Pomivalni stroj na vikendu.
Scorpy84 ::
Preden ga kupim in se ga lotim, me zanima ce je izvedljivo. Torej imam na voljo vodo, odtoka pa zal ne. Ko rocno pomivam se nabere 20l vode in vec odvisno od umazanosti ter kolicine. Pomivalc pa porabi okoli 10l vode, torej za vodo odnasati je dosti lazje. V navodilih pise, da more biti odtok visine 60 cm, sicer mi to ni problem narediti in tudi ne vidim smisla, ker bi lahko direkt v kanto vrgel cev. Torej ce se karkoli spomnite, na kar morem paziti, bo vsaka ideja prav prisla.
St235 ::
https://structuretech1.com/dishwasher-d...
I've heard different reasons for why an additional loop is required under the sink, so I decided to contact the manufacturers directly.
I sent out an email to eight dishwasher manufacturers, asking them this question:
"A high loop is required on the dishwasher drain in the installation instructions for all of your dishwashers. What is the purpose of this? Doesn't the high loop that is incorporated in to the side of the dishwasher achieve the same thing? Any insight or commentary in to this matter would be greatly appreciated."
Here are the responses I received:
Kenmore: "The high loop or air gap must be used to prevent potential backflowcontamination of the dishwasher. Local plumbing codes generally dictate the requirements in your area. Section 807.4 of the Uniform Plumbing Code states: "No domestic dishwashing machine shall be directly connected to a drainage system or food waste disposer without the use of an approved dishwasher airgap fitting on the discharge side of the dishwashing machine. Listed airgaps shall be installed with the flood level (FL) marking at or above the flood level of the sink or drainboard, whichever is higher, or separately trapped with the airbreak located on the stand pipe.
GE: "If an air gap is not required, the drain hose must have the high loop from the floor to prevent backflow of water into the dishwasher or water siphoning out during operation."
Bosch: The high loop in the drain hose of your dishwasher is to keep water from settling in the hose if it were hanging down any lower or horizontally. This keeps the drain hose dried out and keeps any odors from backing up into the dishwasher.
Viking: In testing our dishwashers, we have found that the additional high loop in the back of the dishwasher is required for proper draining of the water. We have seen when this piece is not applied that over time the consumer will have issues with the water back up and causing issues with proper drainage and water pooling in a particular area.
To summarize, the reasons for the high loop are to prevent potential backflow of water in to the dishwasher and to prevent improper drainage of water. Even though dishwashers come from the factory with the drain looped up high against the side of the dishwasher, this is not an acceptable substitute for the high loop underneath the kitchen sink. In Minneapolis, the lack of a properly installed high loop under the kitchen sink requires repair for their Truth-In-Sale of Housing evaluations.
  • spremenil: St235 ()
Stari maček ::
Če ti bo zmrznil, se poslovi od njega.
Scorpy84 ::
Stari maček je izjavil:
To si lahko brez skrbi, znam izprazniti vodo iz njega in ustrezno zascititi.
  • spremenilo: Scorpy84 ()
Barbarpapa2 ::
Pozdrav
Ne vem točno, kakšna je konstrukcija pomivalnih strojev, samo, ali ni tako, da na izhodu ni nobenega ventila, samo črpalka za praznjenje? Ne bi potem voda konstantno odtekala iz stroja, če bi bila odtočna cev prenizko?
Jože
"NaN" ::
Barbarpapa2 je izjavil:
Pozdrav
Jože
Da
V pralnem stroju ne odteče voda
88872 (8737) Mato989
Kako skrbite za ostre nože? (strani: 1 2 )
7821252 (18778) BorutO
S čim očistiti termalno pasto s procesorja?
478182 (7094) opeter
Pomoč pri prevodu tehničnega "štromarskega" besedil
61652 (1509) Okapi
Zakaj ISDN, če hočem ADSL ???
Oddelek: Omrežja in internet
92203 (2051) Bx
