Redirect na wordpress login pri odpiranju strani slovenskih železnic
M.B. ::
Od danes se mi stran slovenskih železnic www.slo-zeleznice.si ne odpre. Ob odprtju me 301 preusmeri na stran https://www.slo-zeleznice.si/index.php/..., kar me preusmeri na https://www.slo-zeleznice.si/sl/ kar me preusmeri na https://potniski.sz.si/, ki je nek vstop v wordpress
Uporabljam Firefox na Linuxu z Telemach in google DNSji. Isto se pojavi na telefonu preko Wifija in na drugem Linux računalniku v gospodinstvu.
Zanimivo da ta link odpre normalno: https://www.slo-zeleznice.si/sl/nepremi... če pa grem v menuju v potniško promet pa spet pridem prek x redirectov na wordpress login.
Sem to tudi omenil na njihovi strani za pomoč ampak pri njih vse dela. :|
mabu ~ $ http "https://www.slo-zeleznice.si"
HTTP/1.1 301 Moved Permanently
Cache-Control: no-store, no-cache, must-revalidate, post-check=0, pre-check=0, no-store, no-cache, must-revalidate, post-check=0, pre-check=0
Connection: Keep-Alive
Content-Length: 0
Content-Type: text/html; charset=utf-8
Date: Tue, 16 Jun 2020 17:04:28 GMT
Expires: Wed, 17 Aug 2005 00:00:00 GMT
Keep-Alive: timeout=5, max=100
Last-Modified: Tue, 16 Jun 2020 17:04:28 GMT
P3P: CP="NOI ADM DEV PSAi COM NAV OUR OTRo STP IND DEM"
Pragma: no-cache
Server: Apache
Set-Cookie: 4e48aed3397740e404816bd7b190ca4f=knvuktphat3vhqt2k48lup8gg4; path=/; HttpOnly
X-Content-Powered-By: K2 v2.10.2 (by JoomlaWorks)
X-Logged-In: False
mabu ~ $ http "https://www.slo-zeleznice.si/index.php/sl/"
Content-Length: 240
Content-Type: text/html; charset=iso-8859-1
Date: Tue, 16 Jun 2020 17:04:51 GMT
Server: Apache
<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
<html><head>
<title>301 Moved Permanently</title>
</head><body>
<h1>Moved Permanently</h1>
<p>The document has moved <a href="https://www.slo-zeleznice.si/sl/">here</a>.</p>
</body></html>
mabu ~ $ http "https://www.slo-zeleznice.si/sl/"
Content-Length: 231
Date: Tue, 16 Jun 2020 17:05:12 GMT
Server: Apache
<html><head>
</head><body>
<p>The document has moved <a href="https://potniski.sz.si/">here</a>.</p>
</body></html>
krho ::
Meni tude dela.. Zdej ali so popravili ali pa tebi nekaj dela narobe... Se recimo vmešava kakšen antivirus ipd.
M.B. ::
Antivirusa nimam. Predvidevam da meni dela narobe, samo ni mi jasno kaj. Saj dela isto na 2 računalnikih in Android telefonu preko Wifi in tudi 4g. Kar pomeni da DNS tud ni važn.
M.B. ::
Preizkusil in se isto dogaja tudi na domačem Windows računalniku na AWS sistemu na irskem in sodelavcu v Berlinu.
Tako da mi je še manj jasno.
M.B. ::
Zdaj še Google najde zadetke na potniski.sz.si če iščeš slovenske železnice.
Informacijski pooblaščenec hacked?
191866 (1458) AndrejS
PHP & XAMPP file_get_contents
Oddelek: Izdelava spletišč
151660 (1440) KoMar-
Kaspersky Internet Security 7.0
181786 (1526) luky
Pripombe,pohvale,graje (strani: 1 2 )
Oddelek: Slo-Tech
586858 (2442) CaqKa
Problem s charsetom
111910 (1743) Matek
