Forum » Strojna oprema » NVIDIA Ampere (2020)
AapocalypseE ::
Nujno potrebujemo hitrejše kartice.
2080 Ti na 1440p komaj izpljune avg. 75fps. Katastrofalno glede na cene kartic.
https://www.techpowerup.com/review/hori...
FlyingBee ::
Eh, lousy console port and they known it.
New Sphincter Kvartet:
filip007 ::
Saj bo Intel, cenejši in boljši, vsaj upam v 2021.
HP prenosnik, Xbox SX in Hisense Qled.
gddr85 ::
ah, nekej čist normalnega...konzolaši špilajo, pcjaši pa se predrkavajo o benchih, fpsjih, štekanjih, osveževanjih itd. ;)
FlyingBee ::
ja, špilajo s ploščkom :-)
AapocalypseE ::
Mam PS4 Pro. Sem že pozabil kdaj sem ga nazadnje prižgal. Aja točno, lahko bi ga prodal. Kupi kdo?
FlyingBee ::
1. sept. bo očitno 3000 serija alive:
https://www.nvidia.com/en-eu/geforce/sp...
https://www.techpowerup.com/270986/nvid...
As we are getting close to September 1st, the day NVIDIA launches its upcoming GeForce RTX graphics cards based on Ampere architecture, we are getting even more leaks. Today, an alleged PCB of the NVIDIA's upcoming GeForce RTX 3090 has been pictured and posted on social media. The PCB appears to be a 3rd party design coming from one of NVIDIA's add-in board (AIB) partners - Colorful. The picture is blurred out on the most of the PCB and has Intel CPU covering the GPU die area to hide the information. LOL There are 11 GDDR6X memory modules covering the surrounding of the GPU and being very near it. Another notable difference is the NVLink finger change, as there seems to be the new design present. Check out the screenshot of the Reddit thread and PCB pictures below
- spremenil: FlyingBee ()
Wrop ::
Če se prav spomnim, sem pred meseci na YT poslušal eno špekulacijo, da naj bi Nvidia dodala na PCB, poleg GPU, še en čip, ki naj bi posebej pospeševal iskanje v BVH, mogoče je celo rekel, da tudi testiranje zadetkov žarkov v BVH strukturi. Ne spomnim se več točno. Je sploh kaj na tem?
gddr85 ::
AapocalypseE je izjavil:
ti dam jst 30 bucks za ta pos in se ga rešiš ;)
Vuli ::
wow, 3x 8pin pcie
FlyingBee ::
shit, imam leadex 750 W unit pa nima treh, šajse
Usrani 8nm proces pač. :S Pa tukaj tudi ram doda svoje.. 1Gb pije cirka 4W, medtem ko bi naj ta pošast imela 24Gb rama..
Sicer pa ima najhudejša 2080Ti tudi 3x 8-pin napajanje.
FlyingBee ::
11x 2gb = 22gb
En ram čip je bojda leaker zameglil, torej 24gb.. Bojda!
Micron confirms NVIDIA GeForce RTX 3090 gets 21Gbps GDDR6X memory
Vuli ::
te slike so meni malo čudne, še posebej tale: Kaj naj bi bilo pokrito pod unim cpujem, tam so itak keramični kondiči ponavadi.
tale je bolj smiselna, in 12 gddr čipov.
redko kjir jih ima. zato je fajn met kak server psu pri roki.
- spremenil: Vuli ()
FlyingBee ::
Pokrito je, ker na gpuji piše info.
Čudno je, da bi 3090 imela samo 12gb vrama https://www.techpowerup.com/270991/micr...
Vuli ::
aha, zaenkrat so gddr6x samo 1GB moduli. pff to bo zauzelo enga placa.
Se kaj ve, ali se bo poznala razlika med pcie gen3 in pcie gen4 za top rtx kartico ?
Ne sme bit neke razlike, glede na to, da še PCIE 3.0 X8 ni do konca zasičen z 2080Ti kartico.. In ker bo 3090 tam ~50% hitrejša, mora bit PCIE 3.0 x 16 polna kapa.
AapocalypseE ::
Dve igri spodaj kjer je razlika med x16 in x8 3.0 (2.0 x16)
Pri drugih igrah razlike ni oz. je minimalna.
3.0 x16 še bo dolgo aktualen.
We are happy to report that the RTX 2080 Ti is finally able to overwhelm PCIe gen 3.0 x8, posting a small but tangible 2%-3% performance gain when going from gen 3.0 x8 to gen 3.0 x16, across resolutions. Granted, these are single-digit percentage differences, and you won't be able to notice them in regular gameplay.
https://www.techpowerup.com/review/nvid...
PCIe 4.0 x16 je smiselen za kartica z manj VRAM-a in visokoločljivostnimi teksturami, ker se tam podatki iz sistemskega pomnilnika pretakajo bolj pogosto ter je posledično manj cukanja. Torej bolj zna vplivati na min fps kot pa na avg fps, pa še to ne povsod.
Zanimivo. Ko je imel INTEL vodstvo v litografiji, dolocenih oseb to ni motilo. Sedaj pa stalno jokajo kako je AMD v nefer prednosti in ne pozabijo omeniti, da je za to zasluzna druga firma. Mogoce INTEL nima moznosti izdelave cipov drugje:).
FlyingBee ::
Napačna tema, Tikiboy.
FlyingBee ::
Ja, party like it's 1999.
nostalgia overload![]()
Vse lepo in prav.
Pozabili so na Unreal GOLD, Final Fantasy VII in Unreal Tournament, C&C, StarCraft in Warcraft.
- predlagal izbris: AapocalypseE ()
strumf666 ::
V igrah precej malo verjetno, v programih se pa v določenih workloadih pozna:
https://www.igorslab.de/en/pci-express-...
Member of OC-Lab Team
http://www.oc-lab.si/
- spremenil: strumf666 ()
Potem bo intel v tezavah in bodo njihove hedt platforma.... no se presenetimo kaj bo septembra z novimi intli...
FlyingBee ::
Edino instagram je easter egg.
FlyingBee ::
Vprašanje koliko je to resnično, ne bom pa začuden, če bo dražja od 2080ti.
Seveda bo tudi odvisno od konkurence in ko se zaloga uravna, day one pa mogoče 1500eur, zakaj pa ne.
Senior Dev ::
2000 ni nek denar roko na srce. Novac treba da kroži.
neo5468 ::
Nekje do 700€ sem pripravljen dat. Gtx 1060 je premalo zraven 10700k, za 144hz. Upam, da se dobi 3080. Če ne bo velike razlike v performanceu, potem pa 3070. Še slaba 2 tedna. Bo pa kr joke, če ne bojo grafov pokazal na predstavitvi, tako kot pri turing
700€ za 3080? Pozabi.. Okrog 1000€ zna bit.. Za 700€ boš dobil 3070.. Za 400-500 pa 3060.. Ray tracing bo po novem samo za "privatnike". Za siromake bo GTX serija in pa AMD jajca.
Tele serija graf bo mela dost vrama .
Prihaja čas, ko grafe z manj ko 12gb vrama ne bomo niti pogledali. No, grafe so sicer zlo močne. In nekoliko drage.
Rumor: Nvidia GeForce RTX 3090 'Ampere' GPU's price expected to be around $2,000 USD ballpark
https://www.dsogaming.com/news/rumor-nv...
FlyingBee ::
Kitajski source, kitajska firma, preračunano iz kitajskega dnarja, tam naj bi bile rtx zelo drage, itd.
mailer ::
700€ za 3080? Pozabi.. Okrog 1000€ zna bit.. Za 700€ boš dobil 3070.. Za 400-500 pa 3060.. Ray tracing bo po novem samo za "privatnike". Za siromake bo GTX serija in pa AMD jajca.Če sploh še bo kakšna non rtx grafa na voljo.![]()
FlyingBee ::
Sigurno, če ne pa refresh Pascala na 7nm, bo imel AMD tudi z rdna2 še veliko posla :-)
