NVIDIA Ampere (2020)
scipascapa je izjavil:
https://www.mindfactory.de/Highlights/M...
Nič ne najde ? So že prodali ?
scipascapa ::
Skyman ::
ta stran men na vseh browserjih popaceno prikazuje ze par dni.3070 so kar prodajal nekaj casa se zvecer je bila gor.
  • spremenil: Skyman ()
Skyman je izjavil:
Tudi pri meni je vse popačeno na tisti strani.
NVIDIA GeForce 496.13 WHQL driver released, adds Shader Cache Size setting
Game Ready Driver
This new Game Ready Driver provides support for Back 4 Blood, which utilizes NVIDIA DLSS to boost performance by up to 46% at 4K. In addition, this new Game Ready Driver offers support for the latest new titles and updates, including the launch of the Crysis Remastered Trilogy and Baldur's Gate 3 which utilize NVIDIA DLSS, as well as DLSS updates to Rise of the Tomb Raider, Shadow of the Tomb Raider, and Chivalry 2. Additionally, this release provides optimal support for The Riftbreaker and Sword and Fairy 7.
What's New in Release 495
NVIDIA Control Panel > Manage 3D Settings
o Added Shader Cache Size control to set the maximum amount of disk space to use for
storing shader compiles.
o Vertical Sync options for Optimus notebook GPUs are now the same as for desktop GPUs.
Fixed Issues
[GeForce RTX 3080]: The system does not boot with two Samsung Odyssey G70A 28´´ monitors are connected to the GPU.
[GeForce GTX 960]: The primary monitor lost after resume from sleep or shutdown.
[Windows 11]: The screen flashes once after switching to the discrete GPU-only mode in the NVIDIA Control Panel.
[Multiple Apps][Ansel/Freestyle]: Depth of field filter shows blurry characters.
[Notebook]: Vulkan test applications run on the integrated graphics processor instead of the discrete GPU.
Skyman ::
NVIDIA preparing GeForce RTX 3080 with GA102-220 GPU and 12GB memory for January 2022 launch
https://videocardz.com/newz/nvidia-prep...
In za koliko % je pričakovati, da bo hitrejša kot navadna RTX 3080 ?
Skyman ::
5% nič več nič manj :)) ja ce primerjas 3080 pa TI verzijo je cca 10% potem je 5% idealno
Cena 3080"super" pa ista kot navadna 3080 "magičnih 699$"
NVIDIA Readies GeForce RTX 3080 With GA102-220, RTX 3050 Ti With GA106-150 & RTX 3050 With GA107-350 GPUs
https://wccftech.com/nvidia-readies-gef...
Bo zanimivo videti, če bo GPU crisis segel še v leto 22.
FlyingBee ::
Verjetno želijo ohraniti prednost v 4k, kjer radeonke šepajo, gre pa itak vse v high end, poceni robo sploh ne proizvajajo več izven oem.
New Sphincter Kvartet:
Še vedno igram Metro Exodus vse na ultra računalnik je kar glasen. Ventilatorji.
FlyingBee ::
Grafična je s kompromisi, nimaš kaj.
oo7 je izjavil:
Sem ti povedal rešitev, ampak očitno nimaš par minut časa.
DarwiN je izjavil:
oo7 je izjavil:
Si povedal rešitev nekomu, ki je to že delal jaz nisem še nikoli :P
Raje nastavi tako, da bo temp ~70 in nižji vrtljaji.
Oziorma najprej obvezno undervoltaj.
dolenc ::
Če maš video kako se kozarc kumarc odpre, zna bit da maš tud to razložen na yutubi.
dolenc je izjavil:
Ja saj bom poiskal :)
Evo še enkrat link samo za tebe, 007:
Skratka, preveriš, kakšna je max boost frekvenca in potem za to frekvenco naštimaš 0.9V.. That's it. Lahko greš tudi nižje (0.875, 0,85).. Odvisno od primerka. 0.9 zmore praktično vsak gpu, za nižjo vrednost pa potrebuješ malo silicijeve loterije. Sej boš videl, kdaj je zadeva stabilna.
Rezultat: zmogljivost ostane enaka, zniža se pa poraba in z njo temperature oz. hrup. Dejansko lahko izbiraš, kako boš unovčil ta bonus. Ali v obliki nižje temperature, ali pa nižjega hrupa. Ali 10-15 stopinj nižje temp., ali pa ~2x manjši hrup.
Poročaj rezultat oziroma če se ti bo kje zataknilo.
p.s.: najprej si zapiši temperature in vrtljaje med gamingom pred undervoltom... Da boš lahko kasneje primerjal.
  • spremenil: DarwiN ()
Bom probal tole urediti čez vikend. Hvala za nasvete Darwin :)
FlyingBee ::
Koliko imaš osveževanje monitorja? Lahko tudi samo sync-aš na nativno frekvenco in bo manj hrupa. Če ti ne bo šlo po Darwinovo.
Master_Yoda ::
Haleluja, sem prisel pri EVGA na vrsto za 3060. Sedaj pa samo fingers crossed da ne dobim DOA karte :)).
Dovie'andi se tovya sagain.
scipascapa ::
OMG, gut luk.
mahone ::
Master_Yoda je izjavil:
A to prek Gputrackerja?
Master_Yoda ::
Preko njihovega queue sistema.
mahone ::
FlyingBee ::
Zdaj so naredili čistko, od 11.10. so ostali le še po dva artikla v čakalni vrsti na eno osebo. Jaz sem pustil 3080 in 3080ti, bomo videli.
scipascapa ::
tole imam jaz
PartNumber DateEntered Notify Sent Active
12G-P5-3967-KR 6/6/2021 6:27:19 AM PT Removed by User False
12G-P5-3657-KR 2/26/2021 12:58:24 AM PT No False
08G-P5-3751-KR 1/15/2021 12:39:09 PM PT No False
10G-P5-3881-KL 1/15/2021 12:38:20 PM PT No False
08G-P5-3667-KL 1/15/2021 12:37:24 PM PT No True
08G-P5-3663-KL 1/10/2021 3:34:23 AM PT No True
možnosti imam za zadnji dve?
Master_Yoda ::
S tem da ko se EU queue premakne za 4 minute se US queue premakne za 3 mesece - sem sel v vrsto 3 minute 44 sekund po launchu in sem danes dobil notify. Americani ki so se postavili v vrsto maja ze dobivajo heh.
Scipa, moznosti imas samo za dve najstarejsi - ker so po tej cistki naredili da si lahko v vrsti za samo 2. Ce nisi pobrisal ostalih so ti vzeli 2 najstarejsa. V tvojem primeru sta to 08G-P5-3663-KL in 08G-P5-3667-KL
scipascapa ::
yep
10.1
15.1
omfg
Skyman ::
Ma kaksen maj.. se slabse tisti ki so narocevali 15.6 ze dobivajo..EU pa kot da smo na marsu oz druga galaksija.
Master_Yoda
Porocaj koliko casa bo hodila do tebe.
FlyingBee ::
Celo večnost, baje noben kurir noče v tisto močvirje na Dagobahu.
mahone ::
Skyman ::
kaj takega za 3080 obstaja
scipascapa ::
FlyingBee ::
Do 100eur nad msrp za boljše izvedenke je še sprejemljivo, toliko več za Ventus pa je kriminal.
FlyingBee je izjavil:
60,000 HZ
Nvidia Desktop RTX 3050 and 3050 Ti specifications leaked
https://www.gameort.com/2021/10/nvidia-...
  • spremenil: oo7 ()
Skyman ::
Ima kdo izkusne z Gainward GeForce Phoenix oz Phantom serijo? sem jih videl ze sedaj malo "cenejse" za te razmere,pa nekak sem en review bral na redditu da ni presezek.
Buggy ::
Tezko reci, ker imajo pri vsaki generaciji vsak od proizvajalcev dolocen shortcute.
imel PNY Gtx 460 Ti, ki je bil najbolj pocen GPU takrat z dokaj decent coolingom...je imel pa jeben core tolk epic, da se je z overclockingom iz graficne dalo iztisnit vec kot ostale grafike takrat. Undervolting takrat niti se ni bil v igri, ker so iz fabrik prihajale "podhranjne" verjetno zaradi coolinga.
Hocem rect, da ne smes in ne mores predalcak kar tako, sploh pa ne danes, ker so GPU-ji bolj kot ne namenjeni miningu. Face it!
FlyingBee ::
Na techpowerup testirajo različne modele in v razdelku fannoise/temperatures vidiš primerjavo različnih aibjov za isti čip. Recimo primer za 3080ti:
https://www.techpowerup.com/review/gain...
Najti je treba razmerje med glasnostjo in temperaturo, MSI in Asus načeloma prednjačita v tem, sta pa dražja od Gainward, Palit, PNY druščine.
oo7 je izjavil:
60,000 HZ
Spodaj primer kako relativno nizka je poraba na sync 60hz/fps. Vsekakor se to odraža potem na vseh ventih v PCju, največ seveda od grafične.
Skyman ::
Vem da sta Asus in MSI prednjacita,tako kot pri maticnih ploscah :).Mel sem jo moznost dodat v kosarico kar dobra cena še za ta letni čas :)) Pa glih nisem vedel zadnjo gainward ko sem imel je šla rakom zvizgat je pa res da je bilo to 20 let nazaj.
yayo ::
Je kdo že limai tale trač?
https://www.notebookcheck.net/Nvidia-al...
Še ena teorija zarote verjetno.. Tko kot tista, da nekatera podjetja kao kopičijo silicij za hude čase.. Sej človek več ne ve, kaj bi verjel. Whatever.. Bo čas povedal svoje.
FlyingBee ::
Bussiness ni za pusije.
FireSnack ::
Enkrat bo poknilo vse skup. Nemore se napihovat v neskončnost. Ko bo poknilo, bo fajn poknilo. Takrat ne bo nihče razmišljal da bi kupoval grafo za 1000€.
Horas ::
DarwiN je izjavil:
niso teorijo zatore zastonj teroije in pridejo na plano! vse kar je še na plano prišlo in je bilo označeno za ¨teorijo¨, se je izkazalo za resnično, še posebej za take ki ni dokazov. saj so jih uničili. v tem primeru bi jaz še kako verjel da je res, da to nvidia dela namenoma. je bilo govora do letos jeseni se bojo cene normalizirale, pa sos e? seveda da ne. zdaj so že govorice za leto 2023. pa 24-25. potem pa se bojo končno ja seveda, ne bojo se nikoli več, vsaj na GPU področju ne!
FlyingBee ::
Transport je vse dražji, surovine tudi, itak, da raje manj kosov po višjih cenah prodajo, kot da preplavijo trg in morajo nižat cene ali pa trgovci potem štopajo in imajo višje dobičke.
GALAX GeForce RTX 3080 HOF Extreme Edition Graphics Card Review - The Best Looking Ampere By Far!
https://wccftech.com/review/galax-gefor...
Master_Yoda ::
Skyman je izjavil:
Master_Yoda
14.10 narocil popoldan, danes 19.10 prisla.
Skyman je izjavil:
Master_Yoda
Katero si pa naročil ?
186 / 222
