Forum » Programiranje » Flashu 4
Flashu 4
msmiha ::
kako bi v Fleshu 4 naredu, da bi en gumb na katerega bi klknil zagnal en določen program (recimo Windows Commander). Podobno stvarco ma naret SiOL, na tistem CDju. Ko klikneš, da bi rad recimo namstil Internet Explorer
Sergio ::
sistemski klic v Flashu? ne verjamem...
Tako grem jaz, tako gre vsak, kdor čuti cilj v daljavi:
če usoda ustavi mu korak,
on se ji zoperstavi.
msmiha ::
Pol mi pa razloži kako je SiOLovci tist naredl???
Tjulenj ::
pomojem dokaj tezko, ker v nasprotnem primeru bi ti vsak bizgec zalaufal kaksen BO v ozadju.
flashu, fleshu flash
yimi ::
Jak.....
Naj vam namignem. Flash ima funkcijo getURL, ki odpre določen url. In če ti predvajaš animacijo v samostojnem Flash Playerju na računalniku, se ti bo, ko boš klical en url pač odprl default brskalnik.
Slutim, da mora biti nekaj podobnega tudi za ostale datoteke. Malo se poigraj.
dexter ::
Hello!
To se naredi z FlashJester Jugglor-jem (samostojna aplikacija) ali z ProjectorLauncher-jem dodatkom.
Poglej si www.flash-jester.com in www.mories.com
msmiha ::
dexter ta link ne dela! www.flash-jester.com on drug je pa nek čuden program.
dexter ::
Hello!
JEb`ga mal so spremenil www naslov.Zdej je se nekaj novih orodij tko da mal poglej,verjetno pa je jugglor kar taprav.
http://flashjester.com/software/jugglor...
The command exec launches an application program from the Flash projector. If the program is in the same directory as the Flash projector, it is not necessary to provide a path to the application. However, if the program is located outside of the directory the Flash projector resides in, a relative or full path is required to launch the application.
Exec is not capable of opening a specific file, only an application. However, there are some third party tools which can open a specific file with an associated application. One such tool is available from Flashjester.
http://www.flashjester.com/software/jto...
"JStart can run almost any file such as:"
Avi's, PDF, Doc, Programs, Bitmaps, Tiffs, JPEG's, MP3, HTML, etc
msmiha ::
thenx dexter
Jst ::
msmiha:
Jst sm vcasih delal s flashom in se to DEFINITIVNO DA narediti, samo sedaj se ne spomnim kako..
jst sm tok naredil dosti Autorunov za mp3cdje in sem zagnal winamp tako...
Ce mi das 2 dni casa, da dobim flash ti bom povedal. Aja pa se pis mi na jst@nofx.com, da se bom spomnu.
| » | Posodobitev biosa (težava z navodili) (strani: 1 2 )Oddelek: Strojna oprema | 12687 (11699) | Miha20 |
| » | Težava niprave frekvence procesorja (strani: 1 2 3 )Oddelek: Hlajenje in modifikacije | 11227 (9977) | Miha20 |
| » | Nov članek: "All your firmware are belong to us" (strani: 1 2 3 )Oddelek: Novice / Nova vsebina | 20238 (17078) | arrigo |
| » | Apache - localhost JA, IP naslov NEOddelek: Omrežja in internet | 7272 (7131) | ManDriver |
| » | Kako zagnati program v želeni prioriteti?Oddelek: Operacijski sistemi | 2262 (2121) | tha_man |
