Forum » Pomoč in nasveti » avast secureline VPN + OSX
ideep ::
Zdravo,
Ko se želim povezat na optimalno lokacijo, me vedno znova vrže ven.. povezave nikakor ni mogoče vzpostavit
Potem sem našla tole na avastu:
Sem na T2 omrežju. Kako nastavim te nastavitve na macu?
Če ga imam vklopljenega ne morem ne na mail, ne na nobeno stran:
Mi napiše
The VPN server did not respond. Verify the server address and try reconnecting.
If SecureLine VPN is unable to establish a connection, try the following solutions:
Your device:
Some routers have the option to enable or disable IPsec, sometimes displayed as VPN passthrough. For SecureLine VPN to connect and function properly, ensure that IPsec or VPN passthrough is enabled.
Consult your firewall vendor to check that UDP port 500 and UDP port 4500 are open on your firewall.
If SecureLine VPN is still unable to establish a connection, try to uninstall and re-install the software.
Mi napiše
This site can’t be reached www.xx.com took too long to respond.
Try:
Checking the connection
Checking the proxy and the firewall
ERR_TIMED_OUT
| » | Facebook TežavaOddelek: Omrežja in internet | 2353 (1994) | Sandi1987 |
| » | ASUS RX3041 firewallOddelek: Omrežja in internet | 1617 (1524) | whatever |
| » | VPN connection iz domačega omrežja v služboOddelek: Omrežja in internet | 4468 (4126) | darh |
| » | Iptables in C&C GeneralsOddelek: Igre | 2511 (2280) | Tito |
| » | težave z lowid-jem (router)Oddelek: Pomoč in nasveti | 2104 (1964) | Cokolesnik |
