Forum » Izdelava spletišč » Apache problem
Apache problem
matjash ::
Ve kdo kaj bi lahko bilo krivo, da apache vsake toliko časa odpre napačen vhost. Obiščem domeno in kdaj odpre pravi document root, kdaj pa od enega virtual hosta. Zmeraj od istega. Imam omogočen 000-default, ki pravilno vrne željeno stran. Prvi vhost, na katerega tudi random redirecta dela, drugi tudi, zadnji pa ne. Poskusil sem ustvariti še enega in se napaka prav tako pojavi.
Ob redirectu se v apache loge ne zapiše nič.
... bolje pozno kot nikoli.
- spremenil: matjash ()
matjash ::
apache2.conf
primer vhosta, vsi so enaki:
zamenjal sem *:80 z internal ip zaradi iskanja napake
Mutex file:${APACHE_LOCK_DIR} default
PidFile ${APACHE_PID_FILE}
Timeout 300
KeepAlive On
MaxKeepAliveRequests 100
KeepAliveTimeout 5
User ${APACHE_RUN_USER}
Group ${APACHE_RUN_GROUP}
HostnameLookups Off
ErrorLog ${APACHE_LOG_DIR}/error.log
#LogLevel warn
#LogLevel debug
LogLevel rewrite:trace3
IncludeOptional mods-enabled/*.load
IncludeOptional mods-enabled/*.conf
Include ports.conf
NameVirtualHost 10.0.0.214
<Directory />
Options FollowSymLinks
AllowOverride None
Require all denied
</Directory>
<Directory /usr/share>
AllowOverride None
Require all granted
</Directory>
<Directory /var/www/>
Options Indexes FollowSymLinks
AllowOverride None
Require all granted
</Directory>
DirectoryIndex index.php index.html
AccessFileName .htaccess
<FilesMatch "^\.ht">
Require all denied
</FilesMatch>
LogFormat "%v:%p %h %l %u %t \"%r\" %>s %O \"%{Referer}i\" \"%{User-Agent}i\"" vhost_combined
LogFormat "%h %l %u %t \"%r\" %>s %O \"%{Referer}i\" \"%{User-Agent}i\"" combined
LogFormat "%h %l %u %t \"%r\" %>s %O" common
LogFormat "%{Referer}i -> %U" referer
LogFormat "%{User-agent}i" agent
IncludeOptional conf-enabled/*.conf
IncludeOptional sites-enabled/*.conf
#SetEnv APPLICATION_ENV "production"
<VirtualHost 10.0.0.214:80>
ServerAdmin support@lilia.it
ServerName www.lilia.it
ServerAlias lilia.it
DocumentRoot /var/lady-amarena/public
<Directory /var/lady-amarena>
AllowOverride All
Require all granted
</Directory>
</VirtualHost>zamenjal sem *:80 z internal ip zaradi iskanja napake
| » | Apache in Node.JSOddelek: Izdelava spletišč | 2568 (2254) | dunda |
| » | DNS preusmeritevOddelek: Omrežja in internet | 1203 (995) | b3D_950 |
| » | Apache Alias pomočOddelek: Omrežja in internet | 1547 (1458) | BlueRunner |
| » | Apache - localhost JA, IP naslov NEOddelek: Omrežja in internet | 7237 (7096) | ManDriver |
| » | orodje za pregled in prikaz statistike HTTP dnevnikovOddelek: Programiranje | 1131 (991) | napsy |
