Epidemijo koronavirusa prva napovedala umetna inteligenca
2
Uporabnik ::
Jaz vidim sam statično slikco za nazaj :)
  • spremenilo: Uporabnik ()
spegli ::
Par let nazaj je blo vse turbo, pol je bil klaud in zdej je AI. Kje je komet ?
Lepo razloženo, da se ne boste preveč kregal:
Artificial intelligence (AI), machine learning and deep learning are three terms often used interchangeably to describe software that behaves intelligently. However, it is useful to understand the key distinctions among them.
You can think of deep learning, machine learning and artificial intelligence as a set of Russian dolls nested within each other, beginning with the smallest and working out. Deep learning is a subset of machine learning, and machine learning is a subset of AI, which is an umbrella term for any computer program that does something smart. In other words, all machine learning is AI, but not all AI is machine learning, and so forth.
Vir: https://pathmind.com/wiki/ai-vs-machine...
Balaton ::
To dilemo razlikovanja med nivoji AI je lepo rešil Mass Effect že pred več kot desetimi leti.
A Virtual Intelligence (VI) is a sophisticated program designed to make modern computer systems easier to use. They are not to be confused with artificial intelligences (AI)... as VIs are only utilised to assist the user and process data. Though they appear to be intelligent, they aren't actually self-aware, just made with clever programming. VIs vary greatly depending on how they are deployed. They can handle search queries on the extranet, act as tour guides--as or manage sophisticated lab and database work.
Dobesedno vso današnjo "umetno inteligenco" lahko uvrstimo pod VI.
nevone ::
Lepo razloženo
Res je.
o+ nevone
nejcek74 ::
Bralci in poslušalci smo samo naveličani vedno novih umotvorov, ki prihajajo iz ust nerazgledanih ustvarjalcev. Inteligenca je prav lepo definirana kot sposobnost povezovanja, sklepanja, učenja, razumevanja. Da jo nekdo vtakne v povezavo z zgoraj opisanimi postopki, ki se dogajajo v povezavi z obdelavo velikih količin podatkov kaze predvsem na nekritično navdušenje nad lastnim delom ter zeljo po manipuliranju z javnostjo in investitorji. "umetna inteligenca" je ravno toliko inteligenca kot je "vegetarijansko meso" meso.
Mogoce bi lahko počasi priznali, da gre za cisto iste stvari kot jih je počel nekdo 2300 let nazaj, ko je analiziral tabelo podatkov zapisanih na glineno tablico, pred skoraj dvesto leti z mehaničnim analitičnim računalnikom, zdaj pa s procesorji. Ja, je obcutna razlika v kolicini obdelanih podatkov, temu primerni so rezultati.
"Why do you call it AI if it is not intelligent?"
"You don't understand, it's complex, there are different levels.....bla bla bla"
"Still, no part of this is intelligent"
"Eeeeeee, we named it AI so it's Artificial Intelligence"
Oziroma kot bi rekel Gino D'Campo: "'Se mia nonna avesse le ruote, sarebbe una carriola'" Ce bi moja babica imela kolesa, bi bila karjola
nevone ::
Ne bi mogel lepše povedati. Le da pri tem ne veš, zakaj in kako to deluje. Z razvojem umetne inteligence pa se temu razumevanju približuješ.
o+ nevone
Seveda vem, saj zato pa oporekam marketinški uporabi izraza umetna inteligenca na tehnološkem forumu.
nevone ::
jype je izjavil:
Lahko da veš, ja. :)
o+ nevone
Phantomeye ::
proto je izjavil:
Phantomeye je izjavil:
tikitoki je izjavil:
Markoff je izjavil:
proto je izjavil:
Pa marketingarjem, ki poleg nalepke brez glutena in brez holesterola, za dobro mero na gate nalepijo se nalepko AI. In potem to ljudje kupujejo in so zadovoljni, da zivijo v brezglutensko brezholesterolnem umetnointeligencnem svetu.
Tule si grdo brcnil v temo. Celiakija ni neka brezvezna nevšečnost sodobnega človeka.
So pa horde samodiagnosticiranih bolnikov move.
Ima pa to eno pozitivno lastnost. Zaradi te norije glede glutena imajo zdaj dejansko ljudje, ki glutena ne smejo uživati (npr. tisti s celiakijo) dejansko eno normalno izbiro hrane.
Ja ja, prav, fino, nasel si svojih 5 minut, da ves kaj je celiakija. Who cares. Tudi, ce jo imas. Who cares. Odpri novo temo. Mogoce se bo tam kdo hotel pogovarjati (ce ne bom prisel mimo in derailal debato na pozornostne cipice).
Kaj točno je tvoj problem? :D Mislim, sej navsezadnje si ti pripeljal gluten v debato.
Ales ::
nevone je izjavil:
Lepo razloženo
Res je.
o+ nevone
Ne ni, ampak je popolna neumnost in prodajanje megle, na nivoju teh "AI mi je pripravil sendvič" bloggerjev in kvazi "novinarjev".
Definirati AI kot "an umbrella term for any computer program that does something smart" je kretenizem. Model z linka je v bistvu rekel, da je inteligenca nekaj pametnega. Uaau. Škoda da on ni.
Medtem ko je definicija, ki jo je podal Balaton, čisto točna. Dobesedno vso današnjo kvazi "umetno inteligenco" lahko uvrstimo pod VI. Vse ostalo je prodajanje megle.
Lahko mi pa npr. pokažeš kdaj je AlphaGO rekel, da se mu danes ne da igrati Go in da bi raje sadil rožice ali raziskoval corona virus. Grem takoj spit eno pivo z njim in malo poklepetat.
Phantomeye ::
Ales je izjavil:
nevone je izjavil:
Lepo razloženo
Res je.
o+ nevone
Če jaz razvijem umetno inteligenco, ki je intelektualno na nivoju papige, opice, 2 leti starega otroka, s katero obviously ne morš na pivo poklepetat ... therefore to ni AI?
Ales ::
Od vsega kar sem napisal je najbolj izstopalo pivo in klepet? Preberi en stavek prej. Pa potem še vse ostale stavke pred tem...
Phantomeye ::
Ales je izjavil:
Ne izstopalo je sporočilo, da je umetna inteligenca človeku podobna entiteta, s katero lahko komuniciraš. Če to ni bil tvoj namen, se opravičujem, ampak tako zveni.
mulc007 ::
jype je izjavil:
Kot nekdo, ki je na podobnih sistemih že delal, lahko zagotovim, da "umetna inteligenca" v tej tehnologiji ne gre dlje od Machine learning @ Wikipedia , zato raba izraza umetna inteligenca IMO ni ustrezna.
Po naravni inteligenci sklepam da se v zadnjih dveh desetletjih nisi imel veliko časa ukvarjati se z umetno inteligenco.
Od leta 2012 ko si se registriral na ta portal si v ca 6400 dneh pridelal 96950 postov kar v povprečju pomeni 15.17 postov na dan. S tolk postov na dan bi meni precej primanjkovalo časa :)
mulc007 je izjavil:
Prepočasi tipkaš.
HappyPills ::
Torej še vedno nobenega linka?
Linka na kaj? Napoved? Ne obstaja, ker se najbrž nihče nima časa ukvarjat z web frameworki.
HappyPills ::
Kaj pol smisel tega vsega? Kle nas neki rajcajo pol pa nič. Bah!
HappyPills je izjavil:
Smisel je, da lahko primerjajo podatke in pilijo orodja, da bodo zanesljivejša. Ko jih bomo začeli dejansko v praksi uporabljat, ne bo prostora za napake, ki so trenutno še pričakovane.
mulc007 ::
Virus se bo širil to je logično ker poleg tistih z vročino so tudi tisti ki še nimajo znakov obolenja.
Če virus ni naravnega izvora se je smiselno vprašat komu bo koristil če bo odstranil šibke bolne ljudi in najbolj udaril tam kjer je največja revščina. Mogoče tistemu ki ohranja sistem kot ga imamo da bo za ostalo večino bolj ekonomsko vzdržen.
  • spremenil: mulc007 ()
kuall ::
Zgodovina se rada ponavlja, zgodovina človeštva pa je polna smrtonosnih virusov: kuga, ki je pobila tretjino evrope, virusi, ki so pobili večino indijancev. Iz tega vidika je napovedovanje nevarnih virusov kar sigurno.
Tudi virus HIV je dokaj nova stvar in dokaj nevarna. Čudi tudi dejstvo, da ne znajo najti zdravila. No saj čudi tudi dejstvo, kako sploh najdejo zdravilo za karkoli.
AI ima prednost, ker včasih zna bolje videti zakomplicirane ponavljajoče vzorce/analogije, ki jih je polno v vsepovsod. Ljudje jih dobro vidimo ampak vse pa ne, spregledamo jih kar veliko, kar je človeško.
Ali se imenuje AI ali kaj drugega pa je debata za jypete.
  • spremenilo: kuall ()
Mhm, ni za ljudi, ki s temi rečmi še niso delali.
Danes se AI, blockchain in bio nalepi na vsak drek, da se ga lahko lažje in dražje proda.
HappyPills ::
HIV je po svoji specifiki precej drugačen kot ti virusi. Malo pogooglaj boš videl v čem so največje ovire. Z razvojem tehnologije in znanosti na splošno pa bodo tudi borbe proti virusom lažje. Sama oznaka je pa saj za nas navadne plebse dost vseen. AI šmai.
kuall ::
jype je izjavil:
Ravno obratno je: AI ima negativen prizvok, ker spominja na zgube, ki jim ne gre v življenju in vidijo v AI magično rešitev. Oziroma spominja na neuspele poskuse iz 60ih in naprej, kako AI doseči in na ljudi, ki so zgubljali čas s tem in nič dosegli (propadli). Če hočeš bit kul boš rekel machine learning namesto AI. Če pa te zunanji izgled ne briga boš rekel AI, za kar se v resnici gre.
Phantomeye ::
kuall je izjavil:
Dejansko smo HIV obvladali do te mere, da zaradi njega ne umreš in pazi to, ne prenašaš naprej, ker virabilnost pade.
Če ješ redno tablete.
http://www.aidsmap.com/about-hiv/undete...
2
Epidemijo koronavirusa prva napovedala umetna inteligenca (strani: 1 2 )
7528635 (24004) Phantomeye
Ptičja gripa (strani: 1 2 3 )
Oddelek: Problemi človeštva
12514971 (11046) Tear_DR0P
