda nas je Tito rešil, da nismo čisto kot oni![]()
V bisvtu karto je kar enostavno pojasniti. Vzhod Nemčije je nekaj povsem drugega. Določeni starejši ljudje imajo občutek, da so v svinčenih časih dobili več, je bilo za njih bolje poskrbljeno, lažji dostop do tega in onega. Jasno svet je takrat tekel počasneje. Potem pa je prišel padec železne zavese in upanje da bo enako kot so takrat gledali na bogati zahod. Zid takrat ni pomenil da nisi smel čez, le papir si mogel dobiti pa je šlo. V vseh teh letih pa vzhod nikoli ni dosegel stopnje zahoda, enostavo razvojno in po številkah še vedno precej zaostajajo, na zahodu jih tudi gledajo malo drugače, saj morajo bogatejše dežele financirat revnejše, zato navdušenje pada, raste pa seveda tudi nostalgija. V CDU ne vidijo perspektive, ti preveč dajejo na lobije iz zahoda, vsa propadla industrija iz vzhoda je le pogorišče, kjer ne raste nič konkretnega, kapitalzem ti seveda daje polno rit neumnih stvari, vendar pa dobiš vse manj, stroški gredo gor, Merz sedaj žuga z upokojitvijo šele pri 70 letih, višina pokojnin tudi ne dosega več standarda za normalno življenje, sploh ženske imajo zelo slabe pogoje... Če dodaš vse kar so imeli v prejšnjem času, je jasno da iščejo nekaj kar se lepo sliši po preteklih časih. Mladi? Nimajo veliko možnosti za uspeh, razen če se preselijo. Berlin je tudi postal mesto, ki so ga Nemci preprosto zasovražili. Je drek od mesta, priseljencev je preveč in tako iščejo novo obliko politike in zgolj na tem AfD raste. Populizem temu rečemo, ker realno pa jim na koncu ne bodo ponudili kaj bistvenega. Gospodarski lobij ta velikih podjetij v Nemčiji je postal preveč povezan s politiko. Se spomnimo FPD? Imeli so svoj program, najboljši rezultat ravno na začetku, vendar na koncu ravno zaradi tega, ker so zgolj pritiskali gumbe po naročilu CDU/SPD, sedaj dokončno izpadli iz Bundestaga. Tu je potem ta razlika v politiki in med zahodom in vzhodom.
Svinčeni časi so seveda bili kruti, ampak večina je dobila lažen občutek da ta vsaj nekako skrbi za tebe, ker se je non stop nekaj gradilo (pa magari le pet nadstropne stavbe, da so privarčevali na dvigalu, ki je bil obvezen z šest ali več nadstropno stavbo, Hruščovke so lep primer
Promo za prijavo v enote brezpilotnih sistemov:
https://x.com/414magyarbirds/status/198...
Madžarova posodobitev:
V prvem tednu smo prejeli 4954 prijav za vstop v @usf_army – eno prijavo na vsaki 2 minuti od začetka.
Brez rožnatih očal – pred letom in pol, ko je potekal še nabor za 414. samostojni polk, Madžarove Ptice, je bilo povpraševanje 50 ljudi na prosto mesto, mi pa smo jih izbrali le nekaj sto.
Sedaj iščemo več kot 15.000 ljudi za celotno vejo – 12 enot USF. Časi so se spremenili – vojna se nadaljuje.
V teh 18 mesecih so Ptice izgubile 27 tovarišev (manj kot 1 % osebja enote) – večni spomin na padle junake.
V istem obdobju smo uničili 24.895 črvov in zadeli ali nevtralizirali 76.950 ciljev – sile in sredstva dveh polnih sovražnih vojaških korpusov.
Za vsakega od naših tovarišev je sovražnik plačal 1.000 črvov – to je cena maščevanja.
Trenutno – zaposlovanje (stanje ob 11:00, 7. novembra 2025):
Prejetih – 4 954, od tega:
• Civilisti – 2 040
• Vojaki – 2 335
• Osebje, ki je že v enotah USF – 579
Obdelano – 3 795 prijav.
Posredovano enotam – 652.
V začetni komunikaciji s kandidati – 1 078.
Opomba – polovica teh so specialisti iz civilnega življenja, kar pomeni, da ne iščemo samo »Rambov«.
Potrebujemo geeke – velike možgane in spretne roke – ni nujno, da je vse to v eni osebi.
Iščemo tiste, ki niso še nikoli držali puške – le »miško« – tiste, ki se bodo borili, ne da bi zapustili svoj monitor ali tablico.
Potrebujemo ljudi, ki bodo – z uporabo dronov – neusmiljeno uničevali črvičke na daljavo – z ognjem v očeh in sovraštvom do sovražnika.
Tako sposobne kot naši bratje in sestre v tem videu – ki so se že pridružili USF.
Nehajte bežati pred vojsko – poletite – pridružite se silam brezpilotnih sistemov.
Potrebujemo vas tukaj in zdaj – služili boste tam, kjer boste izbrali, in kot boste izbrali sami.
Leif ::
Nekako tako se je čez noč začelo uporabljati Kyiv namesto Kiev.
Današnji podporniki rusije aka. "mirovniki" bi v času, ko je bila vb sama proti nemčiji tudi churchilla verjetno označevali za wormongerja, ki podaljšuje vojno.
Jasno. Ukrajinci so (ponovno) dokazali, da so narod drugacen od Rusov in so v tej tezki vojni ze dokazali, da bodo obdrzali svojo drzavnost in svoj sistem. Tudi, ce izgubijo to vojno. Zakaj bi potem njihova mesta pisali po rusko - oz. zelijo, da v anglescini uporabljajo koren iz ukrajinskega korena.
Kaj tocno nas stane, da jim ugodimo?
- spremenil: kow ()
Ooooopsie![]()
Upsi nepoznavalec:
RU
Home Ownership Rate in Russia increased to 92.60 percent in 2023 from 92 percent in 2022. Home Ownership Rate in Russia averaged 84.99 percent from 2000 until 2023, reaching an all time high of 92.60 percent in 2023 and a record low of 58.20 percent in 2000
DE
Home Ownership Rate in Germany decreased to 47.20 percent in 2024 from 47.60 percent in 2023. Home Ownership Rate in Germany averaged 51.05 percent from 2005 until 2024, reaching an all time high of 53.40 percent in 2011 and a record low of 46.50 percent in 2022.
Leif ::
Saj pravim, precej ista mentaliteta
floyd1 ::
Ooooopsie![]()
Upsi nepoznavalec:
RU
DE
Niti ni presenečenje.
