Problemi z datotekami MKV s podnapisi pri 5gb
Alen716 ::
Pozdravljeni!
Kako bi enostavno rešil težavo s filmi mkv in podnapisi, ki imajo velikost 5gb recimo? Rad bi namreč imel datoteko manjšo od 4gb s podnapisi vred za podporo fat32 na usb ključu.
MKVtoolnix ti film lahko razdeli na dva ali več delov, vendar me zanima ali obstaja varianta da bi to naredil tudi s podnpaisi?
Hvala.
ST-777 ::
exFAT ne moreš uporabiti?
"The exFAT file system was introduced in 2006 and was added to older versions of Windows with updates to Windows XP and Windows Vista. exFAT is optimized for flash drives—designed to be a lightweight file system like FAT32, but without the extra features and over head of NTFS and without the limitations of FAT32.
Like NTFS, exFAT has very large limits on file and partition sizes., allowing you to store files much larger than the 4 GB allowed by FAT32." https://www.howtogeek.com/235596/whats-...
smacker ::
Podnapise lahko splitaš na več CDjev z time adjusterem ali z subtitle workshop. Seveda je pa format ključka na exFAT ali NTFS bolj praktična rešitev ;)
USB ključ in oblika formatiranja
112501 (2352) rabelj5
Format diska za max kompatibilnost
162679 (2290) opeter
Formatiranje diska v W10 ne gre v starejše formate (strani: 1 2 )
5611526 (10266) Pithlit
kopiranje na usb ključ
1610096 (9821) iloveboobz
Servisni paket popravkov za Visto (strani: 1 2 )
Oddelek: Novice / Varnost
6313924 (8925) SebaR
