Pomoč pri programiranju pacmana v visual studiu.
Jiffle ::
public partial class Form1 : Form
        public Form1()
            InitializeComponent();
        char smerP = 'R';
        int speedP = 3;
        char smerG = 'R';
        int speedG = 3;
        int tocke = 0;
            R - right
            L - left
            U - up
            D - down
        private void timer1_Tick(object sender, EventArgs e)
            switch (smerP)
                case 'R': pbPacman.Left += speedP; break;
                case 'L': pbPacman.Left -= speedP; break;
                case 'U': pbPacman.Top -= speedP; break;
                case 'D': pbPacman.Top += speedP; break;
        private void pbPacman_Tick(object sender, EventArgs e)
            if (pbPacman.Bounds.IntersectsWith(cesnja.Bounds))
                tocke += 100;
                tocke2.Text=(tocke.ToString());
            if (pbPacman.Bounds.IntersectsWith(limona.Bounds))
                tocke += 100;
                tocke2.Text = (tocke.ToString());
        private void Form1_KeyDown(object sender, KeyEventArgs e)
            switch (e.KeyValue)
                case 37: smerP = 'L'; break;
                case 38: smerP = 'U'; break;
                case 39: smerP = 'R'; break;
                case 40: smerP = 'D'; break;
        private void tGhost_Tick(object sender, EventArgs e)
                Ghost-a bi bilo dobro omejiti, da bi se
                premikal le znotraj okna, sicer hitro uide
                izven vidnega polja.
            switch (smerG)
                case 'R': pbGhost.Left += speedG; break;
                case 'L': pbGhost.Left -= speedG; break;
                case 'U': pbGhost.Top -= speedG; break;
                case 'D': pbGhost.Top += speedG; break;
            // Spodnji del kode zazna, ali sta se pacman in gost 'zaletela'
            if (pbGhost.Bounds.IntersectsWith(pbPacman.Bounds))
                tGhost.Enabled = false;
                tPacman.Enabled = false;
                MessageBox.Show("Konec igre");
        private void tSpremeniSmerG_Tick(object sender, EventArgs e)
            /*  Trapasta logika premikanja ghost-a. Vsake toliko časa
                izbere naključno smer.
                Primerna izboljšava bi bila tudi, če bi se ghost
                premikal tako, da bi sledil pacmanu.
            Random r = new Random();
            switch (r.Next(4))
                case 0: smerG = 'U'; break;
                case 1: smerG = 'R'; break;
                case 2: smerG = 'D'; break;
                case 3: smerG = 'L'; break;
Zanima kaj tocno imam narobe pri "private void pbPacman_Tick(object sender, EventArgs e)" ker hočem da mi vsakič ko se pacman dotakne sadja mu zviša tocke, toda mi ne uspeva. Zanima me tudi kako bi najlazji nacin naredil "zide" ( to da pacman niti ghost ne more iti čez , ali je treba uporabiti Intersect.Bounds kodo?
  • spremenil: bluefish ()
[c#] Slika iz URL
Oddelek: Programiranje
163354 (2941) MrBrdo
C# Pomoč
131801 (1626) jizzer
uporaba C++ unmanaged kode v C#.NET projektu
112311 (2034) krho
[c#] enostavna Igrca -> poraba procesorja 95%
192497 (1861) elKaktus
[Visual C#] posodabljanje polja
111981 (1801) iggy1
