Forum » Strojna oprema » Intel Core 9th-gen
Intel Core 9th-gen
Semafor ::
9900k je bullshit od proca, razen za te z majhnim ticem![]()
A to je največji intelektualni argument ki ga AMD fanatiki premorete?
klinker ::
FlyingBee ::
Čakaj, i9 9900k je najhitrejši v igrah, kaj zdaj ni jasno. Jaz pač ne bom za tak proc dajal denar, kerproc ni bottleneck, ampak nič ne izgubim, če priznam, da je v igrah pač najhitrejši.
FlyingBee ::
Lol, tile pa ne nakupujejo na mindfactory.
Back in April, Intel processors were used by 81.72 percent of people while AMD took an 18.26 percent share. And while Intel has gone up to 82.11 percent, AMD has dropped to 17.88 percent--the red team's lowest figure since February. It's worth remembering, however, that with the Ryzen 3000 series set to launch on July 7, things could start to change for AMD.
klinker ::
FlyingBee ::
Le marketing stunts. 10x večja firma, ki ima še polno drugih produktov in projektov poleg x86 cpu. Kaj vse je AMD prestal v zadnjih 10 letih, potem si lahko predstavljamo kaj lahko Intel.
Noi razmisli, kaj bi lahko postala NV. No na srečo se je zavedala, da bi se lahko zgodilo da bi AMD prodal grafični oddelek Intlu. Kaj bi bilošele potem.
FlyingBee ::
Le dva konkurenta, tako se bosta vrtela v krogu kot do zdaj, nič skrbi ne za eno ne za drugo firmo.
Intelov novi lineup, kot odgovor na zen2:
https://postimg.cc/Q9tkvd03
It's not a leak, it's academic (author).
Internet je pol čudnih novic:
https://www.techpowerup.com/257249/inte...
LOL.
Leading the pack is the Core i9-10900KF, a 10-core/20-thread chip clocked at 4.60 GHz with 5.20 GHz Turbo Boost, 20 MB of shared L3 cache, native support for DDR4-3200, and a TDP of 105 W
Torej 210W realno. :)
Intel has given its 14 nanometer node one last step of refinement to come up with the new 14 nm+++ nodelet. This enables Intel to significantly dial up clock speeds across the board. These processors come in the new LGA1159 package, and are not backwards-compatible with LGA1151 motherboards. These chips also appear to feature an on-package PCH, instead of chipset on the motherboard.
- spremenil: D3m ()
Nimaš kaj, Intel je podmazana mašinerija. HT bo zgleda spet v ponudbi, cene pa konkurenčne. Brez konkurence bi še vedno ponujali 4c/8t za 399$.
To, da bo novi socket, je klasika, pa tudi prijazno do proizvajalcev matičnih plošč.
Semafor ::
Fejk news. Cofe lake plate so namenoma imele default nastavitve v nasprotju z Intel politiko, zato so presegale 95W porabo, da sedaj profesionalni ziparji lahko ponosno skačete naokoli in se trepljate po rami.
Intel TDP Investigation: Boards Violating Turbo Duration
Seveda je to mogoče narediti samo pri arhitekturi ke se lahko navije, ne pri taki ki ne dosega niti oglaševanih ferkvenc.
Žalostno da je AMD arhitektura šele sedaj "dohitela" intelovo ki jo samo updejta tam nekje od izida 2. generacije
Buggy ::
Žalostno da je AMD arhitektura šele sedaj "dohitela" intelovo ki jo samo updejta tam nekje od izida 2. generacije![]()
Zalostno je samo to da mora proporcionalno en po budgetu tako mali AMD nasuvat v rit mastodona Intela ,da se sploh zmiga in da ne nateguje vec potrosnikov, ob tem pa je visek zalosti to da taksen odnost Intela eni celo zagovarjajo, podpirajo sicer ne ker so zgolj navijaci za kupit pa ni vec manevrskega prostora. To je zalostno!
Sam mora biti grozno biti Treer, k ti tvoj idol zgazi AMD in ni nobenega razloga za nakup INTEL CPUja.
Pa se doma ima problem z mamico, k je znorela, k je ves skret papir porabil za brisanje solz.
- spremenilo: tikitoki ()
Semafor ::
Eh, Ryzen uporabnikom razložit kaj je to navijanje... misija nemogoče.
- predlagalo izbris: camx ()
Semafor ::
Navijanje je hobi in ne standard. BTFO Treer.
Navijanje je -zastonj megaherci.
Eni proizvajalci predajajo procesorje ki lahko dosežejo to kar ponujajo v oglasu, imaš pa tudi druge proizvajalce ki lažejo o zmogljivosti svojih produktov, samo so njihovi fanboji tako prazne glave, da napadejo vse ki jim pokažejo kako jih strižejo.
Nič ni zastonj, otrok božji.
- spremenil: D3m ()
All core navijanje 8 jedrnika je zastarel koncept in recept za throtlanje.
Sploh pa za i9 9900K(F) rabiš še 300$ mobo in vodno hlajenje, gain je 5%, pa še komponentam nižaš življenjsko dobo.
Kot sem omenil, v igricah se praktično ne pozna, v productivitiju pa ga R9 3900X močno prehiti.
OC je flikanje, prava rešitev bo nova litografija oz. arhitektura.
klinker ::
Ampak hej.....če je pa zastonja yaaoowwww. ;)
- spremenil: D3m ()
@Semafor:
"Pri ryznu 2 oglaševane ferkvence sploh ni mogoče doseči, pa vas nič ne moti
Po pomoti predlagal izbris. Če malce preučiš delovanje procesorja pri obremenitvah ugotoviš, da je skoraj vseeno, dokler bo igra/aplikacija uporabljala več niti. SW, ki goni dve niti je bodisi zastarel oz. slabo spisan, bodisi pa specifika in zaradi 50MHz ne bo opazne rezlike v delovanju. Vse to so kvazi argumenti, ki ne zasenčijo smart optimizacij performansa.
Validen argument proti zenu2 je kriplan memory performance napram zen+. Ampak tukaj je huge L3...
- spremenil: Jarno ()
Smo že podali ugotovitve Treer.
Še enkrat.
Še enkrat.
(7/8): We've noticed large frequency boost behaviour changes with new motherboard firmware that was released on launch day (7/7). We are currently re-running all our test suite numbers and updating the article with the new data soon as appplicable. For further details please read here.
(7/9): We've updated the article benchmark numbers on the 3900X. We've seen 3-9% improvements in exclusive ST workloads. MT workloads have remained unchanged, Gaming had both benefits and negatives. We continue to work on getting updated 3700X numbers. Original BIOS results are marked with ** in the graphs.
(7/10): We've updated 3700X results as well.
PS, Da ne pozabite nov chipset Z490.
Zastoj? Draga maticna plosca in hladilnik so po novem zastojn? Kje? jaz bi tudi.
IvoJan ::
torej ce ne mislis navijat kupis najcenejso plato in stock cooler?
kurnik121 ::
najcenejšo plato, ki ima vse reči ki jih rabim in najcenejši cooler, ki je še relativno tih
Veliko srece, z no temi k intli..Navijanje je hobi in ne standard. BTFO Treer.
Vuli ::
heh, kar naenkrat je lahko Intel dal vsem novim cpujem še HT zraven, prej pa bog ne daj, da bi imel i5 HT.
Če gledamo 10th serijo. Aaa, pa spet nov socket. 1151 je že predolgo trajal.
Vuli ::
malo na veliko so začel sherat te fake news.
Bwaze6 ::
Mislim da novičarske strani dosegajo novo dno, ko objavijo novico (brez "morda", "leak", "nepreverjeno"), spodaj pa vidiš vir: WCCFTech.
Marsikaj iz leaka verjetno drži, 10-jedrni Comet Lake je že dolgo v Intelovih leakih za začetek 2020, ostalo (specifikacije, cene), so pa verjetno "AdoredTVjali" pri WCCFTech, in oni lepo povejo "Intel's 10th Gen 'Comet Lake' Desktop CPU Lineup Allegedly Leaks Out".
Allegedly.
Allegedly.
Sam da niso zaceli da ima tam en kitajski cipek priljepljen... so sicer poizkusali na nacin da so kao amd omogocil kitajcem svoj cpu...
KAVINSKY ::
HT je bil skoraj zagotovo izklopljen zaradi varnostnih lukenj. Verjetno so v zadnjem letu to popravljali. Razen če res niso mislili, da kupci ne rabijo toliko corov. 6/12 i5 bi bil huda konkurenca za r5.
| » | Nakup CPUja 2019 (strani: 1 2 3 )Oddelek: Kaj kupiti | 24635 (20273) | Predator X |
| » | Intel predstavil 9. generacijo Core procesorjev (strani: 1 2 )Oddelek: Novice / Procesorji | 27000 (23417) | MrStein |
