Evropa odpira mošnjiček:
Today, Sweden presented its largest military support package to Ukraine to date, valued at almost $1.6 billion. The package includes, among other things, support for Ukraine's air defence, artillery, satellite communications, and maritime capacity.
https://x.com/PlJonson/status/190666271...
The Netherlands will allocate 500 million euros to Ukraine for the "Drone Line" project.
The project main directions are to create a zone of destruction to a depth of 10-15 km from the line of combat contact, which will complicate the enemy's advance without significant losses.
At the same time, the units will receive modern equipment: drones, electronic warfare systems, transport and other necessary equipment.
https://x.com/Maks_NAFO_FELLA/status/19...
Super novica, da podpiramo Ukrajince.
- spremenil: mtosev ()
To s tem jammingom: a obstaja the ultimate jamming-proof rešitev? Signal, ki ga z ničemer ne moreš jammat?
Btw. SV ima (je imela?) neke sisteme Roland, kam to spada če primerjamo s HIMARS-i recimo (doseg v km, višina izstrelkov, moč izstrelkov)?
Tako kot so leto ali več nazaj RU motili Usa JDAMe, pa ste tedaj pisali, da to ni mogoče, da ni res, da ....
Verjetno motijo GLONASS signal, potem bomba jadra bolj na približno.
Jdam je v snovi inc voden, gps samo poveča natančnost.
Roland je bil protilatelski sistem.
Roland (missile) @ Wikipedia
- spremenilo: gozdar1 ()
Misliš tole:
Strike by a MiG-29 on the Russian underground command post. The strike was carried out using a GBU-62 precision-guided bombs. Oleshky, Kherson region
- spremenil: fur80 ()
bbbbbb2024 ::
Ukrainian countermeasures have now rendered satellite-guided corrections useless. He says bombs often miss their targets now but the problem was swept under the rug as it often happens in Russia to continue positive reports.
https://www.forbes.com/sites/davidaxe/2...
https://x.com/wartranslated/status/1894...
Sicer Rusi tega (zaenkrat) še ne znajo, to ima recimo Taurus, tudi Storm shadow ima, INS (Inertial Guidance System). Da si pomagajo inercijskimi žiroskopi, zdaj že imaš 3-osne, v obliki čipa.
Primerjaš GPS in INS, ter pač se zaneseš na INS, če se pojavi razlika v poziciji. Samo to še ne bo dovolj. Potrebujejo protizračno obrambo do 120km, Rusi pravijo, da imajo sedaj glider bombe do 180km.
Imajo pa tudi Vampir sistem, da laser pointa bombo, ter ustrelijo 70mm poceni vodeno raketo.
Seveda je vse skupaj stvar (tudi) količin. Mislim, da imajo vampirjev 12-15 lanserjev, kar je malo.
Problem je seveda rešen začasno.
Dodati je treba, da so Rusi nehali metati težke FAB-1500 iz MIG-31, ker so se strošili motorji. Sicer pa MIG-31 itak ni bil narejen za to. Imajo Su-34 - racaka, samo imajo omejene količine.
Imajo pa še sicer sicer Su-24, teh pa sicer imajo ogromno tudi Ukrajinci:
Sukhoi Su-24 @ Wikipedia
Kakšen pa je status Su-24, pa ne vem. Ukrajinci pravijo, da imajo nekje 300+ ogrodij za Su-24 in da njim Su-24 ni problem spacati skupaj.
Pa eno skladišče glider bomb so Ukrajinci vrgli v zrak.
Problem je potrebno rešiti iz več zornih kotov. Saj to Ukrajinci vedo natanko. Najbolj oni.
OutOfTheBox ::
Meni se zdi tole vse skupaj s strani Trumpa zaigrano za rajo. Že vrabčki čivkajo, da ga vleče na rusko stran. Mora nekako dati upanje in prepričati Zelenskega, da podpiše sporazum o redkih zemljah.
To bi bil Ukrajinski samomor. To kar ZDA v pogodbi zahtevajo od Ukrajine, je milorečeno izsiljevanje ( v zameno za nič). Zelensky bi s tem prodal državo ameriki.
To kar se je takrat zgodilo v ovalni pisarni, je posredovala višja sila. Ne glede na to kako slabo je zgledalo, se je Ukrajini naredila ogromna usluga.
Malo več o deal-u.
- spremenilo: OutOfTheBox ()
Z vsakim tednom oz. novim krogom pogovorov Trump&Co zahtevajo več, nekaj je bilo govora tudi o energetiki(elektrarne,...).
bbbbbb2024 ::
Budanov je razpravljal znotraj ožjega tima (menda), da bodo raztreščili jedrsko elektrarno v Zaporožju, če bi se slučajno zgodilo, da Ukrajinci elektrarne ne bi dobili nazaj. To je en svetovalec Zelenskega povedal ne vem kje nek semi-uraden intervju. Čisto možno, da si je pa izmislil. Pri Budanovu pa ni 2x za reči, da tega ne bi storil.
Verjetno je tudi Budanov za organizacijo sabotiranega Severnega toka. Zgodba gre nekako tako, da so ugotovili, da je treba ST raztreščiti, tako ali drugače. Potem je ekipa, ki menda ni imela vezi z uradnimi silami Ukrajine to tudi naredila.
Rusi se bojijo tega istega, zato so jo (menda) zasedli. To je 5700MW. Zdaj se je Rusom začelo svitati drugače. Menda bi to elektriko prodajali.
Američani se bojijo pa tega istega. Poleg tega bi (zgleda) tudi oni prodajali elektriko.
Ne vem, no. Vsem se sline cedijo do tal. Bogi Ukrajinci.
Osebno menim, da to pomeni, da bodo Ukrajinci rabili nuklearno orožje, mi pa tudi.
- spremenilo: bbbbbb2024 ()
Lahko se pogovarjajo iz kroga v krog, dokler se ne podpiše sporazume, je samo pridobivanje časa.
Ne bi se čudil, da je to taktika Zelenskega in Evrope. Zavlačevanje glede sporazuma, da se lahko Evropa pripravi, kako pomagati Ukrajini brez Amerike. Je pa trenutno sporazum med Amerike in Ukrajino samomor, isto kot prvi.
Prvi ni bil samomor, bi bili blizje EU normam, bi morali marsikaj upostevat, sicer tudi pogoje RU.
Sedaj bo vsak sporazum slabsi, izguba ozemlja, mrtvi, ranjeni, pohabljeni ljudje, unicena infrastruktura,....
Ruski pogoji so samomor aka. konec ukrajine kot države.
Dejansko je to vzrok za celo kalvarijo.
Pač ga ne bo podpisal in bo ostal brez podpore Amerike. Na to se tudi Evropa pripravlja, to je vsakim jasno.
Zakaj bi morala samo Amerika pridit do teh zemljič v Ukrajini? Evropa lahko tudi, saj rabimo te boga minerale za proizvodnje.
Na koncu Trump ne bo omehčal Putina in bo največji poraženec. Putin ni neumen in klovna se da nategnat.
bbbbbb2024 ::
Američani so na hitro dostavili cca 1200 ton materiala Ukrajini:
https://bulgarianmilitary.com/2025/03/3...
To se zdaj igrajo Američani gud kop, bed kop. Doni je gud kop.
Bed kops:
Joint Chiefs of Staff @ Wikipedia
Bed kops:
A se ni par strani nazaj razlagalo da je konec tega in je Ukrajina spušila pa da so Rusi zmagal? So Ukrajinci že zapustili ruska tla?
Stane2 ::
Ruska vojska v letu 2025
https://x.com/OSINTua/status/1905701639...
A couple of days ago RUAF attacked one of our brigades with 5 BMP-1AM and 4...MTLBu. In the same day we were attacked just by the enemy infantry (some of them even didn't have helmets and plate carriers). Without artillery support.
V letu 2024 so imeli več žrtev kot v letu 2022 in 2023 skupaj. Letos so prešaltali v novo brzino.
shmandi ::
Se je razlagalo... prav tako 100 strani nazaj, pa skoraj že 1000 tudi.
Samo zdaj pa zares baje bo 377-ti poskus 3 dnevne specialne operacije uspel... baje.
sparklyslo ::
Jaz se ne bi čudil, če Trumponja Ukrajincem namerno postavlja neke nesprejemljive pogoje, samo za to, da bi na koncu lahko rekel, da Zelenski ni za mir in da se ZDA umikajo iz pogajanj in podpore Ukrajini. To pa zato, ker bi rad supportiral Izrael v "boju" proti Hamasu, sprožal akcije proti Hutijem in bombardiral Iran in še nekoliko bolj na vzhodu oboroževal in podpiral Tajvan proti Kitajcem.
Saj iz ameriške perspektive je nadvse bebasto, da bi morali jenkiji ene par tisoč kilometrov proč podpirati boj ene države proti. Naj to počnejo njeni sosedi, aka EU.
Če bi bilo tako, ne bi že leta in leta vlagali v Ukrajino. Že Trump je v prvem mandatu prodajal orožje Ukrajini.
Ampak a ni bebasto? Dejansko tudi s perspektive EU je stvar nadvse bebasta, da morajo neki daljni sosedi reševati probleme, ki se nam porajajo pred pragom.
ššš ::
Gre se za vpliv nad regijo. Par letal s pomočjo je malenkostna cena za to, da lahko v ogromni državi kot je Ukrajina kjerkol postaviš svojo bazo.
Ampak EU pa tole gleda in ji je čisto vseeno, da neki jenkiji serjejo po njenem interesnem območju.
Aja, sj res, EU, prečudoviti brezzobi tiger, ki je zmožen producirati le testenine, šampanjce, ferarije in pršut.
bbbbbb2024 ::
Jaz se ne bi preveč naslajal nad tem. Pri Bakmutu so Rusi uporabili taktiko, da so zapornike nagnali pred cevi Ukrajincev, ki so potem s pretiranim ognjem streljali po raji. Ko so Rusi zadaj zaznali šibkost, ko so rafali postali krajši, je to pomenilo, da gre strelivo h koncu.
Nakar so napadli ruski padalci zadaj. Ukrajinci so ostali brez streliva in so se morali umakniti. Tudi Ukrajinci so se naučili kaj iz tega. Rajo so postrelili snajperji, mitraljezov niti niso uporabili. Tanke in transporterje so pokončali RPGji.
Morda so bili zadaj zopet padalci, ki so videli, da ne bo šlo zlahka. Morda. Morda pa jih ni bilo. Bolj ne, kot ja. Ampak sovražnika se ne podcenjuje.
dronyx ::
Ko so Ukrajinci zadeli letalsko bazo Engels je bilo tam kot kaže shranjeno tudi neko jedrsko orožje (ali orožje z jedrskim materialom), saj je bila zaznana povišana radioaktivnost. Ali so kje podatki kaj so zadeli in kako visoka je radioaktivnost?
jest10 ::
bbbbbb2024 ::
Švedi bodo dali 1,6 mrd $ pomoči:
https://kyivindependent.com/sweden-unve...
verjetno večino v obliki hitrih borbenih čolnov. Govorice so, da jih bodo opremili s torpedi. Švedi ne rečejo nič, SAAP pa je že rekel, da je vojna v Ukrajini testni poligon za njihovo orožje.
bbbbbb2024 ::
Vse več namigov je, da so Rusi izgubili cca 9000 oklepnih vozil in tankov v vojni in so pokurili vse zaloge vse tja do T-62 vključno. Unaccounted-for tanki (ki so bili prej poslikani, zdaj jih ni nikjer) sta dve možnosti - ali so kje skriti v halah imajo Rusi tudi nekaj hal, ali razkosani za dele. Teh je max. 1500 to je res maksimalna domneva. Noter je manj kot 100 T-90.
Link:
https://tvpworld.com/84368543/russia-ru...
Ni to edino poročilo. Tla so že trdna v Ukrajini in vendarle Rusov z oklepniki nikjer. Novih T-90 so Rusi naredili malo manj kot 300 v vseh teh letih.
Torej, vsak ruski tank, svež, ki se bo sedaj pojavil v Ukrajini, je vzet od nekje drugje iz aktivne uporabe. Pa še tu imajo Rusi maj kot 2000 tankov v uporabi po celi Rusiji, verjetno še dosti manj. Ne morejo kar poslati ne vem 50 tankov iz Novosibirska v Ukrajino.
Daleč od tega, da Rusi "zmagujejo". Daleč. To je boljkone ruska narativa.
Link:
Zanimivost, me prav zanima kaj to pomeni in v čem je trik, ali jim kaj ne štima?
Ukrainian military shot down 2/2 Kh-59/69 guided aircraft missiles at night
Russians did not launch Shahed over Ukraine at night for the first time in almost half a year.
https://x.com/front_ukrainian/status/19...
Zelensky je ugotovil, da Trumpa boli kurac za popolnoma vse razen, dobička in tega da doseže svoje. Popušča zato, da je žogica na ruski strani. Ukrajinci vedo, da Putin ne bo popustil niti za milimeter in ima rajhe, da se Trumpova četica idiotov namesto v njega fokusira v Putina in njegovo trmarjenje. Tu lahko Ukrajina samo profitira, ker bo donny odvezal mošnjiček za pomoč.
Vmes upajo, da se Evropa skocka, ter organizira podporo, ki bi lahko nadomestila Ameriško. Nakar lahko skensla Donnya in njegovo izsiljevanje če bi do tega prišlo.
Govori se tudi, da naj bi Zelenski zaradi pritiska Američanov skušal čim prej organizirat volitve z skrajšano predvolilno dobo, dokler še ima relativno visoko podporo v upanju, da premaga Poroshenk-a in Zalshny-ja (če bi le ta kandidiral).
- spremenil: Zmajc ()
Trump in Putin sta se dogovorila, sedaj je potrebno v to prepričat še UA.
bbbbbb2024 je izjavil:
Tanki nio več rusko glavno orožje, ampak fiber optic droni...
Še Rusom je potegnilo, da je s tanki v klasičnem smislu konec...
To da sta se dogovorila nekaj po telefonu ne pomeni čisto nič, dokler to ni podpisano na madnarodno priznanih papirjih tega pa v imenu Ukrajine Donny boy ne more narediti.
Niti nič ne kaže na to, da naj bi se bil Putin pripravljen odpovedat ničemur kar zahteva že od začetka vojne. Teh pogojev pa Zelensky ne bo sprejel, je že rekel, da kapitulacijo lahko gre podpisat v Moskvo brez posredovanja ZDA.
Zelensky je v marsičemer popustil, zdaj isto od Putina zahteva Donny ampak Putin tega ne namerava narediti. Zato se je zadeva ustavila pri Putinu, ne pri zelenskemu.
Ker ti ne ustreza, potem ti ne pomeni čisto nič. Imaš pa prav, dokler niso papirji podpisani, se še ne ve, kaj bo.
Motiš se pa pri tem "tega pa v imenu Ukrajine Donny boy ne more narediti". Res ne bo on osebno to naredil namesto Zelenskega ali UA, bo zrežiral da bodo Ukrajinci podpisali, ni nujno da Zelenski.
Ja ampak catch je da bo moral popustiti tudi Putin. Kar pa ni velika verjetnost.
Stanje na fronti v ničemer ne nakazuje, da naj bi se karkoli spremenili v bližnji prihodnosti.
Vse to je stvar pogajanj, kaj bo, je pa ugibanje.
To, da se Trump in Putin pogajata o tem, kako poteka vojna v Ukrajini, je naravnost komično. Že to, da greš v vojno v sosednjo državo, in potem po treh letih pristajaš na neka pogajanja z eno tretjo državo, priča o tem, da nisi imel pojma, kako končati vojno.
Primer T-90
https://www.youtube.com/shorts/nMYX5Xu6...
Fora je tudi kake vrste kamikaza dron je in vrsta exploziva, itak pa Ukrajinci tolčejo po Rusih z vsekm kar imajo pri roki.
Tukaj imaš pa drugi primer:
https://www.youtube.com/shorts/m7BWoIjc...
Maš te drone:
Še tole kot zanimivost:
Trees in one of the plantings on the front line are wrapped in fiber optic cables from Russian FPV drones.
slonneli ::
Najbolj komični so taki komentarji.
Tisti ki so vojno začeli, jo bodo tudi končali. Ukrajina je samo kmet na šahovnici in ne odloča o ničemer, niti o tem ne, kdaj se bo vojna kočala. Mal si preberi - išči pod Boris...
- predlagal izbris: connel ()
slonneli ::
Še mal večje slike: Russia has 'seized the upper hand' in Ukraine war, intel community warns
...tako da Trump očitno nima prav veliko manevrskega prostora, kar se tiče palice. Bo moral še več korenčov uporabit, da mi bo uspelo.
Ti bom jaz povedal, če ti še ni kapnilo. Ukrajinci ne verjamejo v noben dogovor z Rusi, niti jim v trenutni situaciji to ne koristi. Zelensky je skušal apelirat na Trumpovo človečnost a so mu v beli hiši na hitro dali vedet, da jih boli penis za UA narod in grozote, ki se tam dogajajo. Oni so tu samo za biznis.
Zato je Zelensky obrnil ploščo ter delno sprejel ameriške zahteve. Zdaj Trump isto zahteva od Putina tu ne vem kaj bosta zmuvila, ker Putin uradno ne more izpasti kot luzer, ki se je uklonil nekemu Trumpu.
Istočasno pa EU masovno povečuje pomoč UA.
Zato sem prepričan, da Zelensky igra dvojno igro. Upa, da diplomatski odnosi z ZDA ne propadejo istočasno pa dolgoročno ne izključuje situacije da se bo ne to zgodilo in v sodelovanju z Evropo ekspresno potekajo pogajanja nadomestiti Ameriško vojaško pomoč.
Upanja, da bo vojne konec z nekim magičnim mirovnim sporazumom so whisfull thinking.
Tako ja. Zelenski mora samo vračat žogico na rusko stran. Ne sme se pri njemu zaustavit. Tudi ta sporazum o mineralih, realno ne more tega Trump prodat kot pogoj za nek mir s Putinom. Ker kaj ima to veze z vojno? Zarad tega deala se sigurno ne bojo Rusi kar obrnili in šli domov.
- spremenil: Utk ()
Lahko ti pišeš. kaj ti misliš da bo,... realnost je pa pokazala, da tvoje pisanje ne šteje, je samo "klic vpijočega v puščavi"....
Takšnih vas je še mnogo tukaj na STR in v EU politiki, ki še naprej trmoglavo pelje EU navzdol kljub zmotam, ali pa ravno zato, ker nočejo priznati zmot in napak.
Redke zemlje v UA so pesek v oči, če bi bile omembe vredne in primerne za pridobivanje, se bi to že zgodilo, tako pa niso, je predrago. To so že Trump&Co spoznali, zato imajo na tarči še UA energetiko.
- spremenilo: fikus_ ()
JohnyQ_ ::
Zakaj pa ne bi Putin priznal zmote in napake ?
In kaj naj bi bila po tvoje pot ki pelje navzgor, to da pustimo Ukrajino Rusiji in da upamo, da čez 10 let ne pridejo na vrsto baltske države in moldavija ?
esel ::
Ker tvoje pisanje je pa izrednega pomena in bo spremenilo potek vojne.
Kjub tvojemu jokanju, je EU odločna in končno kaže hrbtenico, kar vam rusofilom seveda ne odgovarja, ker bo zagotovo dolgoročno popeljala Rusijo v pogubo, medtem ko bo Eu prosperirala.
Spet neko nakladanje, obtoževanje in označevanje, to je kot kaže tvoj mentalni doseg!
Argumentiraj zakaj je EU in proti komu odločna?! Kot odgovor na Usa carine je VDL dejala, bomo preučili.....
Usa neocon krmarila je na plečih UA in EU slabila RU (JDV je priznal, da je ta vojna v UA proksi Usa vojna proti RU), koliko smo v EU vredni je pokazala tudi "Fuck EU" Nulandova,...
slonneli ::
Govoriš kot da je to nekaj novega, naj te podučim o ostalih investitorjih, ki so hodili po Ukrajini že leta pred tem:
investitor 1
investitor 1, nova investicija
investitor 1, še ena investicija
investitor 2
investitor 2, nova investicija
investitor 3
investitor 3, nova investicija
itd...
JohnyQ_ ::
Spet ponavljaš neko slaboumno propagando.
Naj se Putin poberem iz UA pa je problem rešen.
esel ::
EU se ves čas odločno upira ruski agresiji. Podpiranje Ukrajine je odločitev večine evropskih držav, ki se zavedajo posledic ruske ekspanzionistične politike, zato tudi ne popuščajo ampak pritisk še stopnjujejo.
Dejstvo je, da je Rusija je oslabljena in dolgoročno izgublja zaradi sankcij in vojaških neuspehov.
https://www.reuters.com/world/europe/eu...
bbbbbb2024 ::
Težava Putke je, da je že od zasedbe Krima 100% svojega političnega kapitala zastavil za "Ruski mir" - ruki svet. Zdaj, 1,1 mio mrtvih in ranjenih kasneje pa kaj? Naj odstopi od zahtev? Potem je gotof.
Povedal sem že, da je to drugi največji konflikt in izguba življenj Rusije sploh, če pa se štejejo samo mrtvi vojaki, pa največje število mrtvih sploh. Ker v 2. sv.vojni so se med izgube šteli tudi zajeti Rusi, tukaj pa je št. zajetih Rusov relativno majhno.
Putka je v blatu do pasu. Tu jaz mislim, da ga niti Doni, niti nihče ne more obrniti v kakšno koli drugo smer.
Pa saj razumeš, da so recimo Finci izgubili nekaj ozemlja, Švedi nekaj v preteklosti, baltske države je okupiral v celoti. Rusija se je že spopadla z Francijo (Napoleonom). Spopadli so se Nemci, recimo. Poljake so na pol požrli Sovjeti.
Zdaj je Evropejcem jasno, da je treba Rusijo ustaviti. Razlika pa je, da se sedaj borijo Ukrajinci, zadaj pa jih na polno podpirajo Evropejci.
In to se ne bo spremenilo, ne glede kaj se Doniju plete po glavi.
Putka je imel plan, da naj Doni 'prepriča' Evropejce.
Rusi so padli v globoko jamo, da so trigerirali vse.
