Forum » Programiranje » več parametrov
več parametrov
Blisk ::
Imam skripto, ki bere parametre iz več fajlov. Primer skripte je spodaj.
Zanima me ali se da nastaviti, da imam en fajl za več parametrov.
ker zdaj imam vsak parameter v svojem fajlu. naprimer da bi imel samo en fajl wrong.txt in samo en fajl params.txt
ker trenutno imam naprimer v fajlu wrong4.txt "old"
v fajlu wrong3.txt imam "month"
v fajlu wrong2.txt imam "year"
pa me zanima če imam lahko vse to v enem fajlu wrong.txt?
old
month
year
old
month
year
set /p readparams=<D:arhiviranje\mesec\nast\wrong4.txt FIND /C /I "%readparams%" LOG*.txt IF ERRORLEVEL 1 (goto C3Z) else (goto KXZ) :C3Z set /p readparams=<D:arhiviranje\mesec\nast\wrong3.txt FIND /C /I "%readparams%" LOG*.txt IF ERRORLEVEL 1 (goto C2Z) else (goto KXZ) :C2Z set /p readparams=<D:arhiviranje\mesec\nast\wrong2.txt FIND /C /I "%readparams%" LOG*.txt IF ERRORLEVEL 1 (goto C1Z) else (goto KXZ) :C1Z set /p readparams=<D:arhiviranje\mesec\nast\wrong1.txt FIND /C /I "%readparams%" LOG*.txt IF ERRORLEVEL 1 (goto ZZ) else (goto KXZ) :ZZ set /p readparams=<D:arhiviranje\mesec\nast\params1.txt FIND /C /I "%readparams%" LOG*.txt IF ERRORLEVEL 1 (goto EZ) else (goto DZ) :EZ set /p readparams=<D:arhiviranje\mesec\nast\params2.txt FIND /C /I "%readparams%" LOG*.txt IF ERRORLEVEL 1 (goto FZ) else (goto DZ)
| » | batch fajl iz txt (strani: 1 2 )Oddelek: Programiranje | 13205 (11866) | b3D_950 |
| » | [Delphi] Izbira podatkovne bazeOddelek: Programiranje | 2900 (2360) | zhigatsey |
| » | C#; WebClient class; problem z uploadanjemOddelek: Programiranje | 1764 (1723) | 64202 |
| » | Command prompt; je moznio klicati ukaz iz fajla krneki.txt?Oddelek: Operacijski sistemi | 1703 (1512) | Microsoft |
| » | problemi z image fajliOddelek: Pomoč in nasveti | 1087 (1014) | XsenO |
