Apache problem
Apache problem
matjash ::
Ve kdo kaj bi lahko bilo krivo, da apache vsake toliko časa odpre napačen vhost. Obiščem domeno in kdaj odpre pravi document root, kdaj pa od enega virtual hosta. Zmeraj od istega. Imam omogočen 000-default, ki pravilno vrne željeno stran. Prvi vhost, na katerega tudi random redirecta dela, drugi tudi, zadnji pa ne. Poskusil sem ustvariti še enega in se napaka prav tako pojavi.
Ob redirectu se v apache loge ne zapiše nič.
... bolje pozno kot nikoli.
  • spremenil: matjash ()
blackbfm ::
pokazi confige
matjash ::
apache2.conf
Mutex file:${APACHE_LOCK_DIR} default
PidFile ${APACHE_PID_FILE}
Timeout 300
KeepAlive On
MaxKeepAliveRequests 100
KeepAliveTimeout 5
User ${APACHE_RUN_USER}
Group ${APACHE_RUN_GROUP}
HostnameLookups Off
ErrorLog ${APACHE_LOG_DIR}/error.log
#LogLevel warn
#LogLevel debug
LogLevel rewrite:trace3
IncludeOptional mods-enabled/*.load
IncludeOptional mods-enabled/*.conf
Include ports.conf
NameVirtualHost 10.0.0.214
<Directory />
        Options FollowSymLinks
        AllowOverride None
        Require all denied
</Directory>
<Directory /usr/share>
        AllowOverride None
        Require all granted
</Directory>
<Directory /var/www/>
        Options Indexes FollowSymLinks
        AllowOverride None
        Require all granted
</Directory>
DirectoryIndex index.php index.html
AccessFileName .htaccess
<FilesMatch "^\.ht">
        Require all denied
</FilesMatch>
LogFormat "%v:%p %h %l %u %t \"%r\" %>s %O \"%{Referer}i\" \"%{User-Agent}i\"" vhost_combined
LogFormat "%h %l %u %t \"%r\" %>s %O \"%{Referer}i\" \"%{User-Agent}i\"" combined
LogFormat "%h %l %u %t \"%r\" %>s %O" common
LogFormat "%{Referer}i -> %U" referer
LogFormat "%{User-agent}i" agent
IncludeOptional conf-enabled/*.conf
IncludeOptional sites-enabled/*.conf
#SetEnv APPLICATION_ENV "production"
primer vhosta, vsi so enaki:
<VirtualHost 10.0.0.214:80>
    ServerAdmin support@lilia.it
    ServerName www.lilia.it
    ServerAlias lilia.it
    DocumentRoot /var/lady-amarena/public
    <Directory /var/lady-amarena>
        AllowOverride All
        Require all granted
    </Directory>
</VirtualHost>
zamenjal sem *:80 z internal ip zaradi iskanja napake
Apache in Node.JS
Oddelek: Izdelava spletišč
92630 (2316) dunda
DNS preusmeritev
Oddelek: Omrežja in internet
61231 (1023) b3D_950
Apache Alias pomoč
91570 (1481) BlueRunner
Apache - localhost JA, IP naslov NE
187284 (7143) ManDriver
orodje za pregled in prikaz statistike HTTP dnevnikov
Oddelek: Programiranje
51162 (1022) napsy
