Forum » Izdelava spletišč » Prestashop težava (sporne SQL poizvdebe)
Jaffa ::
Da ne dolgovezim. :) Neka zadeva na Prestashopu mi periodično (vsakih cca 6 ur) obremenjuje strežniške zmogljivosti. Če se kdo bolj spozna, kaj bi to lahko bilo, bi bil zelo vesel. Hvala. ;-) Spodaj je primer sporne SQL poizvedbe (vsaka traja 160+ sekund):
Command: Query
Time: 168
State: statistics
Info: CREATE TEMPORARY TABLE ps_cat_filter_restriction ENGINE=MEMORY
SELECT cp.id_product, MIN(cp.position) position FROM ps_category c
STRAIGHT_JOIN ps_category_product cp ON (c.id_category = cp.id_category AND
c.nleft >= 6
AND c.nright <= 7
AND c.active = 1)
STRAIGHT_JOIN `ps_product` p ON (p.id_product=cp.id_product)
INNER JOIN `ps_layered_price_index` psi
ON
psi.price_min <= 7299
AND psi.price_max >= 605
AND psi.`id_product` = p.`id_product`
AND psi.`id_shop` = 1
AND psi.`id_currency` = 1
INNER JOIN ps_product_shop product_shop
ON (product_shop.id_product = p.id_product AND product_shop.id_shop = 1)
WHERE 1 AND product_shop.`active` = 1 AND product_shop.`visibility` IN ("both", "catalog") AND p.id_manufacturer IN (2) AND p.id_product IN (SELECT `id_product` FROM `ps_feature_product` fp WHERE fp.`id_feature_value` = 38) AND p.id_product IN (SELECT `id_product` FROM `ps_feature_product` fp WHERE fp.`id_feature_value` = 1265) AND p.id_product IN (SELECT `id_product` FROM `ps_feature_product` fp WHERE fp.`id_feature_value` = 1277) AND p.id_product IN (SELECT `id_product` FROM `ps_feature_product` fp WHERE fp.`id_feature_value` = 1258) AND p.id_product IN (SELECT `id_product` FROM `ps_feature_product` fp WHERE fp.`id_feature_value` = 58) AND p.id_product IN (SELECT `id_product` FROM `ps_feature_product` fp WHERE fp.`id_feature_value` = 48) AND p.id_product IN (SELECT `id_product` FROM `ps_feature_product` fp WHERE fp.`id_feature_value` = 1269) AND p.id_product IN (SELECT `id_product` FROM `ps_feature_product` fp WHERE fp.`id_feature_value` = 54 OR fp.`id_feature_value` = 68) AND p.id_product IN (SELECT `id_product` FROM `ps_feature_product` fp WHERE fp.`id_feature_value` = 261) AND p.id_product IN (SELECT `id_product` FROM `ps_feature_product` fp WHERE fp.`id_feature_value` = 98) AND p.id_product IN (SELECT `id_product` FROM `ps_feature_product` fp WHERE fp.`id_feature_value` = 53)
GROUP BY cp.id_product ORDER BY position, id_product
www.markosoft.si | www.markoshop.si
GRYPHON Z87|i7-4770k@4200MHz|16GB VENGEANCE 1866MHz
2x SAMSUNG 850PRO 256GB|GTX960|LIAN LI|BENQ BL3201PT 4K
| » | www.inled.siOddelek: Elektrotehnika in elektronika | 5804 (1223) | Anney |
| » | Tekočine za avto, kje najcenejeOddelek: Na cesti | 9410 (7734) | B-Stard |
| » | Nakup sintetizatorjaOddelek: Loža | 1672 (1180) | vostok_1 |
| » | Fotografija, kako z zaslonko in zajem svetlobeOddelek: Zvok in slika | 1347 (912) | sid911 |
| » | PHP/HTML strokovnjaki help!Oddelek: Izdelava spletišč | 2188 (1899) | TheHijacker |
