NVIDIA Ampere (2020)
NVIDIA's next-gen Ampere GPUs will arrive in 2020 on 7nm
NVIDIA's new GPU would be the Turing architecture followed by Ampere, and now we're hearing more about the next-gen GPU architecture from NVIDIA that will arrive in 2020.
NVIDIA will reportedly be using Samsung's new 7nm extreme ultraviolet lithography (EUV) process that uses a plasma laser to drive silicon material into 7nm transistor structures. The new GeForce RTX and Quadro RTX graphics cards are both made on the 12nm process thanks to TSMC, with NVIDIA no stranger to working with Samsung for GPU production.
https://hk.saowen.com/a/dc17285c1622849...
Torej 2020 nove kartice Nvidia z imenom Ampere.
FlyingBee ::
https://www.techspot.com/news/79214-nvi...
Govori se, da bodo Ampere na 7nm tease-ali na GTC 17.3.19. Morajo malo hypat pred Navijem.
Sicer se jim ne mudi, bo pa vsekakor velik udarec za AMD, če jim uspe sočasno ali celo malo prej Ampere na trg spravit, ne bodo mogli niti dobro zadihat.
klinker ::
Mahh, dejansko nimajo potrebe. 16xx/20xx so komaj izsli in vprasanje kako bo Navi ze napram tem konkurencen.
FlyingBee ::
Navi bo majhen čip in bo zaradi 7nm konkurenčen do 400eur, verjetno.
NVIDIA Ampere GPU Taped; Might Launch in Latter Half of 2020 [Rumor]
https://www.techquila.co.in/nvidia-ampe...
FlyingBee ::
next year 7nm EUV NVIDIA Ampere GPU
Samsung's 7-nanometer process should use EUV
Navi ne bo imel dolgo časa 7nm prednosti, perf pa tudi ne, le cenovno mogoče
https://www.guru3d.com/news-story/nvidi...
klinker ::
Navi bo komaj Pascale dohitel, vsaj upam.
FlyingBee ::
Seveda se ne bo poznalo na ceni grafičnih, če bodo hitrejše od konkurenčnih pa vendar:
One source said that Samsung is aggressively undercutting prices for its 7nm node with EUV," says EETimes, "offering some startups a full mask set for less than a multi-layer mask (MLM) set at its rival.
https://www.pcgamesn.com/nvidia/ampere-...
klinker je izjavil:
1080 s 170w in 16nm je postavila mejo res visoko, celo za naslednje geforce. Ne za kupce, ampak za firmo je boljši p/W prvi cilj. Ne nazadnje je zato tudi kjučna vse manjša litografija.
Nvidia reportedly confirmed that it's partnered with Samsung to manufacture its Ampere GPU, which is expected to launch in 2020 using its 7nm extreme ultraviolet lithography (EUVL) process rather than continuing to source GPUs from longtime foundry partner TSMC.
https://www.tomshardware.com/news/nvidi...
FlyingBee ::
Updated, 7/5/19, 9:23am PT: Nvidia executive vice president of operations Debora Shoquist said in a statement that "Recent reports are incorrect - NVIDIA's next-generation GPU will continue to be produced at TSMC. NVIDIA already uses both TSMC and Samsung for manufacturing, and we plan to use both foundries for our next-generation GPU products."
Vprašanje kje bodo high end in kje midrange pa low end.
FlyingBee ::
Kot se šušlja, bo Ampere v prvi polovici 2020. Vprašanje ali bodo na TSMC 7nm ali na samo na Samsung 7?nm, a je sploh možno, da bi že bili na 5nm?
NVIDIA's foundry of choice is still unknown, however current speculations are predicting that Samsung will manufacture Ampere, possibly due to delivery issues that are taking place at TSMC.
BT52 ::
Samsung 7nm is EUV? Torej bi lahko rekli temu 5nm. Saj vemo kako marketing napihuje.
m0LN4r ::
Naceloma ni vazno, ce jim uspe priblizno razpoloviti porabo za isti performance.
Naprimer 1080Ti perf z 120W
Prvo večnamensko srednje veliko dirkališče v Sloveniji
https://predlagam.vladi.si/predlog/13186
FlyingBee ::
To bi moralo iti skozi. Naslednik 1660ti s 1080ti perf in 120 do 150W porabe za tovarniški OC.
m0LN4r je izjavil:
Svinja sanja kukuruz:)
dolenc ::
Točen to jaz čakam, 1080ti pri ene 150w, tko da dejmo nvidija nared kej :)
FlyingBee ::
Povsem verjetna situacija.
1660ti ima boljši perf od 980ti in pol manj porabe.
Wrop ::
Saj v roku 4 let je to za pričakovati.
FlyingBee ::
Ja, in avgusta naslednje leto bo 4 leta od gp102 aka 1080ti čipa.
Ampak Pascal je bil pravo tehnološko čudo.. 1080Ti kar ~70% hitrejša od 980Ti, in boost iz 1200Mhz na 2000Mhz. Brez skrbi, da 2660Ti ne bo na nivoju 1080Ti.
Buggy ::
Vi kar pozabte na 1080ti performance v entry-mid segmentu nove generacije. Se sveza 2070S/2080 ji komaj parirata, kaj bo pol neka entry level kartica kle zraven praskala :D
  • spremenil: Buggy ()
Wrop ::
Hipotetična 2660 TI bi lahko imela cca 50 % več transistorjev kot 1660 ti. To znese cca 10 milijard transistorjev. 11,8 milijard jih ima 1080 ti, 7,2 milijard jih ima 1080. 2070 jih ima 10,8 milijard. Zmogljivost se poveča za cca 30 %, pa si že dokaj blizu 1080 ti. Če še kaka igra malo "preveč" uporablja 16FP kalkulacije pa lahko 1080 ti počepne. V 32FP zmogljivosti bo 1080 ti še vedno precej v prednosti.
Spock83 ::
dolenc je izjavil:
Imaš gruče, da se ti pozna toliko poraba ter hlajenje? :D
dolenc ::
Tiha kišta, pa naj kar ostane tko :)
BT52 ::
dolenc je izjavil:
Jaz takoj kupim. Jup to je to. :D
Sanja svija kukuruz. Dvomim, da bo tole mid class cena. Performanca mogoče. Cena NE
  • spremenilo: BT52 ()
dolenc ::
Ti si pa verjetno mal watte pa eure zamenu
BT52 ::
NE nisem
Mid range je bil nekoč 250 eur.
rabelj5 ::
BT52 je izjavil:
NE nisem
nekoč si za 150 eur dobil radeona 4850, ki je bil za tiste čase in to ceno super kartica
kaj dobiš danes za 150 eur? isto kot si preden je mining nabil cene vseh gpujem (torej kar nekaj let nazaj), bolj ali manj, pa še tisto takrat bilo bolj tko :D
Alien123 ::
rabelj5 je izjavil:
BT52 je izjavil:
NE nisem
Inflacija, si kdaj slišal za to?
Cange ::
Razvoj GTX 1080ti je že plačan, ne vem kaj komplicirajo z nekimi ultra dragimi razvoji ko pa lahko copy paste gtx 1080ti na 7nm = 150e. Na ta način bi imeli veliko več časa za razvoj nex gen, posledično bi se tudi pocenil razvoj + povprečen gpu na gamerja bi bil veliko boljši, kar pomeni še hitrejši razvoj grafike.
Sklep: hitro in drago razvijanje po 5% boosta z nex gen GPU-ji vbistvu upočasnuje razvoj grafike.
dolenc ::
A noben sploh ni omenjal cene :), sam pač 1080ti pa 150w porabe.
Napihnjenje cene pa seveda niso posledica inflacije, najprej so potipal z gtx970, če bi zdej to bil srednji rang, ne več x60, pa je folk nabavljal, pol so še par % dodal, folk je navalil, in še bamf rtx madafakar!!! (še par %). Folk spet vse pokupu.
In zdej ti še amd prodaja 5500 (ekvivalent 260x, rx460) kot novi srednji rang!!! Pre je blo pa to sam za league of legends.
Še to.
Včasih se je sestavljal po yutubi "console killer" kište.
Kaj zdej dobiš za 300eur? 400eur je bil pa ps4 ko je izšel.
Me zanima če bo ob izzidu playstation 5 kak tak video, ker ob trenutnih cenah grafičnih lahk glih sam to kupiš. Sej ostalo je še kar solidno.
  • spremenil: dolenc ()
BT52 ::
Se strinjam to je inflacija na inflacijo. Rečimo temu davek na uspeh. :D Konzole pa so res killer. Še posebej, če bodo nove generacije imele SSD.
Cange ::
Lej tale uspeh:
https://www.nakupovanje.net/vsi-oddelki...
"Chinesium" reši marsikaj, ampak tile so šli predaleč.
rabelj5 ::
Alien123 je izjavil:
rabelj5 je izjavil:
BT52 je izjavil:
NE nisem
nisem vedel da je od 2008 250% ali več inflacija
destroyer2k ::
Za primerjavo kakšno "inflacijo" oz. greed smo doživeli v zadnjih generacijah.
Model Launch Launch MSRP (USD)
GeForce GTX 970 September 18, 2014 $329
GeForce GTX 1070 June 10, 2016 $379
GeForce RTX 2070 October 17, 2018 $499
GeForce GTX 960 January 22, 2015 $199
GeForce GTX 1060 6GB July 19, 2016 $249
GeForce RTX 2060 January 15, 2019 $349
Horas ::
ja, zmogljivost je pa tudi temu primerno zrasla
Alien123 ::
rabelj5 je izjavil:
rabelj5 je izjavil:
BT52 je izjavil:
NE nisem
Kaj boš rekel da se ti plača od 2008 do zdaj ni nič dvignila? Pa kakih 250% lol
i7 8700| NOCTUA NH-D14| gigabyte Z390 GAMING X| GIGABYTE GAMING OC 2080|
NZXT H440| 16GB DDR4 3600| SSD 970 evo+ 500gb| GSX 1200 pro
Razer Lancehead, Blackwidow elite| ASUS PG348Q| XBOX one| PS4
rabelj5 ::
4850 je bil takrat nekaj takega kot je danes recimo kaka 2070s in je stal okoli 150 eur, danes je pa 2060 440 eur, skoraj 3x več (oziroma če primerjam z 2070s pa skoraj 4x več)
plače pa tudi niso šle od takrat za 3x gor
destroyer2k ::
Horas je izjavil:
Prej pa ni zrastlo z vsako novo generacijo?
Cange ::
Tale graf pokaže da se je prodalo ~3x več GPU-jev v zadnjih 6 letih, mogoče se motim in je 2/3 folka imela GPU je samo za okras.
Še zakaj so GPU ji dragi:
Bwaze6 ::
To, da je dvig zmogljivosti dejansko manjši od dviga hitrosti, je dokaj novo.
Ob izidu Turinga je 1080 Ti po hitrosti konkurirala 2080, cena je bila podobna 1080 Ti ob izidu, kar je po dveh letih seveda predstavljalo podražitev. Nad njo je izšla 30% hitrejša 2080Ti za 50% več denarja. Seveda so to opravičili s popolnoma novo RTX tehnologijo, ki pa očitno v času aktualnosti Turing kartic še ne bo ravno polno zaživela - iger, ki raytracing uporabljajo vsaj deloma, je le peščica, vpliv na FPS je tako visok da je pogojno uporaben le v 1080p, kar nekaj razvijalcev pa je že odstopilo od svoje napovedane podpore raytracingu.
Lahko si tudi predstavljamo, da bodo ob dvigu RTX zmogljivosti v Ampere karticah to izrabile tudi prihajajoče igre (vsaj tistih par), kar jih bo verjetno napravilo precej neuporabne na Turing karticah - kupci Turinga so tako (pre)plačali razvoj, ki ga sami niti ne bodo deležni. Kar so kupci seveda opazili, in prodaja Turing kartic ni ravno blestela.
FlyingBee ::
Ampak Turing je ponudil boljši p/p, sicer ne kot bi bilo za pričakovati, pa vendar.
Bwaze6 ::
Kje? Mislim da ne šteje "če gledamo samo raytracing igre", ker nihče ne kupi 1200 EUR grafične kartice, da bi prešpilal pet špilov v dveh letih...
FlyingBee ::
Od 2070 Super in navzdol.
Bwaze6 ::
Price / performance razmerje 2070 SUPER se ni nič kaj izboljšalo glede na navadno, in če slednjo dobiš v kaki akciji, je primerjava še slabša. Nižje se mi pa ne da niti gledat, tam gre pa že za cenkanje za šestorček piva gor ali dol.
Horas ::
destroyer2k je izjavil:
Horas je izjavil:
ne tako drastično. začelo se je z maxwellom, potem pascal. zdaj pa turing
Horas je izjavil:
Horas je izjavil:
ROLF? S pod katere skale si pa ti prilezel? Al si se sam vceraj rodil? Nekateri se se spomnimo casa, ko je PC zastarel v letu ali dveh. In ti sanjas, da je turing nek velik preboj:).
FlyingBee ::
Na približno vsake 2 leti so izdali nov arch, že nekaj časa je tako. Največji preboj je pri zmanjšanju nm. Če gledamo zadnjih 10 let izdaj: 2008 unified shaders g80, 2010 Fermi, 2012 Kepler, 2014 Maxwel, 2016 Pascal, 2018 Turing. Future pa je 2020 Ampere.
Na Keplerju gtx 670 oc in i7 2600 sem nedavno preigral na fhd Doom 2016. Zastarelo?
Wrop ::
Včasih so bila 3 leta v strojni opremi, sploh GPU, kot razlika med modrim dirkačem in lenivcem. Posebej se spomnim prehod med ATI 9200 pro na ATI 9800 SE nato pa na Nvidia 7600 GT. To je kot, da bi naslednje leto na eni 1070 gledal samo še diapozitive na high nastavitvah.
FlyingBee ::
Saj jih že zdaj, če je heavy RT. Nvidia poskrbi za take prigode.
1 / 144
