Novice » Operacijski sistemi » Windows 10 z reklamami tudi v Raziskovalcu
AndrejO ::
Jaz sem tisti tretji tabor, ki enakopravno in brez diskriminacije pljuva po vseh pojavnih oblikah dreka.
- spremenil: AndrejO ()
AndrejO ::
krneki0001 je izjavil:
Ne, ti si samo še en, ki pljuva.
Seveda je moj tabor podmnožica množice vseh, ki pljuvamo (vključno s teboj). Hkrati sta preseka mojega tabora s tistima, ki si ju predhodno navedel, prazni množici.
krneki0001 ::
# Tweaked Win10 Initial Setup Script
# Primary Author: Disassembler <disassembler@dasm.cz>
# Original Version: 1.4, 2016-01-16
# Tweaked based on personal preferences for @alirobe 2016-03-23 - v1.4.1
# NOTE: MAKE SURE YOU READ THIS SCRIPT CAREFULLY BEFORE RUNNING IT + ADJUST COMMENTING AS APPROPRIATE
# This script will reboot your machine when completed.
# Ask for elevated permissions if required
If (!([Security.Principal.WindowsPrincipal][Security.Principal.WindowsIdentity]::GetCurrent()).IsInRole([Security.Principal.WindowsBuiltInRole]"Administrator")) {
Start-Process powershell.exe "-NoProfile -ExecutionPolicy Bypass -File `"$PSCommandPath`"" -Verb RunAs
Exit
# Privacy Settings
# Disable Telemetry
Write-Host "Disabling Telemetry..."
Set-ItemProperty -Path "HKLM:\Software\Policies\Microsoft\Windows\DataCollection" -Name "AllowTelemetry" -Type DWord -Value 0
# Enable Telemetry
# Remove-ItemProperty -Path "HKLM:\Software\Policies\Microsoft\Windows\DataCollection" -Name "AllowTelemetry"
# Disable Wi-Fi Sense
Write-Host "Disabling Wi-Fi Sense..."
If (!(Test-Path "HKLM:\Software\Microsoft\PolicyManager\default\WiFi\AllowWiFiHotSpotReporting")) {
New-Item -Path "HKLM:\Software\Microsoft\PolicyManager\default\WiFi\AllowWiFiHotSpotReporting" -Force | Out-Null
Set-ItemProperty -Path "HKLM:\Software\Microsoft\PolicyManager\default\WiFi\AllowWiFiHotSpotReporting" -Name "Value" -Type DWord -Value 0
Set-ItemProperty -Path "HKLM:\Software\Microsoft\PolicyManager\default\WiFi\AllowAutoConnectToWiFiSenseHotspots" -Name "Value" -Type DWord -Value 0
# Enable Wi-Fi Sense
# Set-ItemProperty -Path "HKLM:\Software\Microsoft\PolicyManager\default\WiFi\AllowWiFiHotSpotReporting" -Name "Value" -Type DWord -Value 1
# Set-ItemProperty -Path "HKLM:\Software\Microsoft\PolicyManager\default\WiFi\AllowAutoConnectToWiFiSenseHotspots" -Name "Value" -Type DWord -Value 1
# Disable SmartScreen Filter
# Write-Host "Disabling SmartScreen Filter..."
# Set-ItemProperty -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Explorer" -Name "SmartScreenEnabled" -Type String -Value "Off"
# Set-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\AppHost" -Name "EnableWebContentEvaluation" -Type DWord -Value 0
# Enable SmartScreen Filter
# Set-ItemProperty -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Explorer" -Name "SmartScreenEnabled" -Type String -Value "RequireAdmin"
# Remove-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\AppHost" -Name "EnableWebContentEvaluation"
# Disable Bing Search in Start Menu
Write-Host "Disabling Bing Search in Start Menu..."
Set-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Search" -Name "BingSearchEnabled" -Type DWord -Value 0
# Enable Bing Search in Start Menu
# Remove-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Search" -Name "BingSearchEnabled"
# Disable Location Tracking
Write-Host "Disabling Location Tracking..."
Set-ItemProperty -Path "HKLM:\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Sensor\Overrides\{BFA794E4-F964-4FDB-90F6-51056BFE4B44}" -Name "SensorPermissionState" -Type DWord -Value 0
Set-ItemProperty -Path "HKLM:\System\CurrentControlSet\Services\lfsvc\Service\Configuration" -Name "Status" -Type DWord -Value 0
# Enable Location Tracking
# Set-ItemProperty -Path "HKLM:\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Sensor\Overrides\{BFA794E4-F964-4FDB-90F6-51056BFE4B44}" -Name "SensorPermissionState" -Type DWord -Value 1
# Set-ItemProperty -Path "HKLM:\System\CurrentControlSet\Services\lfsvc\Service\Configuration" -Name "Status" -Type DWord -Value 1
# Disable Feedback
Write-Host "Disabling Feedback..."
If (!(Test-Path "HKCU:\Software\Microsoft\Siuf\Rules")) {
New-Item -Path "HKCU:\Software\Microsoft\Siuf\Rules" -Force | Out-Null
Set-ItemProperty -Path "HKCU:\Software\Microsoft\Siuf\Rules" -Name "NumberOfSIUFInPeriod" -Type DWord -Value 0
# Enable Feedback
# Remove-ItemProperty -Path "HKCU:\Software\Microsoft\Siuf\Rules" -Name "NumberOfSIUFInPeriod"
# Disable Advertising ID
Write-Host "Disabling Advertising ID..."
If (!(Test-Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\AdvertisingInfo")) {
New-Item -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\AdvertisingInfo" | Out-Null
Set-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\AdvertisingInfo" -Name "Enabled" -Type DWord -Value 0
# Enable Advertising ID
# Remove-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\AdvertisingInfo" -Name "Enabled"
# Disable Cortana
Write-Host "Disabling Cortana..."
If (!(Test-Path "HKCU:\Software\Microsoft\Personalization\Settings")) {
New-Item -Path "HKCU:\Software\Microsoft\Personalization\Settings" -Force | Out-Null
Set-ItemProperty -Path "HKCU:\Software\Microsoft\Personalization\Settings" -Name "AcceptedPrivacyPolicy" -Type DWord -Value 0
If (!(Test-Path "HKCU:\Software\Microsoft\InputPersonalization")) {
New-Item -Path "HKCU:\Software\Microsoft\InputPersonalization" -Force | Out-Null
Set-ItemProperty -Path "HKCU:\Software\Microsoft\InputPersonalization" -Name "RestrictImplicitTextCollection" -Type DWord -Value 1
Set-ItemProperty -Path "HKCU:\Software\Microsoft\InputPersonalization" -Name "RestrictImplicitInkCollection" -Type DWord -Value 1
If (!(Test-Path "HKCU:\Software\Microsoft\InputPersonalization\TrainedDataStore")) {
New-Item -Path "HKCU:\Software\Microsoft\InputPersonalization\TrainedDataStore" -Force | Out-Null
Set-ItemProperty -Path "HKCU:\Software\Microsoft\InputPersonalization\TrainedDataStore" -Name "HarvestContacts" -Type DWord -Value 0
# Enable Cortana
# Remove-ItemProperty -Path "HKCU:\Software\Microsoft\Personalization\Settings" -Name "AcceptedPrivacyPolicy"
# Set-ItemProperty -Path "HKCU:\Software\Microsoft\InputPersonalization" -Name "RestrictImplicitTextCollection" -Type DWord -Value 0
# Set-ItemProperty -Path "HKCU:\Software\Microsoft\InputPersonalization" -Name "RestrictImplicitInkCollection" -Type DWord -Value 0
# Remove-ItemProperty -Path "HKCU:\Software\Microsoft\InputPersonalization\TrainedDataStore" -Name "HarvestContacts"
# Restrict Windows Update P2P only to local network
Write-Host "Restricting Windows Update P2P only to local network..."
Set-ItemProperty -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\DeliveryOptimization\Config" -Name "DODownloadMode" -Type DWord -Value 1
If (!(Test-Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\DeliveryOptimization")) {
New-Item -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\DeliveryOptimization" | Out-Null
Set-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\DeliveryOptimization" -Name "SystemSettingsDownloadMode" -Type DWord -Value 3
# Unrestrict Windows Update P2P
# Remove-ItemProperty -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\DeliveryOptimization\Config" -Name "DODownloadMode"
# Remove-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\DeliveryOptimization" -Name "SystemSettingsDownloadMode"
# Remove AutoLogger file and restrict directory
Write-Host "Removing AutoLogger file and restricting directory..."
$autoLoggerDir = "$env:PROGRAMDATA\Microsoft\Diagnosis\ETLLogs\AutoLogger"
If (Test-Path "$autoLoggerDir\AutoLogger-Diagtrack-Listener.etl") {
Remove-Item "$autoLoggerDir\AutoLogger-Diagtrack-Listener.etl"
icacls $autoLoggerDir /deny SYSTEM:`(OI`)`(CI`)F | Out-Null
# Unrestrict AutoLogger directory
# $autoLoggerDir = "$env:PROGRAMDATA\Microsoft\Diagnosis\ETLLogs\AutoLogger"
# icacls $autoLoggerDir /grant:r SYSTEM:`(OI`)`(CI`)F | Out-Null
# Stop and disable Diagnostics Tracking Service
Write-Host "Stopping and disabling Diagnostics Tracking Service..."
Stop-Service "DiagTrack"
Set-Service "DiagTrack" -StartupType Disabled
# Enable and start Diagnostics Tracking Service
# Set-Service "DiagTrack" -StartupType Automatic
# Start-Service "DiagTrack"
# Stop and disable WAP Push Service
Write-Host "Stopping and disabling WAP Push Service..."
Stop-Service "dmwappushservice"
Set-Service "dmwappushservice" -StartupType Disabled
# Enable and start WAP Push Service
# Set-Service "dmwappushservice" -StartupType Automatic
# Start-Service "dmwappushservice"
# Set-ItemProperty -Path "HKLM:\SYSTEM\CurrentControlSet\Services\dmwappushservice" -Name "DelayedAutoStart" -Type DWord -Value 1
# Service Tweaks
# Lower UAC level
# Write-Host "Lowering UAC level..."
# Set-ItemProperty -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Policies\System" -Name "ConsentPromptBehaviorAdmin" -Type DWord -Value 0
# Set-ItemProperty -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Policies\System" -Name "PromptOnSecureDesktop" -Type DWord -Value 0
# Raise UAC level
# Set-ItemProperty -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Policies\System" -Name "ConsentPromptBehaviorAdmin" -Type DWord -Value 5
# Set-ItemProperty -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Policies\System" -Name "PromptOnSecureDesktop" -Type DWord -Value 1
# Enable sharing mapped drives between users
# Write-Host "Enabling sharing mapped drives between users..."
# Set-ItemProperty -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Policies\System" -Name "EnableLinkedConnections" -Type DWord -Value 1
# Disable sharing mapped drives between users
# Remove-ItemProperty -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Policies\System" -Name "EnableLinkedConnections"
# Disable Firewall
# Write-Host "Disabling Firewall..."
# Set-NetFirewallProfile -Profile * -Enabled False
# Enable Firewall
# Set-NetFirewallProfile -Profile * -Enabled True
# Disable Windows Defender
# Write-Host "Disabling Windows Defender..."
# Set-ItemProperty -Path "HKLM:\Software\Policies\Microsoft\Windows Defender" -Name "DisableAntiSpyware" -Type DWord -Value 1
# Enable Windows Defender
# Remove-ItemProperty -Path "HKLM:\Software\Policies\Microsoft\Windows Defender" -Name "DisableAntiSpyware"
# Disable Windows Update automatic restart
Write-Host "Disabling Windows Update automatic restart..."
Set-ItemProperty -Path "HKLM:\Software\Microsoft\WindowsUpdate\UX\Settings" -Name "UxOption" -Type DWord -Value 1
# Enable Windows Update automatic restart
# Set-ItemProperty -Path "HKLM:\Software\Microsoft\WindowsUpdate\UX\Settings" -Name "UxOption" -Type DWord -Value 0
# Stop and disable Home Groups services
Write-Host "Stopping and disabling Home Groups services..."
Stop-Service "HomeGroupListener"
Set-Service "HomeGroupListener" -StartupType Disabled
Stop-Service "HomeGroupProvider"
Set-Service "HomeGroupProvider" -StartupType Disabled
# Enable and start Home Groups services
# Set-Service "HomeGroupListener" -StartupType Manual
# Set-Service "HomeGroupProvider" -StartupType Manual
# Start-Service "HomeGroupProvider"
# Disable Remote Assistance
# Write-Host "Disabling Remote Assistance..."
# Set-ItemProperty -Path "HKLM:\System\CurrentControlSet\Control\Remote Assistance" -Name "fAllowToGetHelp" -Type DWord -Value 0
# Enable Remote Assistance
# Set-ItemProperty -Path "HKLM:\System\CurrentControlSet\Control\Remote Assistance" -Name "fAllowToGetHelp" -Type DWord -Value 1
# Enable Remote Desktop w/o Network Level Authentication
# Write-Host "Enabling Remote Desktop w/o Network Level Authentication..."
# Set-ItemProperty -Path "HKLM:\System\CurrentControlSet\Control\Terminal Server" -Name "fDenyTSConnections" -Type DWord -Value 0
# Set-ItemProperty -Path "HKLM:\System\CurrentControlSet\Control\Terminal Server\WinStations\RDP-Tcp" -Name "UserAuthentication" -Type DWord -Value 0
# Disable Remote Desktop
# Set-ItemProperty -Path "HKLM:\System\CurrentControlSet\Control\Terminal Server" -Name "fDenyTSConnections" -Type DWord -Value 1
# Set-ItemProperty -Path "HKLM:\System\CurrentControlSet\Control\Terminal Server\WinStations\RDP-Tcp" -Name "UserAuthentication" -Type DWord -Value 1
# UI Tweaks
# Disable Action Center
# Write-Host "Disabling Action Center..."
# If (!(Test-Path "HKCU:\Software\Policies\Microsoft\Windows\Explorer")) {
# New-Item -Path "HKCU:\Software\Policies\Microsoft\Windows\Explorer" | Out-Null
# Set-ItemProperty -Path "HKCU:\Software\Policies\Microsoft\Windows\Explorer" -Name "DisableNotificationCenter" -Type DWord -Value 1
# Set-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\PushNotifications" -Name "ToastEnabled" -Type DWord -Value 0
# Enable Action Center
# Remove-ItemProperty -Path "HKCU:\Software\Policies\Microsoft\Windows\Explorer" -Name "DisableNotificationCenter"
# Remove-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\PushNotifications" -Name "ToastEnabled"
# Disable Lock screen
Write-Host "Disabling Lock screen..."
If (!(Test-Path "HKLM:\Software\Policies\Microsoft\Windows\Personalization")) {
New-Item -Path "HKLM:\Software\Policies\Microsoft\Windows\Personalization" | Out-Null
Set-ItemProperty -Path "HKLM:\Software\Policies\Microsoft\Windows\Personalization" -Name "NoLockScreen" -Type DWord -Value 1
# Enable Lock screen
# Remove-ItemProperty -Path "HKLM:\Software\Policies\Microsoft\Windows\Personalization" -Name "NoLockScreen"
# Disable Autoplay
# Write-Host "Disabling Autoplay..."
# Set-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Explorer\AutoplayHandlers" -Name "DisableAutoplay" -Type DWord -Value 1
# Enable Autoplay
# Set-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Explorer\AutoplayHandlers" -Name "DisableAutoplay" -Type DWord -Value 0
# Disable Autorun for all drives
# Write-Host "Disabling Autorun for all drives..."
# If (!(Test-Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer")) {
# New-Item -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer" | Out-Null
# Set-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer" -Name "NoDriveTypeAutoRun" -Type DWord -Value 255
# Enable Autorun
# Remove-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer" -Name "NoDriveTypeAutoRun"
#Disable Sticky keys prompt
Write-Host "Disabling Sticky keys prompt..."
Set-ItemProperty -Path "HKCU:\Control Panel\Accessibility\StickyKeys" -Name "Flags" -Type String -Value "506"
# Enable Sticky keys prompt
# Set-ItemProperty -Path "HKCU:\Control Panel\Accessibility\StickyKeys" -Name "Flags" -Type String -Value "510"
# Hide Search button / box
Write-Host "Hiding Search Box / Button..."
Set-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Search" -Name "SearchboxTaskbarMode" -Type DWord -Value 0
# Show Search button / box
# Remove-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Search" -Name "SearchboxTaskbarMode"
# Hide Task View button
# Write-Host "Hiding Task View button..."
# Set-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced" -Name "ShowTaskViewButton" -Type DWord -Value 0
# Show Task View button
# Remove-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced" -Name "ShowTaskViewButton"
# Show small icons in taskbar
# Write-Host "Showing small icons in taskbar..."
# Set-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced" -Name "TaskbarSmallIcons" -Type DWord -Value 1
# Show large icons in taskbar
# Remove-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced" -Name "TaskbarSmallIcons"
# Show titles in taskbar
# Write-Host "Showing titles in taskbar..."
# Set-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced" -Name "TaskbarGlomLevel" -Type DWord -Value 1
# Hide titles in taskbar
# Remove-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced" -Name "TaskbarGlomLevel"
# Show all tray icons
# Write-Host "Showing all tray icons..."
# Set-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Explorer" -Name "EnableAutoTray" -Type DWord -Value 0
# Hide tray icons as needed
# Remove-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Explorer" -Name "EnableAutoTray"
# Show known file extensions
Write-Host "Showing known file extensions..."
Set-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced" -Name "HideFileExt" -Type DWord -Value 0
# Hide known file extensions
# Set-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced" -Name "HideFileExt" -Type DWord -Value 1
# Show hidden files
Write-Host "Showing hidden files..."
Set-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced" -Name "Hidden" -Type DWord -Value 1
# Hide hidden files
# Set-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced" -Name "Hidden" -Type DWord -Value 2
# Change default Explorer view to "Computer"
Write-Host "Changing default Explorer view to `"Computer`"..."
Set-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced" -Name "LaunchTo" -Type DWord -Value 1
# Change default Explorer view to "Quick Access"
# Remove-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced" -Name "LaunchTo"
# Show Computer shortcut on desktop
# Write-Host "Showing Computer shortcut on desktop..."
# If (!(Test-Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Explorer\HideDesktopIcons\ClassicStartMenu")) {
# New-Item -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Explorer\HideDesktopIcons\ClassicStartMenu" | Out-Null
# Set-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Explorer\HideDesktopIcons\ClassicStartMenu" -Name "{20D04FE0-3AEA-1069-A2D8-08002B30309D}" -Type DWord -Value 0
# Set-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Explorer\HideDesktopIcons\NewStartPanel" -Name "{20D04FE0-3AEA-1069-A2D8-08002B30309D}" -Type DWord -Value 0
# Hide Computer shortcut from desktop
# Remove-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Explorer\HideDesktopIcons\ClassicStartMenu" -Name "{20D04FE0-3AEA-1069-A2D8-08002B30309D}"
# Remove-ItemProperty -Path "HKCU:\Software\Microsoft\Windows\CurrentVersion\Explorer\HideDesktopIcons\NewStartPanel" -Name "{20D04FE0-3AEA-1069-A2D8-08002B30309D}"
# Remove Desktop icon from computer namespace
# Write-Host "Removing Desktop icon from computer namespace..."
# Remove-Item -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{B4BFCC3A-DB2C-424C-B029-7FE99A87C641}" -Recurse -ErrorAction SilentlyContinue
# Add Desktop icon to computer namespace
# New-Item -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{B4BFCC3A-DB2C-424C-B029-7FE99A87C641}"
# Remove Documents icon from computer namespace
# Write-Host "Removing Documents icon from computer namespace..."
# Remove-Item -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{d3162b92-9365-467a-956b-92703aca08af}" -Recurse -ErrorAction SilentlyContinue
# Remove-Item -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{A8CDFF1C-4878-43be-B5FD-F8091C1C60D0}" -Recurse -ErrorAction SilentlyContinue
# Add Documents icon to computer namespace
# New-Item -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{d3162b92-9365-467a-956b-92703aca08af}"
# New-Item -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{A8CDFF1C-4878-43be-B5FD-F8091C1C60D0}"
# Remove Downloads icon from computer namespace
# Write-Host "Removing Downloads icon from computer namespace..."
# Remove-Item -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{088e3905-0323-4b02-9826-5d99428e115f}" -Recurse -ErrorAction SilentlyContinue
# Remove-Item -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{374DE290-123F-4565-9164-39C4925E467B}" -Recurse -ErrorAction SilentlyContinue
# Add Downloads icon to computer namespace
# New-Item -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{088e3905-0323-4b02-9826-5d99428e115f}"
# New-Item -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{374DE290-123F-4565-9164-39C4925E467B}"
# Remove Music icon from computer namespace
# Write-Host "Removing Music icon from computer namespace..."
# Remove-Item -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{3dfdf296-dbec-4fb4-81d1-6a3438bcf4de}" -Recurse -ErrorAction SilentlyContinue
# Remove-Item -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{1CF1260C-4DD0-4ebb-811F-33C572699FDE}" -Recurse -ErrorAction SilentlyContinue
# Add Music icon to computer namespace
# New-Item -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{3dfdf296-dbec-4fb4-81d1-6a3438bcf4de}"
# New-Item -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{1CF1260C-4DD0-4ebb-811F-33C572699FDE}"
# Remove Pictures icon from computer namespace
Write-Host "Removing Pictures icon from computer namespace..."
Remove-Item -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{24ad3ad4-a569-4530-98e1-ab02f9417aa8}" -Recurse -ErrorAction SilentlyContinue
Remove-Item -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{3ADD1653-EB32-4cb0-BBD7-DFA0ABB5ACCA}" -Recurse -ErrorAction SilentlyContinue
# Add Pictures icon to computer namespace
# New-Item -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{24ad3ad4-a569-4530-98e1-ab02f9417aa8}"
# New-Item -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{3ADD1653-EB32-4cb0-BBD7-DFA0ABB5ACCA}"
# Remove Videos icon from computer namespace
Write-Host "Removing Videos icon from computer namespace..."
Remove-Item -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{f86fa3ab-70d2-4fc7-9c99-fcbf05467f3a}" -Recurse -ErrorAction SilentlyContinue
Remove-Item -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{A0953C92-50DC-43bf-BE83-3742FED03C9C}" -Recurse -ErrorAction SilentlyContinue
# Add Videos icon to computer namespace
# New-Item -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{f86fa3ab-70d2-4fc7-9c99-fcbf05467f3a}"
# New-Item -Path "HKLM:\Software\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{A0953C92-50DC-43bf-BE83-3742FED03C9C}"
## Add secondary en-US keyboard
#Write-Host "Adding secondary en-US keyboard..."
#$langs = Get-WinUserLanguageList
#$langs.Add("en-US")
#Set-WinUserLanguageList $langs -Force
# Remove secondary en-US keyboard
# $langs = Get-WinUserLanguageList
# Set-WinUserLanguageList ($langs | ? {$_.LanguageTag -ne "en-US"}) -Force
# Remove unwanted applications
# Disable OneDrive
# Write-Host "Disabling OneDrive..."
# If (!(Test-Path "HKLM:\SOFTWARE\Policies\Microsoft\Windows\OneDrive")) {
# New-Item -Path "HKLM:\SOFTWARE\Policies\Microsoft\Windows\OneDrive" | Out-Null
# Set-ItemProperty -Path "HKLM:\SOFTWARE\Policies\Microsoft\Windows\OneDrive" -Name "DisableFileSyncNGSC" -Type DWord -Value 1
# Enable OneDrive
# Remove-ItemProperty -Path "HKLM:\SOFTWARE\Policies\Microsoft\Windows\OneDrive" -Name "DisableFileSyncNGSC"
# Uninstall OneDrive
# Write-Host "Uninstalling OneDrive..."
# Stop-Process -Name OneDrive -ErrorAction SilentlyContinue
# Start-Sleep -s 3
# $onedrive = "$env:SYSTEMROOT\SysWOW64\OneDriveSetup.exe"
# If (!(Test-Path $onedrive)) {
# $onedrive = "$env:SYSTEMROOT\System32\OneDriveSetup.exe"
# Start-Process $onedrive "/uninstall" -NoNewWindow -Wait
# Start-Sleep -s 3
# Stop-Process -Name explorer -ErrorAction SilentlyContinue
# Start-Sleep -s 3
# Remove-Item "$env:USERPROFILE\OneDrive" -Force -Recurse -ErrorAction SilentlyContinue
# Remove-Item "$env:LOCALAPPDATA\Microsoft\OneDrive" -Force -Recurse -ErrorAction SilentlyContinue
# Remove-Item "$env:PROGRAMDATA\Microsoft OneDrive" -Force -Recurse -ErrorAction SilentlyContinue
# If (Test-Path "$env:SYSTEMDRIVE\OneDriveTemp") {
# Remove-Item "$env:SYSTEMDRIVE\OneDriveTemp" -Force -Recurse -ErrorAction SilentlyContinue
# If (!(Test-Path "HKCR:")) {
# New-PSDrive -Name HKCR -PSProvider Registry -Root HKEY_CLASSES_ROOT | Out-Null
# Remove-Item -Path "HKCR:\CLSID\{018D5C66-4533-4307-9B53-224DE2ED1FE6}" -Recurse -ErrorAction SilentlyContinue
# Remove-Item -Path "HKCR:\Wow6432Node\CLSID\{018D5C66-4533-4307-9B53-224DE2ED1FE6}" -Recurse -ErrorAction SilentlyContinue
# Install OneDrive
# Start-Process $onedrive -NoNewWindow
# Uninstall default Microsoft applications
Write-Host "Uninstalling default Microsoft applications..."
Get-AppxPackage "Microsoft.3DBuilder" | Remove-AppxPackage
Get-AppxPackage "Microsoft.BingFinance" | Remove-AppxPackage
Get-AppxPackage "Microsoft.BingNews" | Remove-AppxPackage
Get-AppxPackage "Microsoft.BingSports" | Remove-AppxPackage
Get-AppxPackage "Microsoft.BingWeather" | Remove-AppxPackage
Get-AppxPackage "Microsoft.Getstarted" | Remove-AppxPackage
Get-AppxPackage "Microsoft.MicrosoftOfficeHub" | Remove-AppxPackage
# Get-AppxPackage "Microsoft.MicrosoftSolitaireCollection" | Remove-AppxPackage
# Get-AppxPackage "Microsoft.Office.OneNote" | Remove-AppxPackage
# Get-AppxPackage "Microsoft.People" | Remove-AppxPackage
# Get-AppxPackage "Microsoft.SkypeApp" | Remove-AppxPackage
# Get-AppxPackage "Microsoft.Windows.Photos" | Remove-AppxPackage
# Get-AppxPackage "Microsoft.WindowsAlarms" | Remove-AppxPackage
# Get-AppxPackage "Microsoft.WindowsCamera" | Remove-AppxPackage
# Get-AppxPackage "microsoft.windowscommunicationsapps" | Remove-AppxPackage
# Get-AppxPackage "Microsoft.WindowsMaps" | Remove-AppxPackage
Get-AppxPackage "Microsoft.WindowsPhone" | Remove-AppxPackage
# Get-AppxPackage "Microsoft.WindowsSoundRecorder" | Remove-AppxPackage
# Get-AppxPackage "Microsoft.XboxApp" | Remove-AppxPackage
# Get-AppxPackage "Microsoft.ZuneMusic" | Remove-AppxPackage
# Get-AppxPackage "Microsoft.ZuneVideo" | Remove-AppxPackage
# Get-AppxPackage "Microsoft.AppConnector" | Remove-AppxPackage
# Get-AppxPackage "Microsoft.ConnectivityStore" | Remove-AppxPackage
# Get-AppxPackage "Microsoft.Office.Sway" | Remove-AppxPackage
# Get-AppxPackage "Microsoft.Messaging" | Remove-AppxPackage
# Get-AppxPackage "Microsoft.CommsPhone" | Remove-AppxPackage
Get-AppxPackage "9E2F88E3.Twitter" | Remove-AppxPackage
Get-AppxPackage "king.com.CandyCrushSodaSaga" | Remove-AppxPackage
# Install default Microsoft applications
# Add-AppxPackage -DisableDevelopmentMode -Register "$($(Get-AppXPackage -AllUsers "Microsoft.3DBuilder").InstallLocation)\AppXManifest.xml"
# Add-AppxPackage -DisableDevelopmentMode -Register "$($(Get-AppXPackage -AllUsers "Microsoft.BingFinance").InstallLocation)\AppXManifest.xml"
# Add-AppxPackage -DisableDevelopmentMode -Register "$($(Get-AppXPackage -AllUsers "Microsoft.BingNews").InstallLocation)\AppXManifest.xml"
# Add-AppxPackage -DisableDevelopmentMode -Register "$($(Get-AppXPackage -AllUsers "Microsoft.BingSports").InstallLocation)\AppXManifest.xml"
# Add-AppxPackage -DisableDevelopmentMode -Register "$($(Get-AppXPackage -AllUsers "Microsoft.BingWeather").InstallLocation)\AppXManifest.xml"
# Add-AppxPackage -DisableDevelopmentMode -Register "$($(Get-AppXPackage -AllUsers "Microsoft.Getstarted").InstallLocation)\AppXManifest.xml"
# Add-AppxPackage -DisableDevelopmentMode -Register "$($(Get-AppXPackage -AllUsers "Microsoft.MicrosoftOfficeHub").InstallLocation)\AppXManifest.xml"
# Add-AppxPackage -DisableDevelopmentMode -Register "$($(Get-AppXPackage -AllUsers "Microsoft.MicrosoftSolitaireCollection").InstallLocation)\AppXManifest.xml"
# Add-AppxPackage -DisableDevelopmentMode -Register "$($(Get-AppXPackage -AllUsers "Microsoft.Office.OneNote").InstallLocation)\AppXManifest.xml"
# Add-AppxPackage -DisableDevelopmentMode -Register "$($(Get-AppXPackage -AllUsers "Microsoft.People").InstallLocation)\AppXManifest.xml"
# Add-AppxPackage -DisableDevelopmentMode -Register "$($(Get-AppXPackage -AllUsers "Microsoft.SkypeApp").InstallLocation)\AppXManifest.xml"
# Add-AppxPackage -DisableDevelopmentMode -Register "$($(Get-AppXPackage -AllUsers "Microsoft.Windows.Photos").InstallLocation)\AppXManifest.xml"
# Add-AppxPackage -DisableDevelopmentMode -Register "$($(Get-AppXPackage -AllUsers "Microsoft.WindowsAlarms").InstallLocation)\AppXManifest.xml"
# Add-AppxPackage -DisableDevelopmentMode -Register "$($(Get-AppXPackage -AllUsers "Microsoft.WindowsCamera").InstallLocation)\AppXManifest.xml"
# Add-AppxPackage -DisableDevelopmentMode -Register "$($(Get-AppXPackage -AllUsers "Microsoft.windowscommunicationsapps").InstallLocation)\AppXManifest.xml"
# Add-AppxPackage -DisableDevelopmentMode -Register "$($(Get-AppXPackage -AllUsers "Microsoft.WindowsMaps").InstallLocation)\AppXManifest.xml"
# Add-AppxPackage -DisableDevelopmentMode -Register "$($(Get-AppXPackage -AllUsers "Microsoft.WindowsPhone").InstallLocation)\AppXManifest.xml"
# Add-AppxPackage -DisableDevelopmentMode -Register "$($(Get-AppXPackage -AllUsers "Microsoft.WindowsSoundRecorder").InstallLocation)\AppXManifest.xml"
# Add-AppxPackage -DisableDevelopmentMode -Register "$($(Get-AppXPackage -AllUsers "Microsoft.XboxApp").InstallLocation)\AppXManifest.xml"
# Add-AppxPackage -DisableDevelopmentMode -Register "$($(Get-AppXPackage -AllUsers "Microsoft.ZuneMusic").InstallLocation)\AppXManifest.xml"
# Add-AppxPackage -DisableDevelopmentMode -Register "$($(Get-AppXPackage -AllUsers "Microsoft.ZuneVideo").InstallLocation)\AppXManifest.xml"
# Add-AppxPackage -DisableDevelopmentMode -Register "$($(Get-AppXPackage -AllUsers "Microsoft.AppConnector").InstallLocation)\AppXManifest.xml"
# Add-AppxPackage -DisableDevelopmentMode -Register "$($(Get-AppXPackage -AllUsers "Microsoft.ConnectivityStore").InstallLocation)\AppXManifest.xml"
# Add-AppxPackage -DisableDevelopmentMode -Register "$($(Get-AppXPackage -AllUsers "Microsoft.Office.Sway").InstallLocation)\AppXManifest.xml"
# Add-AppxPackage -DisableDevelopmentMode -Register "$($(Get-AppXPackage -AllUsers "Microsoft.Messaging").InstallLocation)\AppXManifest.xml"
# Add-AppxPackage -DisableDevelopmentMode -Register "$($(Get-AppXPackage -AllUsers "Microsoft.CommsPhone").InstallLocation)\AppXManifest.xml"
# In case you have removed them for good, you can try to restore the files using installation medium as follows
# New-Item C:\Mnt -Type Directory | Out-Null
# dism /Mount-Image /ImageFile:D:\sources\install.wim /index:1 /ReadOnly /MountDir:C:\Mnt
# robocopy /S /SEC /R:0 "C:\Mnt\Program Files\WindowsApps" "C:\Program Files\WindowsApps"
# dism /Unmount-Image /Discard /MountDir:C:\Mnt
# Remove-Item -Path C:\Mnt -Recurse
# Uninstall Windows Media Player
# Write-Host "Uninstalling Windows Media Player..."
# dism /online /Disable-Feature /FeatureName:MediaPlayback /Quiet /NoRestart
# Install Windows Media Player
# dism /online /Enable-Feature /FeatureName:MediaPlayback /Quiet /NoRestart
# Uninstall Work Folders Client
# Write-Host "Uninstalling Work Folders Client..."
# dism /online /Disable-Feature /FeatureName:WorkFolders-Client /Quiet /NoRestart
# Install Work Folders Client
# dism /online /Enable-Feature /FeatureName:WorkFolders-Client /Quiet /NoRestart
# Set Photo Viewer as default for bmp, gif, jpg and png
Write-Host "Setting Photo Viewer as default for bmp, gif, jpg, png and tif..."
ForEach ($type in @("Paint.Picture", "giffile", "jpegfile", "pngfile")) {
New-Item -Path $("HKCR:\$type\shell\open") -Force | Out-Null
New-Item -Path $("HKCR:\$type\shell\open\command") | Out-Null
Set-ItemProperty -Path $("HKCR:\$type\shell\open") -Name "MuiVerb" -Type ExpandString -Value "@%ProgramFiles%\Windows Photo Viewer\photoviewer.dll,-3043"
Set-ItemProperty -Path $("HKCR:\$type\shell\open\command") -Name "(Default)" -Type ExpandString -Value "%SystemRoot%\System32\rundll32.exe `"%ProgramFiles%\Windows Photo Viewer\PhotoViewer.dll`", ImageView_Fullscreen %1"
# Remove or reset default open action for bmp, gif, jpg and png
# Remove-Item -Path "HKCR:\Paint.Picture\shell\open" -Recurse
# Remove-ItemProperty -Path "HKCR:\giffile\shell\open" -Name "MuiVerb"
# Set-ItemProperty -Path "HKCR:\giffile\shell\open" -Name "CommandId" -Type String -Value "IE.File"
# Set-ItemProperty -Path "HKCR:\giffile\shell\open\command" -Name "(Default)" -Type String -Value "`"$env:SystemDrive\Program Files\Internet Explorer\iexplore.exe`" %1"
# Set-ItemProperty -Path "HKCR:\giffile\shell\open\command" -Name "DelegateExecute" -Type String -Value "{17FE9752-0B5A-4665-84CD-569794602F5C}"
# Remove-Item -Path "HKCR:\jpegfile\shell\open" -Recurse
# Remove-Item -Path "HKCR:\pngfile\shell\open" -Recurse
# Show Photo Viewer in "Open with..."
Write-Host "Showing Photo Viewer in `"Open with...`""
New-Item -Path "HKCR:\Applications\photoviewer.dll\shell\open\command" -Force | Out-Null
New-Item -Path "HKCR:\Applications\photoviewer.dll\shell\open\DropTarget" -Force | Out-Null
Set-ItemProperty -Path "HKCR:\Applications\photoviewer.dll\shell\open" -Name "MuiVerb" -Type String -Value "@photoviewer.dll,-3043"
Set-ItemProperty -Path "HKCR:\Applications\photoviewer.dll\shell\open\command" -Name "(Default)" -Type ExpandString -Value "%SystemRoot%\System32\rundll32.exe `"%ProgramFiles%\Windows Photo Viewer\PhotoViewer.dll`", ImageView_Fullscreen %1"
Set-ItemProperty -Path "HKCR:\Applications\photoviewer.dll\shell\open\DropTarget" -Name "Clsid" -Type String -Value "{FFE2A43C-56B9-4bf5-9A79-CC6D4285608A}"
# Remove Photo Viewer from "Open with..."
# Remove-Item -Path "HKCR:\Applications\photoviewer.dll\shell\open" -Recurse
# Restart
Write-Host
Write-Host "Press any key to restart your system..." -ForegroundColor Black -BackgroundColor White
$key = $host.UI.RawUI.ReadKey("NoEcho,IncludeKeyDown")
Write-Host "Restarting..."
Restart-Computer
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
244
245
246
247
248
249
250
251
252
253
254
255
256
257
258
259
260
261
262
263
264
265
266
267
268
269
270
271
272
273
274
275
276
277
278
279
280
281
282
283
284
285
286
287
288
289
290
291
292
293
294
295
296
297
298
299
300
301
302
303
304
305
306
307
308
309
310
311
312
313
314
315
316
317
318
319
320
321
322
323
324
325
326
327
328
329
330
331
332
333
334
335
336
337
338
339
340
341
342
343
344
345
346
347
348
349
350
351
352
353
354
355
356
357
358
359
360
361
362
363
364
365
366
367
368
369
370
371
372
373
374
375
376
377
378
379
380
381
382
383
384
385
386
387
388
389
390
391
392
393
394
395
396
397
398
399
400
401
402
403
404
405
406
407
408
409
410
411
412
413
414
415
416
417
418
419
420
421
422
423
424
425
426
427
428
429
430
431
432
433
434
435
436
437
438
439
440
441
442
443
444
445
446
447
448
449
450
451
452
453
454
455
456
457
458
459
460
461
462
463
464
465
466
467
468
469
470
471
472
473
474
475
476
477
478
479
480
481
482
483
484
485
486
487
488
489
490
491
492
493
494
495
496
497
498
499
500
501
502
503
504
505
506
507
508
509
510
511
512
513
514
515
516
517
518
519
520
521
522
523
524
525
526
527
528
529
530
531
532
533
534
535
536
537
538
539
540
541
542
543
544
545
546
547
548
549
550
551
552
553
554
555
556
557
558
559
560
561
562
563
564
565
566
567
568
569
570
571
572
573
574
575
576
577
578
Exit
# Privacy Settings
# Disable Telemetry
# Enable Telemetry
# Disable Feedback
# Enable Feedback
# Disable Cortana
# Enable Cortana
# Service Tweaks
# Lower UAC level
# Raise UAC level
# Disable Firewall
# Enable Firewall
# UI Tweaks
# Disable Autoplay
# Enable Autoplay
# Enable Autorun
# Show hidden files
# Hide hidden files
# Disable OneDrive
# Enable OneDrive
# Start-Sleep -s 3
# Start-Sleep -s 3
# Start-Sleep -s 3
# Install OneDrive
# Restart
Write-Host
Restart-Computer
Copy-Paste ga je malo zj***l
AndrejO ::
Ne, 2 skripti sta v enem zapisu. Nisem ju ločil. Ena je original in ena tweakana.
Komu so pa ta magična zaklinjanja sploh namenjena?
krneki0001 ::
Vsakomur, kdor hoče kaj izklopit ali vklopit v windows 10.
Sej so povsod komentarji, kaj dela vsak ukaz posebaj.
AndrejO ::
OK, bom testiral na svoji mami, ce bo razumela, kaj ji zelis povedati.
Ja, ja ... vem. Tukaj smo menda samo znalci. Ampak Windows 10 naj bi bil OS za mase, ne pa zgolj za znalce, mar ne?
krneki0001 ::
Tisto kar navaden človek dela v OS-u za mase, lahko vse naklika preko GUI-ja.
Tukaj, na tehnološkem forumu, pa človek predvideva, da so tudi taki, ki bi radi kaj več znali. In višje gor je bilo vprašanje, kako kaj preko powershella rešiš, pa je bil to tudi en izmed odgovorov, kako.
AndrejO ::
Ah, OK. Se mi je zdelo, da ni bilo namenjeno meni, ceprav je sledilo mojem komentarju o pljuvanju.
BTW, mojh problemov z Win10 ta skripta ne resuje ... Se bo moral kar MS se malo potruditi oz. se je ze uspel potruditi. Pa ne zato, ker bi "jaz" pljuval, ampak zato, ker se zdalec nisem edini s to ali ono tezavo/kritiko/pljuvanjem.
AndrejO ::
#1 Nekonsistenten UI (očitno še vedno v fazi "migracije" tudi še po nekaj letih).
#2 Nezmožnost nadzora nad posodobitvami za spodobno ceno (Enterprise Edition? Ja pa valjda si bom to kupoval za svoje postranske projekte, mar ne?)
#3 Občasna ponastavitev vsega že enkrat odstranjenega dreka, ko se MS-ju to sprdne.
"Creators Update" naj bi vsaj delno uredil #2, čeprav se bojim, kaj mi bo spet crknilo, kot mi je za nekaj časa crknil webcam pri eni izmed teh "juhuhu" vsiljenih novih verzij.
#1 ... kaj pa vem. Morda počakam še 5 let, pa se bom bodisi navadil ali pa bodo končno uspeli vsaj eno stvar dokončati, ne pa da se obnašajo, kot moj trenuten delodajalec.
#3 ... se bojim, da bo to šlo samo še navzdol.
krneki0001 ::
1.) nekonsistenten UI imata recimo android in ubuntu, ki sta resnična polizdelka. Win 10 so kr dost konsistentni.
2.) Tista skripta, ki sem jo višje gor objavil, deluje tudi na pro verziji in je namenjena ravno temu, da lahko updejte poštimaš kakor ti paše.
3.) ne vem kakšne občasne ponastavitve imaš ti? Česa?
AndrejO ::
V primerjavi z Win7 je Win10 nekako tako konsistenten kot Pahor pred volitvami. Vse kar vem je to, da ne vem kaj me bo pričakalo pri naslednjem kliku. Nekako tako, kot ne vem, če bo Pahor jutri kidal gnoj ali pa vozil viličarja.
Žal ni delovalo. Nocoj sem prišel do VM-ja in, glej ga zlomka, nekje vmes se je resetiral, da je namestil KB4013429.
Ampak nič ne de. MS je mene in meni podobne vsaj v tej točki po nekaj letih le uslišal in "ugotovil", da mora napako odpraviti. Creators Update je za vogalom.
Bom počakal na Creators Update in bom podal povzetek, če se bo znova kaj podrekalo. Pri Anniversary Update se je MS odločil, da bi resnično raje videl, da slike in filme gledam z nekimi njihovimi jajci in ne z meni priljubljenima XnViewMP in VLC. Pa še nekaj Windows Store aplikacij mi je nametal na tisti drek od "Start" menuja, ki to ni.
AndrejO ::
No, pa imam še ta odgovor. Creators Update mi je popacal naslednje:
- V taskbar mi je pripel MS-jev Mail.
- Ponovno mi je namestil "Get Office". BTW, toliko je zabit, da ni "opazil", da imam Office 2016 že nameščen.
- Ponovno mi je namestil tudi sledeča že enkrat izbrisana jajca: Alarms & Clock, Calculator, Camera, Feedback Hub, Get Help, Mail, Maps, Microsoft Solitaire Collection, OneDrive, One Note (podrekana Windows Store verzija, seveda in to navkljub temu, da že imam One Note 2016), Paid WiFi & Cellular (karkoli že je to), Paint 3D, People, Photos, Sticky Notes, Store (duh!), Tips, View 3D Preview, Weather, Windows 10 Upgrade Assistant (but, why!), Wireless Display Media Viewer (s pokvarjeno ikono - bel kvadrat namesto česarkoli že) in Xbox. Skupaj torej 22 aplikacij za katere nisem prosil ali pa sem jih že dvakrat odstranil.
- V Action Center mi je dodal že dvakrat prej odstranjen "Tablet mode", ker očitno zelo potrebujem ta "Tablet mode" na računalniku, ki nima ne baterije, ne zaslona na dotik.
- V Action Center mi je ponovno dodal že dvakrat prej odstranjeno povezavo do "VPN".
- Ponovno mi je omogočil prikazovanje sporočil (notifications) na zaklenjenem računalniku (lock screen). Idioti!
- Ponovno mi je vključil prikazovanje opomnikov in VoIP klicev na zaklenjenem računalniku. Idioti drugič!
- Ponovno mi je izključil skrivanje opomnikov, kadar imam kloniran zaslon. OK, ni pomembno na namiznem računalniku, ampak od kje tem opicam ideja, da mi lahko spremenijo to nastavitev?
- Gonilniki za HP OfficeJet so mi crknili. Bom popravil jutri. Zaenkrat bom to štel v slabo MS-ju, ki se je že enkrat izkazal z Logitech spletno kamero in drekanjem API-jev pod havbo.
- Ponovno mi je ponastavil svoj drek od Photos namesto XnViewMP (slike) in VLC (video).
- Ponovno je dovolil dostop do kamere za "apps" (torej drek iz Windows Store), med drugimtudi za (ponovno in brez vprašanja nameščene) Feedback Hub, Maps, in Store aplikacije. Same takšne aplikacije, ki resnično potrebujejo dostop do kamere.
- Enako kot za kamero, tudi za mikrofon, sliko, kontakte, opomnike, ... Praktično vse razen (začuda!) lokacije.
Kot bonus se je Creators Update pritoževal zaradi Microsoft Security Essentials in vključil Windows Defender, ker MSE ni kompatibilen z novo verzijo. Yay! Posodobitev za MSE tudi še ni na voljo. Yay še drugič! Uf ... kaj je že to? Aja, to je nekaj, kar je bilo odstranjeno že takrat, ko sem naredil nadgradnjo iz Win7 na Win10. Thanks Obama za lažen alarm.
Kaj se je spremenilo na boljše?
V Pro lahko ponovno izključim nadležen auto-reboot. It only took two years!
ThinkTech ::
Me kar glava boli ob misli, da bom moral spet 6x vse na novo nastavljat. Upam, da je treba za posodobitev sprejet kakšne licenčne pogoje, ker jih ne bom.
Te Windowsi in njih updati res zvenijo kot pekel, kjer moraš celo večnost spreminjati nastavitve, ki se potem resetirajo. Kako lahko Microsoft imenuje to Proffesional?
Meni ni spremenil nobene nastavitve. Vse je ostalo tako kot mora biti.
Se pravi je popravek čisto nedeterminističen, enemu spremeni vse, drugemu nič? Mogoče ima kak random notri.
krneki0001 ::
Jaz imam vse nastavitve v cloudu in ko se naloži nova verzija potegne vse nastavitve nazaj.
Jaz imam vse nastavitve v cloudu in ko se naloži nova verzija potegne vse nastavitve nazaj.lahko link, ker nisem vedo. bi rad preveril kak imam nastavljeno.
AndrejO ::
To morda pojasni razliko. Jaz nimam ničesar v oblaku in sem se kar potrudil, da sem se izognil kakršnikoli on-line registraciji za katerokoli izmed MS-jevih storitev.
(razen aktivacije same)
krneki0001 ::
Ni linka. Sam ti vse shrani in sinhronizira (sync), samo v nastavitvah si nastavi da ti vse zadeve sinhronizira.
Zadeva je zelo uporabna, ker dost menjam računalnike in samo sistem naložim, potem pa se prijavim s svojim accountom in mi sam sinhronizira vse (nastavitve, teme, ozadja, maile, koledarje, gesla za sistem, gesla za brskalnike, aplikacije (ki so v domeni MS-a in tiste v metroju).
Seveda. Če imaš samo lokalni račun, ti vse povozi in moraš vse spet nastavljat. Če imaš MS account ti sinhronizira vse nastavitve in vse nazaj postavi.
- spremenilo: krneki0001 ()
Se pravi update zna brati obstoječe nastavitve iz oblaka, ne zna pa jih prebrati iz diska. Hm, zanimivo.
Spajky ::
...Te Windowsi in njih updati res zvenijo kot pekel, kjer moraš celo večnost spreminjati nastavitve, ki se potem resetirajo. Kako lahko Microsoft imenuje to Proffesional?Tako : To je verzija MS Win10 Professional Confusion. Cilj, da se s svojim OS post-upgrade čimveč ukvarjate in manj resno delate ter stojite v vrsti za novi upgrade v tresočem pričakovanju. Life is a thrill
meni dela vse ok.
nevone ::
Software je ponavadi toliko konfuzen, kolikor je konfuzen uporabnik.
o+ nevone
krneki0001 ::
Zelo verjetno jih zna, vendar mu moraš to nekako razložiti da naj jih uporabi.
ender ::
Meni je kot ponavadi pozabil Alt+Tab nastavitve (ne maram modernega, je preveč nepregleden) in debelino okvirjev oken, samo imam za to že od prej pripravljeno .reg datoteko, ki te nastavitve povrne.
Alexius Heristalski ::
Te velike nadgradnje so in-place upgrade, normalno, da bo popravil register in nazaj naložil aplikacije iz Storea, to je itak point in-place upgradea. Je nerodno, če imaš nadpovprečno število prilagoditev.
AndrejO ::
Zakaj normalno? Ali obstaja kakršnakoli tehnična omejitev, da se mora stvari ponastaviti? Če vprašaš mene, je to samo še en gnoj od strategije, ki na plačljivem OS-u zapravlja čas z iskanjem načinov kako pospeševati prodajo preko svojega klona App Store, nima pa časa poskrbeti za stvari, ki bi izboljšale uporabnost samega sistema.
Pa še dve čudoviti malenkosti. Včeraj sem dobil to novo opozorilo, da bi se okna zaradi posodobitve želela ponovno zagnati. Pridno sem kliknil, da ne, ker tega nisem želel.
Danes zjutraj sedem pred računalnik in glej ga zlomka. Nekje vmes so se okna vseeno odločila, da se bodo ponovno zagnala. Toliko glede "popravka" na to temo. Sumim, da bodo okna odlagala ponovno zagon samo, če bo nekdo vztrajno klikal na okence, sicer pa se bodo delala francoza.
Druga neumnost pa me še vedno moti. Njega dni (beri: Win7) se je pred vsako posodobitvijo naredil system restore point. Jako prikladna stvar, če pomislim, da so posodobitve znale kakšno stvar tudi pokvariti. No, Win10 tega več nima. Posodobitve pa še vedno znajo kakšno stvar pokvariti in, če jo dovolj pokvarijo, rešitve več ni. System restore, ki je delal v varnem načinu, pa več ne rešuje te težave, ker ga posodobitve več ne uporabljajo.
Hvala, lolekom.
Skratka ... Win10 še naprej ostaja školjka za zagon igric. Za resno delo do nadaljnega ostane Win7.
Hvala, lolekom.
Hvala, lolekom.
Najbolj je pa to, ko berem forume, da jim npr. update pokvari nekaj z driverji in podobno. Potem pa uporabniki krivijo proizvajalca hardwera, da ni dosti hitro spisal nove driverje za trenutni update lol. Smisel neke platforme kot je bila npr Windows 7 je, da proizvajalci pričakujejo da bodo gonilniki delovali skozi celotno dobo platforme, razen v preteklosti SP-ji so lahko zagodli vsake nekaj let. Zdaj pa naj bi proizvajalec kar naenkrat vsak mesec ali dva izdajal in prilagajal driverje ker Microsoft pokvari API ali kaj drugega.
- spremenil: LeQuack ()
xmetallic ::
- spremenilo: xmetallic ()
Nikonja ::
Fak ali ste nesposobni ali imate neki drek od računalnikov, ker jaz dobesedno enega edinega problema nisem imel od prvega dneva vporabe win 10. Vse dela kot urca, dobesedno 0 problemov (vsaj ne zaradi windowsov). Sej ste imeli cel kup dreka od dodatnih aplikacij tudi v 7ki ampak tamo vas to ni motilo. Kupite si Mac-a ali instalirajte Linux in nehajte nekontrolirano nakladat kaj vam ni všeč, najbolj tragično je da ste enako srali o win 7 ko ste leteli iz win xp.
Fak ali ste nesposobni ali imate neki drek od računalnikov, ker jaz dobesedno enega edinega problema nisem imel od prvega dneva vporabe win 10. Vse dela kot urca, dobesedno 0 problemov (vsaj ne zaradi windowsov). Sej ste imeli cel kup dreka od dodatnih aplikacij tudi v 7ki ampak tamo vas to ni motilo. Kupite si Mac-a ali instalirajte Linux in nehajte nekontrolirano nakladat kaj vam ni všeč, najbolj tragično je da ste enako srali o win 7 ko ste leteli iz win xp.jaz se strinjam. tud sam mam win10 in mi vse dela. sem pa par krat dobil blue screen, a to je bilo vse.
Malajlo ::
Pa še res ... 95 je bil zakon, ko je 98 prišla. XP so bili jajca napram 98 SE. Itak pa isto kot 2000. Ker 2000 je pa bil sistem, to pa. Vista ... (tri leta sem jo uporabljal bp) Potem pa sedmica, ki marsikaterega xp sp3 ni zamenjala (ker z sp3 so pa končno poštimal ves drek). In here we go again ...
Desetko uporabljam že od štarta, še po telefonih jo imam, pa bogami je to najbolj zanesljiv sistem iz Redmonda. Ok, takoj za XP sp3, itak.
Za vas ki imate gor samo tiste 3 igre in browser je itak vseeno a ni?jaz mam gor tudi stuff kot wireshark, fiddler, tunnelbear... pa še kaj bi se našlo.
Top kek of the day.
jest10 ::
| » | Microsoft OneDriveOddelek: Operacijski sistemi | 3480 (452) | treker |
| » | Windows 10 z reklamami tudi v Raziskovalcu (strani: 1 2 3 )Oddelek: Novice / Operacijski sistemi | 57676 (51240) | D3m |
| » | Microsoft ne bo več ponujal neomejenega oblačnega prostora naročnikom na Office 365 (strani: 1 2 )Oddelek: Novice / Windows Mobile | 38490 (32959) | Lonsarg |
| » | Izšel Office 2016 (strani: 1 2 )Oddelek: Novice / Pisarniški paketi | 38347 (34500) | s1m0n |
| » | Windows 10 je tu! (strani: 1 2 3 4 5 6 )Oddelek: Novice / Operacijski sistemi | 131094 (109877) | MrStein |
