Forum » Pomoč in nasveti » Redirect na wordpress login pri odpiranju strani slovenskih železnic
M.B. ::
Od danes se mi stran slovenskih železnic www.slo-zeleznice.si ne odpre. Ob odprtju me 301 preusmeri na stran https://www.slo-zeleznice.si/index.php/..., kar me preusmeri na https://www.slo-zeleznice.si/sl/ kar me preusmeri na https://potniski.sz.si/, ki je nek vstop v wordpress .
Uporabljam Firefox na Linuxu z Telemach in google DNSji. Isto se pojavi na telefonu preko Wifija in na drugem Linux računalniku v gospodinstvu.
Zanimivo da ta link odpre normalno: https://www.slo-zeleznice.si/sl/nepremi... če pa grem v menuju v potniško promet pa spet pridem prek x redirectov na wordpress login.
Sem to tudi omenil na njihovi strani za pomoč ampak pri njih vse dela.
mabu ~ $ http "https://www.slo-zeleznice.si" HTTP/1.1 301 Moved Permanently Cache-Control: no-store, no-cache, must-revalidate, post-check=0, pre-check=0, no-store, no-cache, must-revalidate, post-check=0, pre-check=0 Connection: Keep-Alive Content-Length: 0 Content-Type: text/html; charset=utf-8 Date: Tue, 16 Jun 2020 17:04:28 GMT Expires: Wed, 17 Aug 2005 00:00:00 GMT Keep-Alive: timeout=5, max=100 Last-Modified: Tue, 16 Jun 2020 17:04:28 GMT Location: https://www.slo-zeleznice.si/index.php/sl/ P3P: CP="NOI ADM DEV PSAi COM NAV OUR OTRo STP IND DEM" Pragma: no-cache Server: Apache Set-Cookie: 4e48aed3397740e404816bd7b190ca4f=knvuktphat3vhqt2k48lup8gg4; path=/; HttpOnly X-Content-Powered-By: K2 v2.10.2 (by JoomlaWorks) X-Logged-In: False mabu ~ $ http "https://www.slo-zeleznice.si/index.php/sl/" HTTP/1.1 301 Moved Permanently Connection: Keep-Alive Content-Length: 240 Content-Type: text/html; charset=iso-8859-1 Date: Tue, 16 Jun 2020 17:04:51 GMT Keep-Alive: timeout=5, max=100 Location: https://www.slo-zeleznice.si/sl/ Server: Apache <!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN"> <html><head> <title>301 Moved Permanently</title> </head><body> <h1>Moved Permanently</h1> <p>The document has moved <a href="https://www.slo-zeleznice.si/sl/">here</a>.</p> </body></html> mabu ~ $ http "https://www.slo-zeleznice.si/sl/" HTTP/1.1 301 Moved Permanently Connection: Keep-Alive Content-Length: 231 Content-Type: text/html; charset=iso-8859-1 Date: Tue, 16 Jun 2020 17:05:12 GMT Keep-Alive: timeout=5, max=100 Location: https://potniski.sz.si/ Server: Apache <!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN"> <html><head> <title>301 Moved Permanently</title> </head><body> <h1>Moved Permanently</h1> <p>The document has moved <a href="https://potniski.sz.si/">here</a>.</p> </body></html>
krho ::
Meni tude dela.. Zdej ali so popravili ali pa tebi nekaj dela narobe... Se recimo vmešava kakšen antivirus ipd.
M.B. ::
Antivirusa nimam. Predvidevam da meni dela narobe, samo ni mi jasno kaj. Saj dela isto na 2 računalnikih in Android telefonu preko Wifi in tudi 4g. Kar pomeni da DNS tud ni važn.
M.B. ::
Preizkusil in se isto dogaja tudi na domačem Windows računalniku na AWS sistemu na irskem in sodelavcu v Berlinu.
Tako da mi je še manj jasno.
M.B. ::
Zdaj še Google najde zadetke na potniski.sz.si če iščeš slovenske železnice.
| » | Informacijski pooblaščenec hacked?Oddelek: Informacijska varnost | 1865 (1457) | AndrejS |
| » | PHP & XAMPP file_get_contentsOddelek: Izdelava spletišč | 1660 (1440) | KoMar- |
| » | Kaspersky Internet Security 7.0Oddelek: Informacijska varnost | 1786 (1526) | luky |
| » | Pripombe,pohvale,graje (strani: 1 2 )Oddelek: Slo-Tech | 6858 (2442) | CaqKa |
| » | Problem s charsetomOddelek: Izdelava spletišč | 1910 (1743) | Matek |
