Naravno lepilo
Naravno lepilo
omnimint ::
Ni to ravno lepilo - iščem snov, ki se bo oprijela strme (deloma kamnite) podlage in obstala tam dovolj časa, dokler ne požene trava. Nekaj, kar lahko sam doma spacaš.
Kakšna ideja?
Daliborg ::
Jajce? Predvsem beljak...
Format life:
Warning all life will be erased!
Do you want to continue?(y/n) Y_
voda pa moka?
K0l1br1 ::
Mreža pa dva vijaka?
omnimint ::
Nekaj takega sem mislil http://www.turcogolf.com/hydroseeding
Ne vem pa kaj dodajajo, da se stvar drži podlage, tudi po zalivanju recimo.
Daliborg ::
Pa saj ti piše v naslovu od linka kaj je to in vse lepo olisano v prvem odstavku:
Hydroseeding is the process of combining seed, mulch, fertilizer and healthy soil amendments with water to mix in a hydroseeder tank to form a thick slurry. This slurry is sprayed onto the ground to establish vegetation and control erosion. Grass should begin to grow within 7 days, and the new turf will be well established within 3-4 weeks.
googlaj kako pripraviti tako zmes pa je :)
Format life:
The Evil Within (strani: 1 2 )
Oddelek: Igre
9517816 (4344) oo7
Samodejno izklapljanje računalnika
263194 (2413) sennheiser
Apokalipsa: April 2014 - Marec 2015
367999 (6444) Janac
V osončju sedaj le 8 planetov (strani: 1 2 )
5813684 (8984) Thomas
allofmp3
122300 (1942) mn
