Kateri 55" in večji LCD televizor?
andrej69 ::
Sicer pa je vse jasno tudi kar se tiče procesiranja slike:) Letošnji procesor P5 je še pol koraka naprej:)
Argica ::
Link za Panasonic GZ950 1200€ prosim :)
kunguruj ::
@Andrej69, tista tabela o zanesljivosti ni preveč uporabna. Kolikor vidim je iz leta 2016 in zajema TV-je le do starosti 3 leta. Večina nas kupuje za daljše obdobje. OLED-i še niso vključeni, prav tako so vsi cenovni razredi vrženi v en koš.
skyform ::
andrej69 je izjavil:
Tukaj imaš citat iz testa za nekaj malo slabši model XH9005.
You get significantly better HDR picture quality with OLED TVs, and compared to Sony X900H (XH90) the divide was strikingly clear - and articulated in many interesting terms - to anyone who saw the TV during our testing, as it was placed next to Philips OLED805 and Panasonic HZ2000. It is not close but Sony's TV has one advantage, which is its higher full-screen brightness that contributes somewhat to the HDR presentation in bright daylight, although the OLED TVs still deliver a higher-contrast HDR picture with truer colors and "depth". We also noticed quite heavy banding at times in dark scenes on Sony X900H (XH90), which is a shame. Overall, we are a little disappointed with the TV's HDR picture quality, especially compared to the 2-year old X900F that benefitted from having more dimming zones.
Sony X900H (XH90) is a worthy successor to the Sony X900F (XF90) but it is not necessarily a better TV in terms of picture quality. It is competitive compared to Samsung's similarly priced LCD TVs with zone dimming and competitive in the segment for large-sized TVs, but is not close to matching OLED TVs that are inching still closer to mainstream prices.
XH9505 je kar boljši od XH9005, sploh v HDR in DV, ker je dosti svetlejši TV. XH9005 je v bistvu slabši kot XGH9505.
Primerjava
Argica ::
Samo skyform 55XH9505 je hudičevo drag, za denar dobiš OLED-a.
skyform ::
mihaelo je izjavil:
Tole je sedaj še težja odločitev:
https://www.telekom.si/zasebni-uporabni...
https://www.makspro.si/led-tv-sony-kd-5...
Baje da naj bi imel letošnji Sony XH9505 BISTVENO izboljšan FALD sistem torej BLOOMINGA naj bi bilo zelo malo ali če sem slišal prav skoraj da nič. Sedaj imam model XF9005 v kabinetu in moram reči da sem s TVjem ZELO ZADOVOLJEN edino blooming je malo moteč in sedaj če lahko kdo poda mnenje ali je ta zadeva pri letošnjem SONYu res bistveno boljša. Vsi pa vemo da so časi LCDjev kitajskih proizvajalcev ko je bilo v ozadju mnogo zatemnitvenih con žal minili.
Jop res je, local dimming algoritem je na letošnjem modelu zelo izboljšan.
Argica je izjavil:
Se strinjam, da je drag ampak kateri letošnji OLED dobiš za ceno XH9505? Mislim da noben, so vsi dražji, lanske ja, letošnje pa ne. Saj je pa high end LCD, najbližja zadeva OLEDu in celo boljša v čem, zato je tudi cena blizu OLEDa in mu tudi cena zelo pade ob koncu leta, bolj kot OLEDom, 9000 serije se zadnje 2-3 leti dobi ob koncu in začetku leta za 900-1000EUR.
  • spremenil: skyform ()
Argica ::
SONY KD55XF9005BAEP dobim za dobrih 800e. Samo je že out, to je 2017 model ne?
easyrider3 ::
Argica je izjavil:
Pa v akciji je letos bil že parkrat lasnki model Sony KD 55XG9505 za 850 Eur to ti je bomba za tak denar.
V Maks pro trgovini imaš Panasonic za 1.200 Eur sam preverit moraš če je zaloga
https://www.makspro.si/avdio-in-video/t...
skyform ::
skyform je izjavil:
easyrider3 je izjavil:
V tistem videu zgoraj na koncu Vincent Teoh pove da za gledanje filmov priporoča raje Panasonica kako to sedaj,ko pa v večina primerov glih obratno pravijo in ocenjeno je, da je Sony A8 najboljši OLED televizor za gledanje filmov.
Pa še to kako to da Philips ima tako visoke cene OLED televizorjev saj vedno so imeli najcenejše televizorje to mislim za LED
Najbrž ravno zaradi boljšega DVja, za SDR je boljši Sony, za HDR sta tam neki še vedno Panasonic majhna prednost, za DV je boljši Panasonic. Šport bi naj bil boljši na Sonyju, ker je A8 prvi OLED, ki ima enak motion kot na njihovih LCDjih. Ampak če je prenos športa v 30fps in ga žliš pogladiti je Panasonic boljši, ker ima bolj močan SOE in tako malo artefaktov kot noben druga znamka, zadeva je skor tako kot da bi gledal Gemini Man v 120fps, res svetovno in deluje enako v filmih.
Tudi Philips tukaj briljira:) Nekaj citatov iz različnih testov.
Philips has introduced a couple of excellent changes to its always powerful ‘Perfect Motion’ processing this year: a refined Movie interpolation mode, and a new PureCinema mode. The former uses frame interpolation to reduce judder and blur, but on a low enough level to avoid processing artefacts and stop films succumbing to the dreaded, over-smooth ‘soap opera effect’.
PureCinema reorders the frame playback so that, say, a 24p movie contained in a 3:2 60Hz signal will be converted into a 5:5 cadence 120Hz signal – and it works brilliantly.
Motion is again superb on the Philips with correct pulldown applied to 24fps content without adding any induced judder to film content within the Pure Cinema setting. Movie adds a little De-blur and Philips claims this helps with the effects of the sample and hold technology of OLED to look smoother without adding in SOE, but I could tell interpolation was being applied straight away, your mileage may vary however. You can of course experiment with other content, such as fast moving sports and video with the P5 engine driving the motion styles available, including a personal mode. One thing we did find was that the more intense settings did introduce motion artefacts and false edges, but if care is taken in setting up the interpolation you can find settings that do not have as many artefact issues. While personally I can’t stand adding in frame interpolation, the Philips processing is amongst the best available if that is your cup of tea.
The other big change to picture performance this year can be found in its motion handling. Sport interpolation has gone completely, while a new Pure Cinema mode manages to maintain clarity yet keep a sense of cinematic judder. It’s a best-of-both worlds approach for film fans.
Saj zato ravno pa me nov Philips zanima, ker je izboljšan v vseh pogledih in ker še kar ni bilo OLED TVja, ki bi imel vse kar si želim. Sony in Panasonic sta bila za enkrat najbližje a je vsakemu nekaj manjkalo. Pri Panasonicu mi ni všeč SDR, OS in dalinjc, pri Sonyju pa DV in SOE, če bi ju združil bi dobil ven TV skoraj po moji želji, morda pa je Philips to dosegel z letošnjem modelom in ravno zato bom ga sprobal, ker kot sem že večkrat napisal me sploh ne zanima znamka ampak slika in funkcije, ki najbolj odgovarjajo mojemu okusu.
easyrider3 ::
Skyform verjetno to misliš za model 935 ker 805 je že malo slabši ali boš prav tega sprobal?
skyform ::
805, 935 je predrag in ne rabim soundbar, ki je zmontiran na stojalo.
andrej69 ::
kunguruj je izjavil:
Saj se do danes ni nič kaj spremenilo.. Kar se tiče Philipsa, ima še nekoliko kvalitetnejšo elektroniko od leta 2018:) kvalitetnejše osnovne in napajalne plošče.. Sicer pa sem že dosti napisal okoli okvar določenih televizorjev:) Danes je predvsem važno, da , če kupuješ televizor na daljše obdobje, da vzameš pri nakupu podaljšano garancijo. Pa vseeno za katero znamko televizorja gre, ali je to Sony, Philips, Panasonic, ker se vsi televizorji kvarijo:) Nekateri televizorji ne dosežejo niti par tisoč ur delovanja:) Danes moraš imeti precej sreče pri nakupu.. Tako, da je danes pri nakupu bolj važno kako kvalitetno sliko ima določen televizor, kakšen zvok, smart možnosti itd.. Ker kar se tiče okvar, ni danes nikakršnega pravila kako dolgo bo televizor deloval:)) Lahko deluje par let, lahko pa samo par mesecev.
  • spremenil: andrej69 ()
easyrider3 ::
Ja res je tako da ne moreš vedeti koliko časa bo delal televizor tudi na drugih področjih je podobno razen kakih izjem kjer še vedno dobiš kvaliteto katera deluje dolgo let brez problema to govorim za kašen avto kot je Lexus pri večinah tega ni.
Bantani ::
Argica je izjavil:
XE model je 2017
XF model je 2018
XG model je 2019
XH model je 2020
Če te pa že zanima nakup 55XF9005 imaš trenutno na extreme digital za dobrih 736eur.
https://edigital.si/led-tv-sprejemniki/...
edublin ::
Uff, ste se pa razpisali danes... Človek oddela službo in smo že skor 2 strani naprej :)
Samo na kratko - Andrej - nisem prepričan glede daljinskega upravljalnika, da sta ista - tisti na sliki, ki je osvetljen in moj... Sem šel prav navodila gledat in v Slo navodilih nikjer ne piše nič o osvetljenosti daljinca ali pritiskanju kakšne tipke. Lahko izvem, kaj moram pritisniti, da se osvetli daljinec?
Zmotilo pa me je mnenje, da se na slikah ne vidi nič posebnega... Zame te fotografije argumentirano dokazujejo, da gre za zaslon, ki je slab, milo rečeno. Tolikšne napake pri prikazu slike bi sprejel pri nekem slabem SD filmu iz 70 let prejšnjega stoletja, ne pa pri 4k signalu, kjer gre za nekaj preprostega prelivanja barv.
Potem se omenja nastavitve za Apple tv - najprej posodobitev, nato nastavitev v nekem zaporedju (4:4:2) itd... Zdaj - ali Philips želi, da smo vsi po novem strokovnjaki za TV-je in imamo čas prva dva meseca po nakupu televizorja sedeti pred njim in nastavljati in posodabljati vsako stvar? In da se vsi razumemo v vse nastavitve v kopici pod-menijev? Enako se očitno od mene pričakuje za ostale nastavitve zaslona... V teh 10 dneh sem zabil kar nekaj časa na nastavitvah in Yotube filmih itd... Pa si res vsi uporabniki vzamejo toliko časa, si znajo vse to poiskati, nastaviti?
Presenečen sem, kako je lahko tak rang TV-ja v letošnjem letu toliko slabši od Sonyja, ki je v dnevni sobi vse od leta 2013 ... Sem upal, da bom z nakupom danes naredil še korak naprej v kakovosti prikazane slike, ne da bo to vsaj 2 ali 3 korake nazaj...
Hvala tudi ostalim za mnenja - tako o Philipsu kot o nasvetih za nakup... Bom spremljal tole temo še naprej in bomo videli.
damirj79 ::
Tisto z youtube ne vem, meni izgleda da je stream prevec kompresiran zarafi nizke hitrosti. V youtube obstaja prikaz statistike (stats for nerds) pa poslji se to slikco.
Glede pikic na crnem ozadju, isci napako na appletv ali pa na kablu. Meni je s slabim kablom enako delalo na xboxu.
andrej69 ::
edublin je izjavil:
Če si televizor nastavil kot treba je potem 100% težava v samem panelu:) Kar je po mojih izkušnjah zagotovo.. Ker te težave niso nito toliko vezane na same nastavitve.. Saj sem ti posredoval dva testa tega modela, pa vidiš, da je slika odlična.. Pa tudi mnenja uporabnikov to potrjujejo.. Če ima ta tvoj sorodnik možnost, ga naj vsekakor zamenja ali pa uveljavlja garancijo:))Kar se tiče daljinca je zagotovo pravi (model 8505..) Edino, če ima ta tvoj sorodnik model 8535 ali 8555, ki pa nimata osvetlitev imata pa zadaj tipkovnico. Osvetlitev še ima tudi model 8545. Toliko za informacijo.
scipascapa ::
Sony KD 55XG9505 800 + ddv....predrago?
easyrider3 ::
scipascapa je izjavil:
To ni nič predrago ampak super cena z itak televizor
Imate kolegi znalci kak best buy za 50'' (in 55'') do 900€ ca?
Hvala
andrej69 ::
Machete je izjavil:
Hvala
Tukaj imaš nekaj modelov.
https://www.bigbang.si/philips-led-lcd-...
https://www.moj-tv.com/artikel/led-tv/p...
Če pa že iščeš za okoli 900 evrov, pa še primakneš 100€ več in dobiš že tale odličen OLED:)
https://www.bigbang.si/55oled754-12-phi...
Aquinas ::
Je kdo že kupoval pri ACS Sony? So legit?
scipascapa ::
Zelo legit.
mihaelo ::
Aquinas je izjavil:
Zelo vredu. Že večkrat kupoval in vse je bilo ok.
krco77 ::
Tud js pr njih kupu lani TV. 55XF9005. Z 5let garancije. Super tv! ? in prav tako trgovina Acs.
PikaPoka828 ::
Machete je izjavil:
Hvala
Pričakuje se, da bo oled tehnologija cenejša za izdelavo kot led.
Zaenkrat temu še ni tako, zaradi razmeramo nove tehnologije (oled).
Ali so mogoče kakšne ocene kdaj bi to tega preloma prišlo?
nomad_soul ::
Mnenja glede Samsung UE75TU7172UXXH? Dobi se za 1k€, pa še soundbar ti dajo povrh.
Skopi podatki na spletu, verjetno balkan verzija. :))
A je Edge LED + 75" == šrot?
andrej69 ::
nomad_soul je izjavil:
Mnenja glede Samsung UE75TU7172UXXH? Dobi se za 1kEUR, pa še soundbar ti dajo povrh.
Za takšen denar ti jaz priporočam nekoliko manjši model toda občutneje kvalitetnejši:) Seveda brez soundbara..:D
Pa še tale model Philipsa je nekoliko kvalitetnejši..
https://www.mimovrste.com/ultra-hd-4k-t...
Če pa že Samsung pa raje tale model.
PikaPoka828 ::
PikaPoka828 je izjavil:
Machete je izjavil:
Hvala
No, malce sem se sam pozanimal, napišem svoje izsledke, lahko me popravite, lahko še komu pomagam:
Pametno je počakati na Konko da vstopi na ameriški trg. Predvideno je bilo letos, vendar so preložili.
Cene naj bi v letu 2021 konkretno padle, oled tehnologija pa naj bi prevladala.
Kaj paziti pri kupovanju novega TV:
Don’t buy a TV with less than 4K resolution. Avoid full HD or 1080p sets.
You can skip 8K TVs (for now). 8K TVs are super expensive, and 8K movies and shows aren't available yet.
Expect to pay about $500 for a good 55-inch 4K TV. And at least $900 for a 65-inch model.
Look for 60 Hz or 120 Hz refresh rate: When it comes to refresh rates, 60 Hz is good, but 120 Hz is better. A higher refresh rate provides smoother motion for everything from movies and shows to live sports and gaming.
Look for an HDR-compatible set: This offers more realistic colors and better contrast.
OLED TVs look much better than most LCD sets: But QLED TVs from Samsung, Vizio and TCL are an affordable middle ground.
Look for at least four HDMI ports. And opt for the newer HDMI 2.1 format if you can.
Plan to buy a soundbar. TV speakers are worse nowadays because the screens are thinner.
Avoid extended warranties. Your credit card company may already provide purchase protection
Klemzy17 ::
Zdravo,
Sam imam televizor SONY XF90 in pa zvočni sistem LOGITECH Z906. Ali je tukaj kakšen, ki se spozna na 5.1 sisteme in pa zanimajo me tudi določene nastavitve na TV-ju. Sem gledal že pod temo kjer so pisali o Z906 samo vidim da ni nekih odgovorov tam.
Lp,
fpbs ::
Glede padca cen OLEDov je predvsem odvisno, ali bo Samsung ponudil na tržišče svoje QD-OLEDe.Vzorčne panele je že dobavil Sonyju in Panasonicu. Na tržišču naj bi se pojavili leta 2021. Če se bo to zgodilo, se bodo cene LGejevih panelov znižale, posledično tudi cena njihovih OLEDov. LCDeje bodo še nekaj let proizvajali kitajci, dokler jih povsem ne izrinejo OLEDi.
Machete je izjavil:
Hvala
hvala
kunguruj ::
Ker bom v prihodnjosti kupil nov TV sem se malo bolj poglobil. Zelo važen faktor je zanesljivost in trajnost. Neumno se mi zdi, da bom dal 2000 €, po dugi strani pa marsikdo reče, da danes moraš imeti srečo pri nakupu, ker nikoli ne veš, kdaj se lahko kaj pokvari. Priporočajo ti, da kupiš podaljšano garancijo. Za TV sem pripravljem plačati nekoliko več, vendar pričakujem, da bo deloval vsaj 10 let če ne več. Splošna garancija velja 2 leti, dokupljena garancija pa še dodatna 3 leta in ne pridobiš veliko, če pričakuješ da bo TV deloval vsaj 10 let, 5 let nimaš pokritih. Vse navedeno me odbija, da bi v TV investiral večje zneske.
Malo sem gledal teste zanesljivosti, ki mi je najbolj poglaviten faktor pri nakupu TV-ja in nekaj jih delim tudi tu:
Test iz ZDA:
https://www.consumerreports.org/lcd-led...
 Graf60+
Graf60+
 Graf50+
Graf50+
Rezultati so zbiranje podatkov od leta 2017 do 2020. Vidi se, več denarja več zanesljivosti in obratno, kar bi tudi moralo biti logično. Manjka Panasonic, ki ni prisoten v ZDA. Pričakovano je Sony na prvem mestu, zelo dobro je uvrščen tudi LG.
Še test iz Anglije. Verjetno bi znali biti zanimivi rezultati zanesljivosti na spodnji povezavi, vendar je test plačljiv in ga nisem kupil. Vsekakor bi lahko kakšen tak plačljiv test imeli in pokazali prodajalci TV-jev, da bi se kupci lažje odločali, predvsem tisti, ki ponujajo zmagovalce. Test zajema LG, Panasonic, Samsung, Sony in Toshiba in že tu lahko vidimo iz grafikona na spodnji povezavi, da obstajajo razlike med najbolšim in najslabšim, kaj šele če bi vključili še druge nizkocenovnike, razlike v zanesljivosti bi bile še večje.
https://www.which.co.uk/reviews/televis...
Še test iz Nemčije. Vidi se graf tako zadovoljstva strank kakor zanesljivosti proizvoda, rezultati so različni.
https://www.test.de/Handy-Fernseher-Lap...
Po vsem tem kar sem pogledal, se nekako najbolj nagibam k Japoncem.
andrej69 ::
@kunguruj
Napisal si, da želiš, da ti televizor deluje 10 let. Pa te moram razočarat, da karkoli boš kupil ne bo dosegel teh let:)) Res je, da se pri televizorjih ne gledajo leta temveč delovne ure. Edino, če boš gledal 10 let eno uro ali dve na dan, potem bo televizor dosegel mogoče takšno starost.. Televizorji leta nazaj so bili druga zgodba, današnji televizorji pa zopet druga.. Če ti bo deloval 5 let ali nekaj več, brez kakršnekoli okvare boš lahko "zelo zadovoljen", pa vseeno kaj boš kupil Sony, Panasonic itd.. Predvsem je danes preveč težav z paneli, od okvar osvetljenj te okvare so danes na prvem mestu, in pa okvare samih pixlov:)) Potem pa je tudi kar nekaj težav z samim napajanjem televizorja. Kar se tiče okvar osvetljenja se lahko dosti naredi v tej smeri, da se osvetljenje ne nastavi na maximum, in podobno velja tudi za sam kontrast.. Te dve stvari podaljšujeta življensko dobo samega panela. Tako, da kot sem že napisal ti želim res veliko sreče pri nakupu, in, da ti bo televizor dosegel takšno življensko dobo..
kunguruj ::
Najprej sem načrtoval nakup OLED-a 65" za kakšnih 2000 €. Sedaj ko vidim, da je zanesljivost najsodobnejšega visokotehnološkega "škarta" zelo slaba, sem pripravljen za TV odšteti 1000 € + kakšen stotak. Razmišljal sem o LED 65 ali OLED 55. Doma sem izrezal karton v dimenzijah 65", ga postavil v dnevno sobo, da vidim reakcijo družine na tako velik "okvir" sredi dnevne sobe. Ni njim bilo moteče oziroma preveliko tako, da se je tehnica nagnila na stran LED 65".
Vseeno se zaradi zanesljivosti, kakor sem že opisal v zgornjem prispevku, pa tudi zaradi vsega ostalega, najbolj nagibam k Japoncem.
Prva izbira je Sony KD-65XH90, ki se po testih slike kar zelo približa OLED-om. Največ bomo gledali itak kabelsko televizijo HD programe. Trenutno je cena 1400 €, pričakujem, da bo ob kakšni akciji padla še za stotak ali dva.
Veliko pohval je deležen tudi Panasonic, katerega ne poznam najbolje. Kateri model Panasonica bi bil primerljiv s Sony KD-65XH90? Ali bolj priporočate Sony ali Panasonic?
Senior Dev ::
Dobro si to izrezal karton in snemal reakcije družinskih članov. Jaz pravim samo pogumno naprej in kupi en OLED velikosti 65. Verjetno je najboljša izbira oz. best buy kar LG OLED 65B9SLA za 1400€ na firmo je to tam okoli 1100€ 1200€ kar ni nek denar za 65 OLED.
scipascapa ::
LG OLED 65B9SLA 1400 kje?
andrej69 ::
Panasonic je odličen proizvajalec televizorjev in za mene osebno nekaj kvalitetnejši od Sonya in ostalih proizvajalcev. Toda kar se tiče kvalitete slike ravno nima nekega TOP modela. Sony ima v najvišjem rangu nekoliko boljšo izbiro. Sicer pa sta recimo modela HX800 in model HX940 zelo dobra modela:) Model HX940 posebej kar se tiče procesiranja slike:))Žal mi je, da ima tale serija v glavnem modele z IPS panelom. Razen največja velikost ima VA panel. Ker, če bi imela ta serija tudi v manjših diagonalah VA panel bi bil tale model vsekakor zelo konkurenčen Sony modelom najvišjega ranga.. Tako, da če se odločaš med Sonyem in Panasonicom, je Sony nekoliko boljša izbira kar se tiče kvalitete slike. Recimo, če pa bi gledal večinoma v osvetljenem prostoru in nikdar v mraku ali popolni temi, pa je Panasonic HX940 odlična izbira, in bi ga jaz osebno vsekakor prej kupil kakor pa Sonya:)
kunguruj ::
@Andrej69
To je tudi mene presenetilo, da Panasonic v rangu 65" nima VA panela. Sem mislil, da sem kaj spregledal oz ne poznam njihovih produktov. Kot gledanja TV-ja bo dokaj naravnost, zato se bolj nagibam k VA kakor IPS panelu, vseeno je kontrast boljši pri VA panelu. Otroci bodo gledali TV bolj pri svetlem, starši pa zvečer bolj v mraku :-)
andrej69 ::
@Andrej69
Kar se tiče modela HX800 ima v velikosti 65˝ VA panel, toda model HX940 pa ga nima. Torej, če boš gledal v mešanem okolju potem ti je bolje vzet Sonya.
Drugače pa je tudi zelo dobra izbira Panasonic model HX800:)
scipascapa ::
andrej69 ::
scipascapa ::
Dimenzije s stojalom: 1454 x 893 x 335 mm
me gusta...je dober tv?
andrej69 ::
Zelo kvaliteten:) Edini mali minus mu je, da ravno ne prikazuje črnih kadrov na nivoju kakšnega Sony FALD modela ali recimo Philips modela 8505. Kar pa se ostalega tiče pa odličen televizor.
scipascapa ::
sej tole velja ne?
XH90 = XH9505 ?
KD-55XH90 / KD-65XH90 1050 + ddv
TX-58HX810E / TX-65HX810E
decision :)
Bantani ::
XH90 pa XH95 sta različna modela...XH95 je rang XG95.Na tvojem mestu bi raje vzel XG95 kot tega panasonica ali XH90.
easyrider3 ::
Oznake pri Sony televizorjih pomenijo modelno leto in sicer gre tako XF= 2018
XG= 2019
XH= 2020
Potem imaš pa še po razredih od nižje do najvišje. XH80
XH85
XH90
XH95
Stvar je taka da lanski Sony model XG95 je bil eden najboljših LED televizorjev in letošnji model XH95 je še malo boljši vendar lanski model ima tisto kar letošnji nima HDMI 2.1 kar zelo jezi igralce iger. Vsekakor je pa veliko govora in večina pravi da je še vedno boljša izbira lanski model XG95 kakor letošnji XH90 in tudi cenovno je kar razlika.
nomad_soul ::
Hvala andrej, bom pogledal te Philips-e.:D
To verjetno ne velja za naš prostor.
Wrajtn28 ::
Preletel sem zadnje par strani in sem malenkost v dilemi za kater model se odločit. Iščem 55 ekran in rad bi 100hz, predvsem zaradi športa...
Bi vzeli v tem primeru SONY (drugače mislim, da je 100hz od serije 85, če se ne motim) kd55xg9505baep (https://www.bigbang.si/sony-4k-hdr-kd55... ali raje enega izmed najcenejših oled - PHILIPS 55oled754 (https://www.bigbang.si/55oled754-12-phi.... Budget do 1000...
294 / 535
