MYSQL trim
MYSQL trim
BRBR ::
select term, hex(term) from t
where term like ' %'
" kihavka","206B696861766B61"
" kober","206B6F626572"
update t set term = trim(term)
Tale zadnji sql nima nobenega učinka na zgornja dva recorda, zakaj ?
Vitamin-B ::
Skripta je OK (meni dela).
Morda imas vklopljen safe update
izklop z ukazom > SET SQL_SAFE_UPDATES = 0;
BRBR ::
Ni to.
SHOW VARIABLES LIKE 'sql_safe_updates'
--> OFF
Oboje , tabela in column sta utf8_slovenian_ci ampak to najbrž nima veze.
  • spremenil: BRBR ()
BRBR ::
npr, tole ne dela:
update t set term = trim(both ' ' from term)
tole pa dela:
update t set term = trim(both UNHEX(20) from term)
Kakšen komentar ?
[MariaDB] Kolikokrat se pojavi tekst v tekstu?
Oddelek: Programiranje
71135 (828) BigWhale
Zanimiv ...hm... problem
Oddelek: Programska oprema
283515 (3010) poweroff
MYsql: Error: Incorrect decimal value: '' for column '' at row -1
7956 (881) Vazelin
Apocalypse Now - the Game
Oddelek: Igre
194077 (195) oo7
Kaj za vraga je to RAID?
142838 (2503) krucymucy
