Postavitev DNSSEC (Debian, Bind9)
HotBurek ::
Navodila po korakih za DNSSEC na Debina in Bind9.
Če so kakšne napače in izboljšave, pa kr povedat.
#1 Init...
named -v
BIND 9.10.3-P4-Debian
nano /etc/bind/named.conf.local
# Direct zone | example.si
zone "example.si" IN {
        type master;
        file "/etc/bind/example.si.zone";
        allow-update { none; };
nano /etc/bind/example.si.zone
$TTL    60480
@       IN      SOA     ns1.example.si. hostmaster.example.si. (
                        2019022401      ; Serial
                        6048            ; Refresh
                        864             ; Retry
                        1209600         ; Expire
                        6048)           ; Negative Cache TTL
@       IN      NS      ns1.example.si.
@       IN      NS      ns2.example.si.
@       IN      A       1.2.3.4
ns1     IN      A       1.2.3.4
ns2     IN      A       1.2.3.4
@       IN      CAA     128 issue "letsencrypt.org"
#2 Config options
nano /etc/bind/named.conf.options
options {
	dnssec-enable yes;
	dnssec-validation yes;
	dnssec-lookaside auto;
#3 Keygen
cd /var/cache/bind/
Joža, požen:
dnssec-keygen -a NSEC3RSASHA1 -b 4096 -n ZONE example.si
dnssec-keygen -f KSK -a NSEC3RSASHA1 -b 4096 -n ZONE example.si
ls -l
Kexample.si.+007+12345.key
Kexample.si.+007+12345.privat
Kexample.si.+007+12346.key
Kexample.si.+007+12346.privat
#4 Copy zone file
cp /etc/bind/example.si.zone /var/cache/bind/
#5 Add DNSKEYs
nano /var/cache/bind/add-dnskey.sh and save:
#!/bin/sh
for key in `ls /var/cache/bind/Kexample.si*.key`
do
echo "\$INCLUDE $key">> /var/cache/bind/example.si.zone
done
Joža, požen:
/bin/sh /var/cache/bind/add-dnskey.sh
nano /var/cache/bind/example.si.zone
$TTL    60480
                        2019022401      ; Serial
                        6048            ; Refresh
                        864             ; Retry
                        1209600         ; Expire
@       IN      A       1.2.3.4
ns1     IN      A       1.2.3.4
ns2     IN      A       1.2.3.4
$INCLUDE Kexample.si.+007+12345.key
$INCLUDE Kexample.si.+007+12346.key
#6 Sign zone
cd /var/cache/bind/
Joža, požen:
dnssec-signzone -3 $(head -c 1000 /dev/urandom | sha1sum | cut -b 1-16) -A -N INCREMENT -o example.si -t example.si.zone
Output:
Verifying the zone using the following algorithms: NSEC3RSASHA1.
Zone fully signed:
Algorithm: NSEC3RSASHA1: KSKs: 1 active, 0 stand-by, 0 revoked
                         ZSKs: 1 active, 0 stand-by, 0 revoked
example.si.zone.signed
Signatures generated:                       12
Signatures retained:                         0
Signatures dropped:                          0
Signatures successfully verified:            0
Signatures unsuccessfully verified:          0
Signing time in seconds:                 0.211
Signatures per second:                  56.756
Runtime in seconds:                      0.239
#7 Copy signed zone
cp /var/cache/bind/example.si.zone.signed /etc/bind
#8 Reconfig zone file
        type master;
        file "/etc/bind/example.si.zone.signed";
#9 Add DS records to registrar
nano /var/cache/bind/dsset-example.si.
example.si.               IN DS 12345 7 1 C1958F1FF50FD18D9845629D8A4ABBFBA035223F
example.si.               IN DS 12345 7 2 7E45C686BBA075157AE7EE24AA047FF734512C5A789D4909001233FF 6A122DBF
Oznaka ključa = 12345
Algoritem ključa = 7
Tip digitalnega izvlečka = 1, 2
Digitalni izvleček DS = dolgi string, od začetka do konca, brez presledkov (AAA BBB -> AAABBB)
Hitrost.com sample:
 DS DNSSEC Hitrost.com
root@debian:/# iptraf-ng
Please resize your window
Kudos za še kar spodobna navodila. Na prvi pogled ne vidim napak.
  • predlagalo izbris: 49106 ()
poweroff ::
O, super, ravno to sem rabil. Sem ravno pred kratkim začel gledati kako bi se tegale lotil.
sudo poweroff
tony1 ::
Hvala avtorju še z moje strani.
HotBurek ::
Še dve malenkosti.
#1 Kako preverit remote verzijo bind-a:
dig CH TXT version.bind @ns.slo-tech.com
Da se verzije ne vidi, se uredi v named.conf.options:
options {
    version "Bind";
    //ali version none;
#2 Da se uredit tudi signign on the fly in je manj manual copy/past dela.
https://ftp.isc.org/isc/dnssec-guide/ht...
Opcija "4.3.2.3. inline-signing" in pa key-directory.
[Alternatvni Firmware za router] Vprašanja in težave
Oddelek: Operacijski sistemi
52069 (1339) BivšiUser2
Težave z DNS strežnikom
Oddelek: Omrežja in internet
315883 (5075) Bakunin
[UBUNTU 10.04] GRUB se ne postavi
338269 (8053) matijaz74
Problem z DNS (non-improving refferal)
327263 (6988) SasoS
Problem z domenami na Apache
262076 (1703) Ice-Heki
