403 Forbidden pri dostopanju lokalno
Excavator ::
Če dostopam apache lokalno dobim 403 forbidden(You don't have permission to access / on this server.)
Če dostopam z zunanjim ip-jem, port forwardam port 80 dela normalno.
Vse hostam na Debian based OS-u, na Apache v2.4.25
Config imam direktno v apache2.conf, htaccess-a še nimam.
# Sets the default security model of the Apache2 HTTPD server. It does
# not allow access to the root filesystem outside of /usr/share and /var/www.
# The former is used by web applications packaged in Debian,
# the latter may be used for local directories served by the web server. If
# your system is serving content from a sub-directory in /srv you must allow
# access here, or in any related virtual host.
<Directory />
	Options FollowSymLinks
	AllowOverride All
	Require all denied
	Allow from *.*.*.*
</Directory>
<Directory /usr/share>
	AllowOverride None
	Require all granted
</Directory>
<Directory /var/www/>
	Options Indexes FollowSymLinks
	AllowOverride All
	Require all granted
</Directory>
#<Directory /srv/>
#	Options Indexes FollowSymLinks
#	AllowOverride None
#	Require all granted
#</Directory>
Naj pustim apache conf tak kot je in uporabim .htaccess v /www?
Apache in Node.JS
Oddelek: Izdelava spletišč
92632 (2318) dunda
Apache Alias pomoč
Oddelek: Omrežja in internet
91571 (1482) BlueRunner
Apache - localhost JA, IP naslov NE
187286 (7145) ManDriver
kako usposbim ssl
162325 (2054) pan
html ali java, izpis IPja
Oddelek: Programiranje
101589 (1505) Trubadur
