Nvidia Volta
Nvidia Volta
7 / 16
Predator X ::
ja dr_M vega res nima perfa, ki bi ga mogla met vsejn je pa 400-500EUR, dober freesync monitor je pa 200EUR manj kot dober gysnc monitor. Če primerjamo setup imaš freesync + vego dost cnej kot pa counter part nvidije.
Da negovorimo o driverjih itd.
D3m0r4l1z3d ::
Uu, poglej, zdaj pa driverji pomembni, lol
A zdej je ze 200e cenej? Vcasih so bli 100...
  • spremenil: Dr_M ()
D3m0r4l1z3d ::
On SpecViewPerf 12.1, the Titan V delivers better performance than NVIDIA's professional Quadro P6000 (which goes for $5,000) across all workloads save one. This seems to be the best price-performance ratio for this graphics card, not gaming; so if you're looking for the best possible compute performance and the best gaming experience on the side, the Titan Volta is the only solution.
klinker ::
Predator X je izjavil:
Kmal bo tuki "all in one čip". Intel je zgubil PC gaming.
Kdaj je pa Intel bil sploh v gamingu? 8-O:))
S to izjavo si se pa krepko ustrelu v koleno...ce s cim drugim AMDja ne mores vec primerjat ;(( in ja...GPU del je pogrnu kot se nikoli do zdaj.
Predator X ::
klinker je izjavil:
No, no. Ti si se malce ustrelu v koleno? Kavica, pa kavica + polom AMDja prihajata. Kje pa Intel? Ne ne gaming pa ne. Kje pa desktop ga sploh nezanima.
Kabylake, Skylake X ter Kavica v enem letu.
gddr85 ::
itak da ga zanima, zato pa je vzel radeon gpuje ;)
klinker ::
klinker je izjavil:
In kaj imajo cpuji in desktop veze z Titan V in ostalimi gaming grafami? 8-O
Tebi res dogaja :))
D3m0r4l1z3d ::
https://www.techpowerup.com/239686/nvid...
Titan V reveals itself as a graphics card that achieves 69 MH/s at stock settings - and an even more impressive 82 MH/s when slightly overclocked. Overclocking methodology was simple - increase temperature and power targets for the Titan V, and then increase memory frequency until a bottleneck was found. And voila. The Titan V was happily churning out 82 MH/s in version 10.2 of the Claymore Miner - more than double the output of an RX Vega 64 and Titan Xp.
Predator X ::
D3m0r4l1z3d je izjavil:
Sej sm reku. Tole je mining beast.
Za minerje ni zanimiva.
Vstopna cena je previsoka.
Predator X ::
Res je.
Ampak tole pomen, da bo mining samo rasel.
GDDR6 bo pripomogelk temu. Kokr sm opazu bo 13-14Gbps, pa še HBM bo cenejši.
Kmal pa bomo pri 128Bitnem vodil vidl 200GB/s. Kar me zanima ali bo AMD začel HBM dajat v medium range GPUje ~ 300€. Zna se zgodit, da bodo kriptovalute še poskočile.
GenZNPC ::
Sej bo, Fury pa Vega pac nista prinesle pomladi. Jebiga to se zdaj odraza v upocasnjeni konkurencni bitki.
Nvidija je ze ready za Navi.
Glede na performance razmerje med Titan pascal first in Titan V lahko predvidevamo performance x70 in x80 kartic.
Nekega velikega skoka letos ne bo, razen ce AMD pride poleti na trg z kartico ranga Titan V, ne pa leto pa pol pozneje spet.
Freesync buyerji so se v manjsi manjsini fanboyev kot radeon buyerji aka irelevantno za debato.
Titan V je fina kartica za nova 4k VR ocala !!! Pimax!
Vega FE je meeh as of today
skibidi
Titan V je polni Volta čip?
neo5468 ::
3k volta je dobesedni fuck you amdju. Pa še sandbagal so jo pol leta. Jaz bi isto naredil. Treba je pokazat dominanco.
Predator X ::
neo5468 je izjavil:
Volta je 815mm^2 čip.
Če AMD vrže 2x VEGA (IF link) bo vsejn cenej kot pa 815mm^2 čip.
Tud če bo frekvenca na 1100-1200MHz, da pridejo pod 150W per čip ma zadeva vsejn 18TFLOps.
Predator X ::
Nerazumem zakaj so šli delat čip za višje frekvence na 14nm LP... Razn če imajo focus na 12/7nm.
gddr85 ::
menda dual vega še pride, samo poraba in performance žal ne bo enak volti :))
klinker ::
Bo kaj? Lih prisla na nivo 2060ke s 4x visjo porabo? :))
Ker lahko :)
  • spremenilo: klinker ()
D3m0r4l1z3d ::
Gv100 v Titan V je full chip, top geforce bo verjetno gv102 brez tensor cores in tako čip ne bo 800+ mm2.
GenZNPC ::
Remember Titan X in Titan Xp ?
Ce imajo tak produkt kot je Titan V in Tesla V100 ze v rokah imajo sigurno ze celo paleto za 2018 in mogoce kako presenecenje za 2019 pripravljeno.
skibidi
D3m0r4l1z3d ::
Spomladi so sposobni gv 102 in gv104 ven dat, sem prepričan. Upam, da bo mindfactoey do takrat že pošiljal spet v Slo.
GenZNPC ::
Kupis zle BTC pa 2019 kupis na caseking.de z BTCji 2080Ti.
Sounds like a plan to me :)
skibidi
Tudi ce ne, je dovolj stacun, ki omogocajo paypal placevanje.
klinker ::
Ce bo AMD tako spal, bos dobu k vecjem se 1060 Ti in nic vec...oz. bo 2060 kostala 500€, 2080 pa jurja ;((
Predator X ::
klinker je izjavil:
Sem hotel biti tiho, ampak AMD naj bi pripravljal 7nm GPUje.
klinker ::
klinker je izjavil:
Kr naj...but but...rezultati bodo povedali svoje, ker impresivnih stevilk so vedno polni :|
D3m0r4l1z3d ::
Eh, kaj rezultati, ampak KDAJ? Vega bi bila lansko pomlad čist ok.
7nm, kdaj?
Predator X ::
govorice, nakoc bo pa Q2 2019.
Naj bi bila že VEGA 64 narejena za 7nm.
GenZNPC ::
Aftermarket Vega bi ze tut morala bit v mojem racunalniku letos spomladi, pa ni ni
skibidi
D3m0r4l1z3d ::
Anandtech ima dober preview Titana Volte. V predelu Can it run Crysis, so lepo zapisali, da je prva grafična, ki na 4k ultra nastavitvah vse prav vse na max. spravi 60fps iz sebe, oziroma prava grafična, ki poganja to igro The way its meant to be played ;)
https://www.anandtech.com/show/12170/nv...
Zanimiva primerjava Titanov.
klinker ::
Zgleda so se pri volti drzali malo nazaj, da ne bo amd prevec srot spet izpadu >:D
Ales47 ::
Ze mogoce kdo zna, kdaj priblizno bi prisli novi modeli? hocem mojo 970 ze menjat za 1440p ce lih je se dobra hehe:)
Kaksna 2060/2070 bi bla zadost:P
trenutne cene so pa itak " joke "
Ryzen 7 5800X3D|Aorus X570|32GB KINGSTON DDR4|RTX 3080|250GB SSD Samsung|2TB
Nihče ne ve, ampak pričakuj tam okrog junija. Pravzaprav lahko kar računaš, da bo podobna štorja kot s Pascalom.. 2070 in 2080 torej junija, cene pa tokrat še bolj napihnjene zaradi efektivnega monopola Nvidije (GTX2070 cena ~700€, GTX2080 pa ~1000€). GTX2060 potem avgusta za ~450€. :) In potem čakanje na zaloge, custom kartice, pa mogoče še kak Founders Edition povrh. Skratka, če si navaden smrtnik, raje kar prestavi nakup na 2019.
Ales47 ::
haha kar direktno :) pol bom mogo se CPU menjat... :)))
gddr85 ::
ah, razen če bo rang kar poskočil za x2, potem bi morale bit 2060ke tam 350+, 2070ke 500+ in 2080ke 750+ (odvisno tud kater aib)
  • spremenil: gddr85 ()
D3m0r4l1z3d ::
glede na to, da bo tudi 12nm, znajo biti cene res kar 350+ za stock 2060 6/8gb
gddr85 ::
no, za tistega, ki mu bo 350+ preveč, bo imel na voljo delno pohabljeno 2060 3gb za samo 250+ bucks :))
D3m0r4l1z3d ::
2060 5Gb ;)
Računajta, da so že danes poštene 1060tke od 300EUR naprej, 2060 pa zna imet še 8Gb rama, tko da pod 400EUR si jaz nikakor ne bi nadejal v začetku. Razen če rudarjenje crkne, potem bo trg čez noč preplavljen z rabljenimi karticami in se cene sesedejo. Ampak kakšna je možnost ...
edit: Ne samo 12nm, ampak tudi GDDR6 (vsaj pri 2070/2080).
  • spremenil: DarwiN ()
Se mi zdi, da ste eni mal pocasni v glavi.
Razlika med Titan Xp in Titan V je relativno majhna. 20% hitrosti pri Crysis. Kljub temu pa pricakujete, da bo NVIDIA cudezno naredila se en tak skok, kot jim je uspelo pri predhodnih dveh generacijah GPUjev.
Se pa strinjam z Darwinom, da nas bodo pocasi nategovali, prvo top GPUji,... Cas za nakup zna res biti sele 2019.
Osebno upam na vecji skok pri AMD z NAVI (vsaj za razliko od VEGA), ce bodo res uspeli z dobro implementacijo vecih manjsih GPUjev. Seveda zna biti isti zajeb, kot je VEGA.
D3m0r4l1z3d ::
V igrah so ponavadi Geforci hitrejši od Titana na istem gpuju.
Kle gre za primerjavo med istim razredom kartic, Pascal vs. Volta. 20% ni bas veliko (pr enih igriah je se manj). Tko, da zna NAVI koncno dohiteti, kar bi bilo dobro za vse, posebaj nas, koncne uporabnike.
Osebno mi gre na k., da so graficne trenutno vsaj za 35% precenjene.
klinker ::
Hja, ce se bodo sli isto taktiko kot z 9xx-->10xx, bo 2070ka res ene 500€ pa gor.
Prevec ne smejo it gor s performansom, ker bojo pojedli AMD....ze tako ga grizejo konkretno.
Torej pricakujes en tak velik cudez? S 500w porabo? Good for you.
D3m0r4l1z3d ::
Želi si pač, da bo spet zdrava konkurenca, tako kot si nas večina tudi. Volta ne bo prinesla iste pohitritve kot pascal s 16nm iz 28nm Maxwella, tudi to je res, ampak roko na srce ji tudi sploh ni treba, ker je Vega za gaming brez veze.
Dr_M je izjavil:
Vsaj dojamem, da 7 nm je boljse od 12 nm. S tem tudi p/w. Mas prav. Good for me.
D3m0r4l1z3d ::
Bo pa 7nm dražje
GenZNPC ::
https://wccftech.com/nvidia-gameworks-r...
Pa da vidimo v ponedeljek kaj naj bi bil tale Volta RTX, zanimivo ane. Po eni strani dobi xbox freesync po drugi strani pa MS razvija z Nvidio nov API.
skibidi
7 / 16
AMD Navi in EPYC 2 prispeta v tretjem četrtletju (strani: 1 2 3 )
Oddelek: Novice / Rezultati
10226729 (24183) Mr.B
Nvidia prinaša podporo DXR raytracingu na kartice GTX (strani: 1 2 3 )
12239231 (35660) Cange
