IE6 HELP !
IE6 HELP !
AIDS ::
LP,
Mogoce kdo ve kako v IE6 nastavis da lahko downloadas vec file-ov na 1x ? Ce grem na http, ftp, in lahko downlovdam samo 2 fila na 1x...
CaqKa ::
za to rabiš kakšen tweak.. ali pa recimo zunanji program kot je getright...
to je pač ena bedna omejitev v winsih...
Kebab ::
Probaj to:
Increase simultaneous HTTP connections
To abide by the HTTP specifications Windows limits the number of simultaneous connections that it will make to a single HTTP (web) server. This affects all Windows Internet applications that use the standard API, including Internet Explorer. The behavior can be seen when downloading multiple files from a web site only a certain number (2 or 4) will be active at any one time.
Create two new values, or modify the existing values, called 'MaxConnectionsPerServer' and 'MaxConnectionsPer1_0Server'. Change the values to equal the number of simultaneous requests allowed to a single HTTP server, the default values are 2 and 4 respectively.
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Setting]
MaxConnectionsPerServer REG_DWORD 0x00000005 (5) - change this to 4
MaxConnectionsPer1_0Server REG_DWORD 0x00000005 (5) - change this to 8
ahac ::
najboljša rešitev je da se nehaš igrat z IE pa daš gor resen browser:
http://mozilla.lugos.si/MFH/
CaqKa ::
vendar ker ti je pri srcu IE, ter pogrešaš samo tabe, ter par manjših dobrotic, poleg hitrega nalaganja, boš zgornji post spregledal in posegel po MyIE2.
Imate rajši Win 7 kot Win 10? Imamo rešitev. (strani: 1 2 3 4 )
Oddelek: Operacijski sistemi
15358718 (48949) Cervantes
AT komande
Oddelek: Programska oprema
162246 (1767) noraguta
Kako pohitriti FireFox
105067 (4778) Bakunin
edonkey2000
Oddelek: Omrežja in internet
191919 (1534) Mr.Joker
WinXP & Ram Drive
111417 (1265) andrej
