V Kaliforniji od 2017 naprej omejitev porabe računalnikov. Kmalu tudi v EU-ju?
djabi ::
Zanimivo branje:
https://www.techpowerup.com/225808/new-...
Še en komentar na to temo:
What you will do when, because of the governed power limit that computers can have, you will be forced to use external expansion hardware, and similar designs to trash can, that you and others were so displeased with? What you will say when Dell and HP, for that very reason will have to offer similar computer designs, and phase out upgradeable workstations.
I was writing this for very long time on this forum. Nobody believed me. And the funniest part is that in European Union this idea, to power limit computers was discussed in 2014 and 2015 respectively. So far, nothing happened from this, but knowing our politicians its more than guaranteed that we will see power limits in our computers.
I have also written that 95% of future market will be BGA-type. NUC, All-in-One, Laptops, tablets. What Intel say they will focus right now: Devices. Why AMD is saying that because of the costs, and the need to increase effciency scalability is more important than anything? You think that companies that build chips for your beloved, upgradeable computers are unaware of possibility that at some they will have to limit CPU TDP in Bioses, and their power draws?
I was warning about this on this forum. You still refuse to see the reality, despite it slowly turning true.
To wrap this up I have written an analogy to what can happen in future with power limits.
NUC power limit: 85W.
Small desktop computers - 150W power draw.
All-in-one - 250-300W power draw.
Workstation/Gaming desktop - 500W power limit.
Makes sense? Again this is only analogy. Ironic in this case is that tablets and laptops could be excluded from this because they have built in batteries, at least that was the reasoning behind excluding them from power limits in discussion in EU.
Kratki povzetek:
V Kaliforniji želijo omejiti maksimalno porabo računalnikov, s tem pa so verjetno šteti dnevi tudi komponentam, ki imajo visoko porabo. Vprašanje je tudi prihodnost ti. delovnih postaj in gaming-računalnikov, ki imajo visoko porabo. So šteti dnevi nadgrajevanja komponent računalnikov?
Regulacijo naj bi začeli izvajati naslednje leto in bo trajalo približno 4 leta (do 2021), da bo v celoti zaživela.
Tudi v Evropski uniji je to bilo že nekajkrat na dnevnem redu, nazadnje leta 2015.
Obenem je zaživel t.i. Ecodesign standard, ki je eden izmed prvih korakov, da se to nekako uveljavi.
Kaj pravite?
Gejspodar ::
Nesmiselno.
mihec87 ::
Budalaščina..
Meanwhile pa ima odprto okno in nažgano klimo.....
M-XXXX ::
mihec87 je izjavil:
Budalaščina..
Tako ali tako to nima veze ker to je nemogoče omejiti. Sestaviš svoj PC in lahko namestiš poljubne komponente.
  • spremenil: M-XXXX ()
Za povprečnega uporabnika bi čisto lahko sestavili dovolj močan in varčen računalnik...
Že če komponente niso predimenzionirane, se lahko prihrani kar nekaj elektrike.
Tako ali tako pa večina svojih računalnikov ne nadgrajuje ampak jih zamenja ko so prepočasni ali crknejo.
Meni se zdi ta smernica kul. Včasih je dovolj zamenjati stare škatle z poceni novimi, pa vidiš da prihraniš cel kup denarja na leto samo za elektriko... Pa še hitrejše imaš...
Seveda je ta ideja dobra, ampak spet začenjajo na napačnih mestih kot ničkolikokrat prej in drugje :)
Po eni strani ogrevamo in eni pacienti luftajo, po drugi bi pa tu uzakonjali nekaj pri ITju... najprej naj popucajo pri osnovah, grejejo se vsi, PCja pa nima vsak :)
SaXsIm ::
Mislim, da se ne zavedate specifike Kalifornije - draga elektrika in nestabilno omrežje. Pri nas to pač ni problem. Zato se tudi ni za bati za takšna pravila.
SaXsIm
#000000 ::
VEGAS in ATLANIC CITY pa k novoletno drevo 365 da ne omenjam vseh nesmislov tam ki jih goni štrom razen money mašin ter security sistemov.
  • spremenilo: #000000 ()
uff, tole bo pa hud udarec za amd >:D
klinker ::
Kaka anti AMD propaganda verjetno :P
//sarcasm//
Ahim ::
mihec87 je izjavil:
Budalaščina..
... pa navijanje za elektrocne avtomobile.
Amd radeon 7xxx series boost problemi rešitve.
385422 (4566) Janac
Electric fusion (inertial electrostatic confinement fusion - IEC) (strani: 1 2 )
8210607 (7049) A. Smith
Nov članek: "All your firmware are belong to us" (strani: 1 2 3 )
Oddelek: Novice / Nova vsebina
13820334 (17174) arrigo
Jest mam virus a?!
142820 (2577) Kriko
